  • July 09, 2025, 12:52:07 AM
Author Topic: paint scheme /??????????????  (Read 4640 times)
Offline W.D. Roland
« on: August 17, 2006, 12:43:43 AM »
cant decide if i should stop now or possibly paint dorsal fin area blue?
might add more red pin stripes.
sugestions please!
thanks
undecided
David
David Roland
51336
Offline Richard Grogan
Re: paint scheme /??????????????
« Reply #1 on: August 17, 2006, 01:03:39 AM »
Do the dorsal to bring it all together!! Is the white money-kote?
Long Live the CL Crowd!
                  AMA 85745
Offline Warren Leadbeatter
  • AUS-14782
    • My Home Page
« Reply #2 on: August 17, 2006, 04:37:09 AM »
Why not load the picture into Windows Paint and see what you can do?
Like this?
Warren Leadbeatter
Port Stephens, Australia
AUS-14782
  • AUS-14782
    • My Home Page
« Reply #3 on: August 17, 2006, 04:44:35 AM »
Or this...
Warren Leadbeatter
AUS-14782
Offline Steve Moore
« Reply #4 on: August 17, 2006, 08:46:12 AM »
David,
How much does it weight as is sits?  Mine got heaver and heaver the more colors I added, ended up around 54 oz (a real porker) did not have an engine big enough to pull her, lost it in vert 8 @ B. Barkers contest, lost of nice guys to pick up all the pieces... ;D
BIG STEVE
« Reply #5 on: August 17, 2006, 07:27:30 PM »
Sure was pretty though Steve.
« Reply #6 on: August 17, 2006, 09:04:28 PM »
ST,
I like the sunburst idea.
The cowling is not a huge problem to mount. I would use MEK to join the halves. Then measure how far the spinner backplate is from the firewall and add a 1/16th. Then use some Dubro #2 hex head screws and use them to screw into the sides. Once located, pull them out and add some 1/16th ply and epoxy them to the center of your screw holes for some meat.
The hard part, or fun part, is to cut out the cylinder hole, and then follow with the muffler hole. Only cut out what is needed to clear the muffler and add two 1/4 inch holes on the other side so you must remove the muffler to remove the cowling, that way there is more to the plastic structure to maintain integrity.
Save the scrap so if you mess up, you can add back to it with MEK and carve anew. When finished, sand it down so it's smooth and paint it up.
Google DeHavilland Chipmunk, Skip Volk, Don Lumley, Art Scholl, etc.  to get some good ideas for paint schemes.
Looks good, have fun.
Chris...
Offline W.D. Roland
« Reply #7 on: August 17, 2006, 11:18:06 PM »
hey Richard--how come your in 2 places on map?
 white is plastic paint --earthlings call it monokote- the blue is solar film-the red pinstripe is autozone
Warren-dats fancy! thats past the k.i.ss problem though-i resemble the last s
MAN!   Steve thats a nice lookin airplane! sucks that it bit the dust!
as it sits in pics it weighs 40.5oz---with cowel/spinner/hatches on it weighs 44oz.
Chris
 was going to make a light fiberglass cowel but it balances with the stock cowel.
i pulled a mold anyway--just in case!
it does need the 1/16 to make it fit right
hope to have time to weld up a small in da cowel muffler exiting out the bottom pointed away from aeroplane.
David
David Roland
51336
« Reply #8 on: August 18, 2006, 12:02:57 AM »
David, Something moved my first pin to SanAntonio; I relocated myself back in Houston...Just do the Dorsal blue(K.I.S.S.) and go fly!! ;D
Oh, and stick your numbers on the wing! BTW, you don't return e-mails anymore? ??? ???RG
« Last Edit: August 18, 2006, 12:50:11 AM by Richard Grogan »
                  AMA 85745
  • AUS-14782
    • My Home Page
« Reply #9 on: August 18, 2006, 04:16:08 AM »
With blue Dorsal Fin...
Warren Leadbeatter
AUS-14782
« Reply #10 on: August 19, 2006, 05:51:58 PM »
David, Heres a couple shots of mine, close to the original scheme....Richard
                  AMA 85745
Offline Greg L Bahrman
« Reply #11 on: August 19, 2006, 06:18:56 PM »
OH.....Frank is going to like this one.  y1
Greg Bahrman, AMA 312522
Simi Valley, Ca.
Offline W.D. Roland
« Reply #12 on: August 22, 2006, 11:55:59 PM »
Looks good Richard!  you have to much time on your hands(paint work)! ;D
heres mine finished---i think
David
David Roland
51336
Offline W.D. Roland
« Reply #13 on: August 23, 2006, 12:03:03 AM »
and more
David Roland
51336
Offline W.D. Roland
« Reply #14 on: August 23, 2006, 12:09:22 AM »
try agin
and more
David Roland
51336
Offline Tom Niebuhr
« Reply #15 on: August 23, 2006, 12:31:04 AM »
Chris,
Don Lumley?? Bill's Chip comes up by searching Bill Lumley.. Bill is also a PAMPA member.
AMA 7544
« Reply #16 on: August 24, 2006, 01:06:49 PM »
Very, very nice, David! Sometimes less is more!!! Are you gonna put some numbers on it?
                  AMA 85745
Offline Bob Hudak
« Reply #17 on: August 24, 2006, 08:28:09 PM »
The plane needs something to break up the wing panels white. I like Warrens idea with the sunburst in yellow or how about a shooting star.
350838
Offline Leroy Heikes
  • ACE
« Reply #18 on: August 25, 2006, 05:04:36 AM »
David;
    Your plane looks great! y1 Let us know how it flies.
Leroy
Offline W.D. Roland
« Reply #19 on: August 26, 2006, 09:57:09 AM »
probably wont be flying until weather cools down.
in the wait for cooler weather i have been restoring some old airplanes so i will have lots to test fly.
flying r/c off water at lake is only flying i do in heat of summer.
no sunbeurs ect!remember i am the last s in K.I.S.S.
havin fun!
David
David Roland
51336
