  • July 07, 2025, 11:20:45 AM
Author Topic: Follow-Up on current Fox 35s  (Read 1852 times)
Offline L0U CRANE
« on: June 19, 2006, 01:41:19 AM »
Occurred to me since the last post to an older thread about Fox 35s I'd reworked, that I omitted an important development that Larry Foster and 'some guy in Georgia' ;) came up with.
The Hi-Zoot Crankshaft...
Why? The stock Fox 35 shaft has a very thin - by current standards - crankdisk. Even with the slight thickening on the side opposite the crankpin, it doesn't have much metal to dampen the iron piston's movement vibration. Modern designs do have thicker, occasionally massive, crankdisks to provide that kind of 'flywheel damping.'
Larry and 'that guy' developed a way to machine away a segment of the lower crankdisk, and fill it with a heavier metal. I haven't run such a shaft yet, but have heard that it is very effective at reducing vibration from this source. A good part of the way to the vibration reduction from using an aluminum piston in chromed or nickeled sleeve...
And, since 'that guy' also sells Fox 35s fitted with a CNC Backplate, his own Hemi Head, ABC S&P, AND the Hi-Zoot shaft, that combination is most likely even better.
('that guy' - if you haven't made the connection by now, is Randy Smith. :D)
\BEST\LOU
Offline rustler
Re: Follow-Up on current Fox 35s
« Reply #1 on: June 19, 2006, 01:20:15 PM »
For loading a c'shaft by filling holes in the web opposite the c/pin, tungsten is mostly chosen. For a heavier and easier worked metal, our tame engine guru John Dixon has suggested Gold! Reckons for the small amounts actually needed, cost might not be prohibitive!
Ian Russell.
Offline wmiii
« Reply #2 on: June 19, 2006, 01:39:10 PM »
 Hey Lou, I suspect Randy will respond shortly. The Hi-Zoot crank is a
completely new crank, no drillin & fillin done atall. Randy drew it up had
them made to his spects. Your right in that they smooth out the run
quite nicely.
Walter
walter menges
« Reply #3 on: June 19, 2006, 02:55:50 PM »
Hi All
Walt is  correct  the HZ  crank is  NOT  a  machined  FOX product, it is a Brand NEW designed crank for the FOX 35 , and  has a bout  5 grams  more  effective countermass , which is  exaclty what the FOX 35 needed.
Also has  better  metal, harder, last longer, is  true and straight, and is  far far  harder  to  break
randy
Offline Lee Thiel
« Reply #4 on: June 19, 2006, 08:10:09 PM »
I run the crank and hemi head on my favorite Banshee.  What a differeince it make in the engine.  Wish I had more  to change them all over. y1
Lee TGD
AMA791773CD
