The four bolt / different venturi Fox 35 pictured in the classifieds is what appears to be the first Fox combat engine. Plain bearing.That came out in 57, followed by similar Blackheads(58) and then , the Rocket. Same mount bolt pattern as Stunt 35; nothing else.
In 1972-73, a Duke came out with a plain bearing engine for slow combat that at a quick glance, looked like a stunt 35. Totally different. 4 bolt backplate , angled plug, and internally snotted up( read no 2-4), different venturi with an insert. It was a 36 and the 29 looked the same, sans "29" on the crankcase. Both good runners.
