  • July 20, 2025, 08:38:30 AM
Author Topic: Fox 35 ceramic  (Read 1832 times)
Offline Bootlegger
Fox 35 ceramic
« on: May 03, 2011, 10:15:15 AM »
  Fellow's that are flying this set up, what kind of fuel are you using, and what sort of fuel milage are you getting?
 I have a couple set up with this P/L and hemi head as well as the stuffer B/P, and lower nitro (5%) get's good economy, however 10%, and it goes out the window.
 It has good power, and breaks like a Fox, but the economy is shot!!
  Got any suggestions???
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: Fox 35 ceramic
« Reply #1 on: May 03, 2011, 12:22:43 PM »
   Get a bigger tank?  Generally, if you increase the power, you increase the fuel consumption.
Re: Fox 35 ceramic
« Reply #2 on: May 03, 2011, 12:39:40 PM »
Strange how that happens.
Re: Fox 35 ceramic
« Reply #3 on: May 03, 2011, 02:18:12 PM »
  You say that, but you would be amazed at how often people are surprised when it turns out that model airplanes appear to be following the established laws of science instead of being magical.
Re: Fox 35 ceramic
« Reply #4 on: May 03, 2011, 02:33:05 PM »
Even if their users don't use words to describe them the same way that the scientists do.
Re: Fox 35 ceramic
« Reply #5 on: May 03, 2011, 03:06:53 PM »
   Oh, I long since trying to fix the use of the word "power" as applied to stunt. Same with "torque". I stopped using quotes around it, too.
   The fuel consumption VS power thing is also greatly complicated by the fact that we are, frequently, tossing about half the fuel overboard without releasing its energy. So you lean it out, get 3 times the mileage, and more "power" at the same time.
Offline Steve Scott
Re: Fox 35 ceramic
« Reply #6 on: May 03, 2011, 09:25:50 PM »
But the Porsche 918 Spyder (hybrid) seems to defy logic.
Zero to 60 in 3.1 seconds and top end of 199mph.  Claims it gets 77mpg.  Of course, with a price tag of $875k you can probably change the laws of physics?
Re: Fox 35 ceramic
« Reply #7 on: May 03, 2011, 10:59:47 PM »
I think Brett has one of those in black. ;D
Offline W.D. Roland
Re: Fox 35 ceramic
« Reply #8 on: May 03, 2011, 11:36:29 PM »
Its what you do with them BTUs that determines what they do for you. H^^
David Roland
51336
Offline Steve Fitton
Re: Fox 35 ceramic
« Reply #9 on: May 04, 2011, 08:28:34 AM »
You can keep your science.  I'm going to use Rapunzel's magical hair...(!)
