Hi Sparky,
That sounds like what Randy told me. He said his foam wing Katana was 1 oz. heavier than his built up wing Katana, all else equal.
BIG Bear
The numbers are in, I had a Viper wing from Viper 8 that was salvaged and I have my new Quickie wing out of foam. The quickie wing is 1 inch longer in span. (I have not figured out square inches) but basically the same size. The built up wing and the foam wing are finished (flaps-tips-controls) Built up is 15 ounces and the foam is 15.30. The built up wing has color and the foam one does not but both are covered and cleared.
First news I have heard of this issue. I have never built a bendy wing nor have I had one fold EVER
The only issues I have ever had is pilot error.
Read slowly! I never fail! This will not turn into a bash Sparky thread. You can take it elsewhere you do not make yourself look any better than you are.
Nobody said the plane failed.
Wasn't Viper 8 the one that had issues at the Nats with inconsistent corner because it was bending so much? Was that the light grey one?
I cleaned up some of this thread and I am trying to keep it informational. Foam wing in the build state is slightly heavier than built up. I can see in the finish state it might be lighter. The one area where it's way heavier is the wingtips.
How you can tell this for yourself is put the nose to you stomach and one hand on each side and roll it tip to tip. Do this on every plane and try to keep that inertia down.
My wing tips are approx. the same for both. Its just the volume of wood, glue and foam towards the tips.
It is still stiff and always was.
That's what my wife says..........
Exactly. This is the result of a larger 'radius of gyration', the same reason why a short nose with a heavy engine is easier to start/stop than a long nose with a light engine, given the same balance and everything else.
That might be so but it still feels like a brick in the nose. I would take the lighter version and longer nose.
Sparky, what do the tags do on the LE & TE of the outer templates?
How do you stop the templates from sliding around, giving you wash-in/out?
Sorry for the questions, just trying to learn is all.
There are some that sheet the foam first, THEN core it.....thinking being that more pressure can be put on the un-cored piece, with less distortion.
Windy built a light (especially for him) Cardinal for the Lincoln Nats, where he figured weight would be more critical because of the altitude, by sheeting a built-up framework.
That plane is going to look even better with the finish on it. I like it.
Al Rabe was also an advocate of fully-sheeted built-up wings. I did a few Noblers that way - once you get the LE and TE sheeting on, it takes only a little bit more to omit the capstrips and put on a full sheet. The big advantage is the weight saving in the finish, just like the foam wing.
