  • June 24, 2025, 06:59:29 PM
Author Topic: For the record; Mr. Ron O'Toole  (Read 2339 times)
« on: May 25, 2014, 04:24:23 AM »
 I was forwarded these extraordinary photos from about 1960 of Ron O'Toole and would like to enter them into the permanent digital record.  Thank you Ron and Jim Vornholt for sharing.
Re: For the record; Mr. Ron O'Toole
« Reply #1 on: May 25, 2014, 04:25:05 AM »
« Reply #2 on: May 25, 2014, 04:25:40 AM »
« Reply #3 on: May 25, 2014, 04:26:13 AM »
« Reply #4 on: May 25, 2014, 05:52:18 AM »
The body and gear location  looks a lot like the Aron. The wing is better looking than the Aron. Typical of 1959-1960. This is a very different plane than the Tucker that he is often seen with. The body is very thin in the back and he flows it all together beautifully. I have never seen this model before.
EddyR
« Reply #5 on: May 25, 2014, 06:08:01 PM »
I didn't know him but nice old pics, shows the sport runs deep.
« Reply #6 on: May 25, 2014, 07:46:08 PM »
 Cool old photos. y1
Eric Viglione
« Reply #7 on: May 25, 2014, 07:59:54 PM »
Great looking beamer, but what really got my attention was the tank vent arrangement and the looped silicon tubing. Things that make you go hmmmmm...
EricV
« Reply #8 on: May 25, 2014, 08:07:36 PM »
Keeps dirt out of the tank between flights.
« Reply #9 on: May 26, 2014, 12:05:24 AM »
EricV
 Like Doc says, the looped tube is just an easy way to keep things plugged, not for flying.
Eric Viglione
« Reply #10 on: May 26, 2014, 04:16:17 AM »
Well that is true in a lot of cases but isn't the only reason I've seen for this config. Maybe Doug Moon will see this and chime in. The other config I refer to loops the uniflow back into a neutral air space inside the fuselage to avoid directional pressure. You just break the loop to fuel up. That's why I was jesting about it, since the config would have been way ahead of its time.
« Reply #11 on: May 26, 2014, 05:52:48 AM »
I can remember when I was that age.... :'( .......... ;D Cool pics, thanx.
Offline Crist Rigotti
« Reply #12 on: May 26, 2014, 07:36:08 AM »
Ron is a cool guy to talk to.  Very nice man.
« Reply #13 on: May 26, 2014, 07:58:50 AM »
He sure is!
« Reply #14 on: May 26, 2014, 08:01:11 PM »
I don't know who he is but those pictures are classic. He makes control line look so cool!
Offline Doug Moon
« Reply #15 on: May 26, 2014, 09:53:29 PM »
He looks the same!!  I met him in late 90s and see him at the Nats often.  Great guy.  Very soft spoken and knows his stuff and loves CL!  His has the same slicked back look!  I wish I could say the same for mine... ;D ;D ;D
That tubing is very similar to how I run mine.  But I think he was doing that there.  He would need a pressure line from the non existent muffler to the tank. Then the vent and pressure line from the tank exit the side of the model.  You fill on the pressure line and the vent overflows. Then hook the two together and you have a closed system.  Works great. Been running it for years.
These old pics are great!!!!  Thanks!!
Doug Moon
AMA 496454
Dougmoon12@yahoo.com
