Some mug here has enough 19 / 25 s for a Spruce Goose ,3 are 25s .
5 - 20 % nito , set richer with the higher, will 4/2 . set about break .
the 19 & 25 tecnically turn 9 x 4 s at the same RPMs (on 5% nitro )
according to Chinns engine tests.
I usually use em in twins, with the Two .25s , 9x5 zinger's worked good
on a stunt type run .
The 19s are crankier. At one stage , same head clearance , id set em
both at 6 or 6 1/2 turns and theyed be fine .
Lately used doubled blue tube at spray bar, had used bit over , with
the tube over a 8 mm long piece , the blankety thing restriced ,
Blowing fuel tube to set needles same ( Same ' Hiss ' ) woke me up
to this as wernt a lot of hiss on one ! Mutter mutter mutter .
So I wired em on.
Fuel Line Tends to skew , & come loose and / or may leak , on Std. tube .
Where it goes on the spay bar . Traps for wary players .
Outside of that there nice rowdy rorty devices , the 19 being
more hooligan than the 25. ( big brother ! )
Spray bars are fairly small dia. Havnt measured em.And there not
long. Late ' waisted ' OS 15 ones may fit. But these are hopeless
in OS 35s and G-15 FIs, you wind em out running , past 5 turns it
makes no differance . The outlet HOLE aint bigenough for a greedy
engine. So one could drill it out ! but there must be a simpler way .
So I await with intrest for the hot tip on the spaybar !(MVVS ? )
Now I will have to go and measure em up.
A narrow blade 10 x whatever , like a master airscrew should be fine.
Ive some ancient 'Gorrie Mit ' ! 10 x 4s ive oiled , look like Teak ,will
use em before the end of time hopefully when a DeH 88 is fully sorted.
