  • July 11, 2025, 02:10:29 AM
Author Topic: Forced engine shut-off  (Read 2234 times)
Offline ash
« on: April 15, 2011, 12:22:44 AM »
I just watched the vid of the 2010 World Champ posted by Proparc and noticed that he used a semi-wingover to shut his engine down at the time and position of his choosing.
I've heard about pilots doing this to make sure they touch down in the ideal spot relative to the wind and judges, but rarely observed it for myself.
Anyone care to comment on the usefulness of this, whether they do it themselves or not and where exactly on the circle you're aiming for things to happen?
Offline Allen Brickhaus
  • ACE
Re: Forced engine shut-off
« Reply #1 on: April 17, 2011, 08:07:25 AM »
You must have a tank that is set in a position to give the cut off you desire.  I believe a plastic tank will not do that.  The pilot does a large loop at the downwind side and then a tight loop at the top of the second loop at the downwind side.  The engine will shut off leaving you with the goal of landing 360 degrees after the engine cut.  Your tank must be to the point that it is almost out of fuel for this to work.
Allen Brickhaus
Offline Balsa Butcher
  • High Desert Flier
« Reply #2 on: April 18, 2011, 05:26:21 PM »
I can get cut-off loops to work if the engine/tank is set up for uniflow and have low fuel...and the engine hasn't already gone lean. If muffler pressure, won't work. I use this "maneuver" as a last resort if I am in danger of an over run. Used to use it regularly but quit for 2 reasons: too many unnecessary crashes occur during cut-off loops and if it doesn't work...you look stupid. I hate that.  8)
Pete Cunha
Sacramento CA.
AMA 57499
Online Howard Rush
« Reply #3 on: April 18, 2011, 07:14:26 PM »
It's one maneuver in which you can simultaneously look elitist and stupid.  That's my kind of maneuver.
« Reply #4 on: April 18, 2011, 10:08:59 PM »
I like cut off loops so well, occasionally I will do multiple iterations in the same flight
Offline Dick Pacini
« Reply #5 on: April 18, 2011, 10:28:31 PM »
Watching Al Rabe shut his Sea Fury down with the cutoff loop was a thing of beauty and a joy to behold. y1
« Last Edit: April 19, 2011, 02:30:11 AM by Dick Pacini »
AMA 62221
« Reply #6 on: April 18, 2011, 10:38:30 PM »
A vertical eight works good .It ordinarily cuts inverted after the outside loop,
and has enough inertia to come round level at 5 ft. If you get it right . ::) >:D
Offline ash
« Reply #7 on: April 19, 2011, 07:03:32 AM »
My current model runs a plastic clunk tank and muffler pressure, so I think maybe I won't try it just yet ;)
It's also really heavy, so tempting fate seems doubly risky.
