Guys,
I was flying my Still Stuka last weekend and it was flying very well, smooth and consistent. While flying I happen to look down the lines to see where the angle of the lines would hit the fuse. I had the leadouts set about 1/2" back from the CG point (pretty normal position). What I noticed was the imaginary extension line of the flying wires to the fuse would hit ahead of the CG. Since things were so nice I decided to see what would happen if I moved the leadouts back another 1/8". I was surprised with the result. This ship had always had a very long period hunt but with the more rearward leadouts it claimed down quit a bit. Tension up top was still very good. The ship is some 25 years old and has had several different power system (now electric) and solid leadouts. My guess is that the solid leads are more sensitive to drag if the rake is causing them to bend at the exit of the leadout guide which caused the hunt.
I will continue to trim these back a bit more but my question is as you move the LO's back what would be the signs that you are going to far (beside the obvious loosing line tension) and will the flight lines appear to hit the fuse at the CG when they are in the correct position.
Best, DennisT
That's a common story, leadout position errors tend to cause hunting because it binds up the controls. It's also another good reason not to use solid leadouts, particularly on small airplanes.
More generally, the leadouts have to be further aft if there is any rudder offset. A common misuse of adjustable leadouts is to use them to try to set the yaw angle of the airplane. You can put in lots of rudder offset, and then put the leadouts forward, and more-or-less keep the fuselage tangent to the circle in steady-state conditions. It will put a bunch of drag on the leadout guide, maybe or maybe not causing hunting, but that's not the worst problem.
The bigger issue is that any time the line tension changes, the airplane yaw angle will change - like when you try to do a maneuver. It will also cause the airplane to roll in - because as soon as it yaws in at you, the outboard wingtip is leading the inner, causing the flow over the outboard tip to cause much more lift and the inboard to cause much less lift. Of course, 1/2 a line whip period later, it all reverses itself. The result is wild wobbling all over the place, the line tension changing all over the plane, and since you are trying to do a corner at the same time, the control deflection to change (since the torque available to move the controls is also changing). So you also get wild hopping.
I have referred to this in the past as "Twister Disease" because that's exactly what happens if you set up a Twister like the plans show. Thats a bit unfair because just about every other kit shows something similar. I think you should trim tangent to the circle for other reasons but even if you trim for a large yaw angle like Igor, you still have to match the leadouts to the angle or you will get something similar. So if you have a lot of rudder offset, you are choosing to trim with a yaw angle (and it take only a TINY offset to get a big angle), and you have to move the leadouts back - instead of trying to use them to drag the airplane back to tangent. That's why if you look at David's first NATs winning airplane, it has a bunch of Zona Saw cuts in the (fixed) fin where we successively made saw kerfs to straighten out the fixed offset, and why Ted's 95 NATS winning airplane first had the fin cut off and reglued, then cut off completely and replaced to make sure it was dead straight ahead. Any why my airplanes all have adjustable (but fixed) rudders.
I am a big fan of calculating the right position and adjusting the rudder to compensate, and then seeing if it is really tangent and adjusting from there. However, no matter how you come up with the baseline trim, it's always useful to search around systematically to look for possible improvement. You can save tremendous time by a few simple computations, but it doesn't completely eliminate experimentation. As long as you know what you are looking for, it will become obvious very quickly whether you are moving in the right direction or not.
