  • July 19, 2025, 04:53:20 AM
Author Topic: Fox 201 engine  (Read 3289 times)
Offline Jim Hoffman
Fox 201 engine
« on: July 26, 2018, 06:51:45 PM »
What is this engine?  Appears identical to a Fox 19, except the case is embossed with "201" where it originally had cast "19" raised letters
Re: Fox 201 engine
« Reply #1 on: July 26, 2018, 06:59:58 PM »
    I wouldn't put a lot of credence in this, but someone told me once that it was made for the same reason there was a TeeDee .051, that is, allow you to switch engines of the same power output and form to take you out of Class A and into Class B. That makes sense, but the reality, I don't know.
Offline bob whitney
Re: Fox 201 engine
« Reply #2 on: July 26, 2018, 07:16:41 PM »
Fox and K&B both made 201's for the free flighters  K&B's was deff a 201, don't know about the fox
rad racer
Offline dennis lipsett
Re: Fox 201 engine
« Reply #3 on: July 26, 2018, 07:18:53 PM »
I think that someone had responded to the Fox 201 dilemma awhile back in a previous thread and stated that they  probably just stamped the cases 201.
Incidentally K&B also had a Green head 19 and 201
Never having had a 201 I can't say that the statement was true or false.
Re: Fox 201 engine
« Reply #4 on: July 26, 2018, 07:21:54 PM »
Brett is exactly correct. The really interesting side of the story is that these engines are actually .19's, and all Duke did was have the cases stamped .201. The Fox History book tells about this. There were no different PN's for the .201, except maybe the c'case itself. I noticed that, back about Dec. '62.
I had one of the .201's and it was one of my favorites...ran good on Missile Mist and a 9-4 Tornado nylon prop, on a Ramrod 600 or with a 10-3.5 TF on a Veco Warrior.  y1 Steve
Offline James Lee
Re: Fox 201 engine
« Reply #5 on: July 26, 2018, 08:01:31 PM »
The Fox .201 is not just a restamped .19....    The crank has  a .003 longer throw...   And, the crank is marked, but VERY subtly.....   A dial indicator will show the diff in stroke....
Jim
Re: Fox 201 engine
« Reply #6 on: July 27, 2018, 10:24:00 AM »
I used Fox .19. .201 a lot for FF use. One mod we did to them was to cut the intake down ,shortened it,.  This allowed the motor to breath better at high rpm.
Offline Bill Mohrbacher
Re: Fox 201 engine
« Reply #7 on: July 31, 2018, 10:40:42 AM »
Veco also made a .201.  I have had several Fox 201s apart.  All have a little notch on the counterweight.  I'll put on a PIC when I get home.  The Fox 201 was in a special box that said FF Special.
Re: Fox 201 engine
« Reply #8 on: July 31, 2018, 10:47:48 PM »
   You are far more expert on these things than I, but I would presume the power difference between a 19 and a 20.1 was less than the average difference in the output between two individual 19s. I recall a kid that used to fly with my Uncle Donnie and I that had maybe 4 Fox 19s, and one was *way* stronger than the others. Uncle Donnie figured it was because the slow types were no broken in, so we ran them for a long time, and they picked up a bit but were far off the "good engine". The "good" one was very strong by baffle-piston standards- it was no Veco 19bb, but it was stronger than my OS 25S and much stronger than my OS-20S. Which pissed me off no end, I might add, his airplane was always faster.
Re: Fox 201 engine
« Reply #9 on: August 01, 2018, 10:39:04 AM »
Yes, I would doubt there was really any difference in the 19 or the 201, powerwise.  Strictly a rules thing to fly the same plane in two classes, just like the 049 and the 051s, 29s and 32s, .49s and .51s.
Re: Fox 201 engine
« Reply #10 on: August 01, 2018, 06:34:33 PM »
Jim
Interesting. I would wonder if .003" stroke would make a Fox .19 into a .201...were the .19's that close to the .199 cu. in maximum for class A? I do have a 3 bolt Fox .19, but I don't know if its displacement calculates out to .199 or not. If I remember, I'll dig it out of the gun safe and measure it up.
Further, it would not surprise me if +.003" stroke might be a possible error on a .19 crank, given Fox QC and the fact that Rossi made a bunch of 2.5cc engines that were slightly over 2.5cc's and resulted in a World Championships F1C winner being DQ'd in 1979. My recollection (which may well be fubar) is that the stroke was +.005" long...and this being from a WORLD CLASS engine maker with many NATS and WC victories. I know Fox .35's have won the F2B WC, but I find it difficult to call Fox a WORLD CLASS engine manufacturer. NOT looking for an argument on this, Brett!  ;)
As a retired machinist (but only a wee bit of centerless and surface grinding and honing experience), I can imagine how the offset tooling for the crank throw might be done, and it would seem simple enough to design such that an error would be difficult...but you never know how somebody else would/could design the tooling. Then again, we're talking about Fox.
