  • July 12, 2025, 01:02:36 PM
Author Topic: Fox .15 Diesel!!!  (Read 3229 times)
Offline peabody
Fox .15 Diesel!!!
« on: November 29, 2012, 12:08:24 PM »
Trying to sort stuff (it's been a year long ordeal),
I have come across a FOX .15 Diesel!!!! Is there any point in offering it for sale, or should I just ship it to Brett for the HURL?
Thanks, and have fun!
Offline dennis lipsett
Re: Fox .15 Diesel!!!
« Reply #1 on: November 29, 2012, 01:39:47 PM »
Rich,
if it's dieselized then it's gotta be the Fox 15BB model and that is not the engine that gets hurled. The Fox 15X is the correct model and the answer is really quite simple.
the Fox 15x weighs just slightly more then 3 ounces the 15BB model is 7.2 ounces approx. That 3 oz difference would be enough to throw out the shoulders of those old guys and even worse they'd really be embarrased at the short range that they would achieve with your engine. My recommendation is to sell it on Fleabay to some deserving modeller.
Dennis
Offline Chris Wilson
« Reply #2 on: November 29, 2012, 02:54:56 PM »
If its a diesel Brett wouldn't touch it!
MAAA AUS 73427
Offline Dan Bregar
  • Field Marshall
« Reply #3 on: November 29, 2012, 04:00:15 PM »
I say HURL IT !!!  ;D
AMA 33676
« Reply #4 on: November 29, 2012, 10:53:43 PM »
  I smell funny enough already.
Offline Larry Fernandez
« Reply #5 on: November 30, 2012, 12:51:05 AM »
This motor is not legal for the "World Famous Fox .15 Hurl"
It must be the slant plug version.
Larry, Buttafucco Stunt Team
« Reply #6 on: November 30, 2012, 08:59:17 AM »
Put in on the bay or better yet on RiteAuction.  I just might bid on it.  I love diesels when I can get the ether.   Have to go check and see if the starting fluid cans are in stock yet.  Last time I only got 9 ounces of ether out of a can.
Offline bill bischoff
« Reply #7 on: November 30, 2012, 02:27:31 PM »
According to Jim Dunkin's reference book on .15 engines, if it's the baffle piston version, only two were made. The conversion was done by Ronald Valentine. If it's the schnurle engine, the conversion was possibly a custom job by Fox.
Either way, probably significantly more valuable than a garden variety Fox.
Offline Douglas Ames
« Reply #8 on: November 30, 2012, 02:33:15 PM »
Could be a Davis Diesel conversion?
AMA 656546
« Reply #9 on: November 30, 2012, 05:09:31 PM »
It undoubtly is. I can't imagine Fox  doing anything custom.
Dennis
Offline Michael Boucher
« Reply #10 on: December 01, 2012, 09:59:47 AM »
Davis Diesel made a conversion head for the FOX 15BB version  :)
AMA 59633
Offline YakNine
« Reply #11 on: December 01, 2012, 10:18:22 AM »
I sent you a pm Rich
AMA 85135        GSCB
Offline billbyles
« Reply #12 on: December 01, 2012, 01:58:08 PM »
So, Larry, when you hurl the Fox .15 does it have to have the plug installed & torqued?
Also, the other evening at Warren's Man Cave gathering we needed something to test the spray gun pattern so we just went down the hall in Warren's shop & picked up one of the airplanes sitting there.  We did the spray pattern test on the left wing & decided that the bright purple (similar to the purple on the nose of Uncle Jimby's Systrema) didn't look so great over the yellow Monocote on the PT-19's wing so we put the PT back in the hallway.  You did pick up your PT-19 didn't you?
Bill Byles
AMA 20913
So. Cal.
Offline Elwyn Aud
    • Inferalandings Photo Page
« Reply #13 on: December 01, 2012, 02:10:46 PM »
I remember reading somewhere ages ago about somebody using converted Fox 15's with good success. Might have been something involving R/C combat.
Offline Bill Adair
  • AMA 182626
« Reply #14 on: December 01, 2012, 09:04:06 PM »
Wasn't Bob Davis selling those at one time?
« Reply #15 on: December 02, 2012, 07:51:19 AM »
He sells conversions  for a lot of engines.   Depending on hard you run them they last a long time.   Use to have a guy at the radio control field that had a converted .60 diesel that he hand started.   Someone asked him why he didn't use the electric started.  Was told you don't want to bend the parts if you get a hydralic lock.   Diesels guys know what  mean.
Offline YakNine
« Reply #16 on: December 02, 2012, 09:24:29 AM »
Well Rich is going to send it to me I have been looking for one of these for a while to put in a peacemaker . I called Bob Davis a while back and he didn't have any in stock and wasn't sure when he was going to make more. It will be interesting to see how it runs I was thinking about a Marz diesel but without a muffler the exhaust would make a mess.Plus Rich might get to fly it again if he comes back to Jersey for a visit. #^ T.J.
AMA 85135        GSCB
« Reply #17 on: December 02, 2012, 11:45:23 AM »
Yes Bill, the plug must be installed.
Brett spent hours putting data together, and noted that the the drag and wieght of the motor, with and without the plug made a noteable difference.
After his analysis, it was determined that the "official Hurl" is to be conducted with the plug installed.
We take this event seriously and spend a lot time and resources to make better each year.
« Reply #18 on: December 02, 2012, 04:40:30 PM »
Yep, 18:1 compression, add in a rich fuel mix, a flooded lower crank case, attach a 1/2 horse starter motor with no clutch to the spinner and see what happens!
(Kiss your con rod good bye unless you have incredible feel when pressing the rubber starter cone down.)
MAAA AUS 73427
