  • June 28, 2025, 06:39:48 PM
Author Topic: Typical Day in My Dad's Workshop (Tom Weedman is my daddy)  (Read 11975 times)
Offline Larry Fernandez
Re: Typical Day in My Dad's Workshop (Tom Weedman is my daddy)
« Reply #50 on: August 10, 2010, 05:12:02 PM »
Check out these photos Tom....BBBBUUUTEEEFUL model...for sure
WOW !!!!!!!!!!
WHAT A DROP DEAD, KNOCK OUT GORGEOUS PLANE !!!!!!!!!
 H^^ LL~ y1 >:D :## Z@@ZZZ
Larry, Buttafucco Stunt Team
Offline Will Davis
« Reply #51 on: August 10, 2010, 07:01:15 PM »
Tom,
What about the secret Weapon??.. Looks like a Vector..  , foam wing ,hollowed out.. etc.
Will
Will Davis
"Carolina Gang"
Offline tom_weedman
« Reply #52 on: August 10, 2010, 10:38:27 PM »
The Secret Weapon is my SV -23 Plus Pattern  master foam wing cut to SV 23 every thing else is Curt and Randy's stuff PA 61 powered super light no paint full components engine tank prop  42 oz
thanks Tom Weedman ama 63672
AMA 63672
Offline Thomas J. Weedman II
  • T.J. Weedman
« Reply #53 on: August 11, 2010, 06:09:33 AM »
hey dad told you someone would pick up on the SV-23 Plus haha
Offline Michael Massey
« Reply #54 on: August 11, 2010, 10:43:07 PM »
How about some more information on the wing jig.  Home made?  Details?  Anything would be of great interest.
Tx.
Eagle Point, Oregon
AMA 914713
« Reply #55 on: August 11, 2010, 11:22:11 PM »
Tx.
I looks a lot like the one Jim Snelson of CLC offered.
Big Bear
« Reply #56 on: August 11, 2010, 11:24:14 PM »
You are correct but PA 61 powered Thanks Matt Tom Weedman AMA 63672
Hi Tom,
Is it the 1970's version that had the.35 or the last one that was piped (and used the SV wing?)
Thanks!
« Reply #57 on: August 12, 2010, 08:27:22 AM »
Yes that is the wing jig peices that Jim Snelson sells at CLC.  The little sticker is at the top of the verticle leg.  If you follow his instructions it is very easy to use.  It takes time to set up.  I now have a 4 foot metal level that is as straight as I can get any thing that I had to buy to set up the rig.  If you check his site.  www.clcentral.com     You can see he is a family operation with a ton of Tom Morris stuff.  Remember his is still a working stiff. H^^
Offline tom_weedman
« Reply #58 on: August 12, 2010, 02:51:30 PM »
Tx.
[/quote The wing jig started out as A Control Line Central jig the leading edge blocks I had made they split in the middle so I can take the wing in or out with out having to set every thing back up
thanks TOM WEEDMAN AMA 63672
AMA 63672
Offline tom_weedman
« Reply #59 on: August 12, 2010, 02:55:31 PM »
Hi Tom,
Thanks!
1970s Version but with PA 61 SE
 Thanks Tom Weedman AMA 63672
AMA 63672
« Reply #60 on: August 12, 2010, 04:45:26 PM »
Thanks for the info all.
Eagle Point, Oregon
AMA 914713
