  • June 30, 2025, 10:14:07 PM
Author Topic: OK over spray..........  (Read 2244 times)
Offline Bootlegger
« on: March 06, 2009, 09:56:52 AM »
    Seem's that some time back there was a post on using some sort of kitchen pot cleaner to help remove over spray.
  I have some Red on White that I need to remove so I thought that I'd ask here.
  What do you use, this is Buterate dope with auto paint for color.
                             Thanks, Gil
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: OK over spray..........
« Reply #1 on: March 06, 2009, 10:35:03 AM »
I use some 2000 grit paper or some 00 steel wool.
« Reply #2 on: March 06, 2009, 11:14:15 AM »
I think what you are refering to is the Mr. Clean cleaning pads. They are white, about 3 x 4 inchs and almost an inch thick. havent used them myself but hear they are great for cleaning up LIGHT overspray.
Offline Bootlegger
« Reply #3 on: March 06, 2009, 04:13:11 PM »
  #^          The "Grey matter" kicked in, what I was trying to remember was a product called "Soft Scrub" a counter top cleaner. Can be picked up at Super Markets, or as we call them in the "South" Grocery Stores...
  Hope that this helps some one else with this problem...
Gil Causey
AMA# 6964
Offline Dick Fowler
« Reply #4 on: March 06, 2009, 04:48:13 PM »
Clay Bars - Meguiars is good. Use a dish washing soap solution as the lubricant.  Body shops use it all the time and it doesn't abrade the surface.
http://www.meguiarsdirect.com/detail/MEG+G1001
Dick Fowler AMA 144077
Kent, OH
Offline billbyles
« Reply #5 on: March 06, 2009, 05:10:38 PM »
The Meguiars clay system is the best for removing overspray.  I use it with either their "Quik Detailer" or "Final Inspection" liquids as the lubricant.
« Last Edit: March 06, 2009, 06:03:53 PM by billbyles »
Bill Byles
AMA 20913
So. Cal.
