  • June 23, 2025, 10:52:38 AM
Author Topic: Triple nearly done.  (Read 2499 times)
Offline Robert Zambelli
Triple nearly done.
« on: February 25, 2009, 08:47:19 AM »
I finally took it off the shelf and got to work.
It's ready for primer and final finish.
Weight as shown is 27 ounces.
I estimate the ready-to-fly weight to be around 78 ounces.
The picture with the Nobler gives an idea of size - 68 inch span.
Should be fun.
Offline Roger Vizioli
  • CLiner
Re: Triple nearly done.
« Reply #1 on: February 25, 2009, 08:59:25 AM »
Lookin' good!
Will surely sound "neat!"
Roger
Roger Vizioli
AMA L-2408
Florida/Space Coast
« Reply #2 on: February 25, 2009, 11:18:18 AM »
Hey Bob,
That wing almost looks like a Cardinal wing. What engines will you put on it?
And that is one SWEET looking Nobler. I hope to see them both at Brodaks! #^
« Reply #3 on: February 25, 2009, 04:09:53 PM »
Hi, Paul - thanks for the kind words.
Yes, they will both be at Brodaks. The Nobler will fly in ama stunt and Classic.
If the triple works, I may just enter it.  I'll either impress the judges or scare the daylights out of them!  ~^ ~^ ~^
At this poit, the planned powerplants are three Surpass 26s. If they don't prove out, look for three SAITO 30s.
« Reply #4 on: February 25, 2009, 05:13:53 PM »
 That's pretty cool! y1 Are you going to have any cowlings?
Offline Larry Cunningham
  • Red Hot Lover
  • Klaatu barada nikto my ass
    • Stephanie Miller
« Reply #5 on: February 25, 2009, 06:29:41 PM »
I trust you'll be using diesel power? ;->
(Make it a challenge, Man!)
L.
"The one serious conviction that a man should have is that nothing is to be taken too
 seriously." -Nicholas Murray Butler
Offline Larry Fulwider
« Reply #6 on: February 25, 2009, 06:40:49 PM »
. . . Yes, they will both be at Brodaks.  . . .
My guess is that another big-white-stretch-limo with that triple stickin' out will do a tad of both  y1
Larry Fulwider
« Reply #7 on: February 26, 2009, 04:45:08 AM »
Yes, there will be cowlings - I will post pictures later today.
Diesels????????????????????????????????? You gotta be kidding!!!!!!  n~ n~
No more limo - I keep imaging bad guys in my rear view mirror!  LL~ LL~
« Reply #8 on: February 26, 2009, 09:47:48 AM »
OK, here are some shots of the front showing the power mod, tank and cowl.
The tank bolts to the primary firewall.
Then, the power mod, which includes the secondary firewall and plastic engine mount bolts to the primary firewall.
Then, on goes the cowl. It's made from a Walmart soda bottle.
So far, so good.
« Reply #9 on: February 26, 2009, 01:16:18 PM »
I can see the Cardinal influence in the design.  If things work out I may make Brodaks this year.  DOC Holliday
« Reply #10 on: February 26, 2009, 01:51:19 PM »
Yes, John - Cardinal aerodynamics. It works well so I decided to use it.
Hope to see you at the Fly-In.
