Here is the 35X. You can see the rear roller bearing, that runs directly on the crank.
Interesting that there is no bearing material in the crank journal, the crank just runs on the aluminum case.
Also quite clean, did not see much running either.
Did see something interesting though, there is a small void in the wall of the piston on the exhaust side.
Looks like a flaw in the original part, not done through some sort of damage, because there is no distortion of the piston around it.
About the same width as the divider in the exhaust port so it should not leak, but possibly could grow and cause the piston to fail?
I could grind it out to clean edges, but then it would be open when the piston is in parts of the upstroke.
A bit of side port action perhaps
I will probably just run it as is till it fails.