I don't recall seeing anything about a K&B .201 Greenhead, but saw many .23's, and then there was the 3.25cc version of the 3.5cc hotrod. Ditto for a Veco .201, which I suppose might have been a Series 200? Or a .201 version of the .19bb? From 1969, I mostly flew FF until the late '80's, and was a member of NFFS for two decades, so I can't understand why I wouldn't have read or seen those other .201's, but anything is possible. Maybe some California secret factory engines? That's certainly plausible.
By the way, when I worked in QC at Jorgenson Steel, one of my monthly tasks was to calibrate micrometers and dial indicators, both company and machinist owned. It turns out that for a typical 0-1" stroke dial indicator, .003" variation from nominal for a brand new one was about as good they got. Many "experienced" ones were .006" off nominal, which IIRC was acceptable. I saw some that were really beat and were more like .012" off nominal and those were labeled as unacceptable and supposed to be taken out of service. A 0-1" indicator would likely be used to measure a model engine's stroke, leading me to suggest that it's just not an appropriate tool for the job. There are 1/2" stroke indicators, but they're far and few between. I've seen a few of those, maybe 3 in 35+ years.
I looked online for a picture of the test device used, but no joy. It was a Mitutoyo, and sort of a vertical micrometer without the anvil end, and a column to mount the subject indicator on. The dial was probably 5" to 6" diameter, giving lots of hashmarks to eyeball. I seem to think it was marked in .0001" increments, but maybe .00001"...way less than required for the job. That instrument got sent out for calibration in a lab somewhere in Seattle.
The machinists whined that their rejected indicator worked fine to dial-in a round-ish part in a 4-jaw chuck, and I agreed completely, but Mil-Spec limits were law, so these were condemned if out of tolerance. Usually, they'd be tagged and sent in for repair at company expense, but if it wasn't adjustable by the lab to be in tolerance, the machinist had to buy a new one...and I'd get to check their brand new indicator. That's not adjust, but check and apply a stamp to show compliance to whatever the Mil-Spec is/was...which I'm vaguely remembering to be within .006" over the travel of the instrument, regardless of the travel. Kinda sloppy tolerance for a test indicator with only .010", .030" or .060" travel.
The WORST dial indicators were the back plunger .300" travel models, usually Starrett. They were crap, new or old. I don't think any of them passed. The 0-2" stroke indicators were not impressive either. Here's where Mil-Spec didn't mesh with reality. It really depends on how the indicator is being used. I'd trust a depth mike over a 1" travel indicator to measure an engine's stroke, anytime. Federals were my favorite real American brand, but they were already out of business by 1981.
Anybody know how to Google for Mil-Specs for inspection equipment? I tried, and gave it up.   H^^ Steve
Re: Fox 201 engine
« Reply #11 on: August 02, 2018, 05:16:24 AM »
The Fox 19 had a .650x.600 Bore and stroke = .199
The 1957 .201 .650 x .607, picture shows the notch in the counterweight I've seen on all the 201s I've handled
The K&B was out in 1960, had a .650 x .625 Bore and stoke, .201 on crank, cast on the side of the case, and stamped on some heads.
The Veco 201 was a Series 100, made in 1956, was also stoked, I have no dimensions.  Only about 200 were made.
Sorry no photos of the K&B or VECO Guts
Re: Fox 201 engine
« Reply #12 on: August 02, 2018, 09:24:36 AM »
The K&B 201
Offline Perry Rose
Re: Fox 201 engine
« Reply #13 on: August 02, 2018, 04:30:28 PM »
Mil-spec refers to a specification for an item made for the gov't.  The gauges used to assure it's made to the "spec" are calibrated to standards traceable to the N.I.S.T. Hence the $100.00 hammers.
Offline BOB ALLAN
Re: Fox 201 engine
« Reply #14 on: August 02, 2018, 07:01:59 PM »
More here (note that the K & B has "201" cast on the side of the case)
https://www.rcgroups.com/forums/showthread.php?1402733-Vintage-Glow-Engines/page952#post36229770
Re: Fox 201 engine
« Reply #15 on: August 03, 2018, 03:17:32 PM »
I thought it was $700 hammers and $400 toilet seats? I once made a one-off spherical part from AL-NI-Bronze (pretty tough stuff to machine) for the Bangor (WA) submarine base. About 1.5" dia, with what looks to be about a 2" radius...not easy on a manual lathe. I spent quite awhile hand grinding a radius tool and then lapping the tool to smooth out the bumps. After I got the part(s) made, I read up on the packaging and part marking requirements for hours, only to be saved by the boss calling the customer and asking what they expected and required for packaging and part marking. I've got the back-up part right here, still in the bag, PN, Rev.B, etc. Nice work, if I do say so myself! One of these days, I'll throw it in the recycling bin.   n~ Steve
Re: Fox 201 engine
« Reply #16 on: August 03, 2018, 04:01:58 PM »
  What sort of inspection equipment?  I know of some test requirements, like the test equipment has to be accurate to 10X as good as the tolerance on the item being test, stuff like that.
