I agree with Randy and Jim - put the engine back as far as possible, use whatever weight is necessary to balance, and fly it. I relearned control line with an Akromaster and a Fox 19 so it can be done. The airplane may be a little fast, but it has the power to pull out of dumb mistakes and it will take off with close to zero ground run. A good modification is to use regular landing gear straps instead of the "shock absorbing" rubber band gear mount. The rubber bands let the gear swing back too far and the wheels will break the bottom spars. The gear wire is light enough to just bend back after a hard landing but the spars are a problem. Don't do the rubber band gear securement. If it is already done, just screw a couple of nylon gear straps below the dowel.
