  • July 11, 2025, 01:36:03 PM
Author Topic: Flying palm up inverted  (Read 10795 times)
Online Paul Taylor
« on: March 11, 2025, 08:36:44 PM »
I learned to fly inverted palm up. I would like to try and fix that.
Or should I try and not try and teach an old dawg a new trick?
Am I asking for trouble?
Offline Dan Berry
Re: Flying palm up inverted
« Reply #1 on: March 11, 2025, 09:09:02 PM »
You just hafta work at it
« Reply #2 on: March 11, 2025, 09:26:42 PM »
It took me two years to get rid of the palms up habit, but it was worth it.  I still tilt a little.  The point is that you are no longer fighting the changes that occur from rotation speed.  I learned Palms Up when I was 12 and made the change to vertical when I was 75, so not quite an old dog.  Don't make the change at the start of a contest season! It takes serious concentration at first.  Start with the maneuvers.  Chances are you are going palm up on the squares as well.  I changed after it became apparent that I was not able to turn with the same even gate that I had as a kid in my 50's.  In my case it was worth it but, a lot of fliers do just fine with palms up.
« Reply #3 on: March 11, 2025, 10:52:40 PM »
   I never did that, but people tell me it is difficult. Just flying inverted that way is not terribly bad, but some people have to rotate their hand to follow the airplane through the maneuvers, and that can make it nearly impossible. That means, have their hand vertical through the inside part of a square 8, then rotate it palm up over the top of the outside part, straight again for the descending leg, the palm-up again for the bottom, vertical for the intersection, etc. It's actually painful to watch and I can't see how anyone can successfully complete a square 8 or hourglass doing that.
    There are a lot of these sorts of things people learn over the years, and some of them were actually helpful or necessary back with 4-2 break engines and mostly-out-of-trim airplanes. Now, it's hurting but it's a habit that is hard to break.
Online Paul Taylor
« Reply #4 on: March 12, 2025, 01:17:08 PM »
Ok I took an old FS and practiced this morning. I think it’s doable.
I really had to think about it. It took me 25+ years to learn this way nowI need to unlearn it. 🤪
« Reply #5 on: March 12, 2025, 01:49:44 PM »
       Yeah, keep this in mind!!  Be conscious of it for 3 or 4 flights and increase each session if you can. Then just finish out the session having fun! I didn't try to quit cold turkey and NOT fly inverted palm up any more but just worked at it. I'm about 1/2 to 3/4 oof the way to upright and still working on it!! I don't loose any sleep over it, though!!
Offline Doug Moon
« Reply #6 on: March 12, 2025, 06:27:09 PM »
I fly palm up inverted. I can still hear the guy who taught me 30+ years ago telling me "if you get scared just stop and the plane will turn over"  When I do outside rounds i just kind of keep it tilted at about 45 degrees or so then roll to upright as the plane comes out upright.  Where I think it hurts me is the RWO pullout to invented. I follow the path over the top so as the plane is coming down my palm is actually facing down and as I pull out inverted I snap my hand palm up for the inverted portion. If I don't think about it can usually get that maneuver pretty good but once i start focusing on it all hell breaks loose. I have been able to make it work but I sure would like to fix it.
I am building a profile maybe I will try it this summer.
Doug Moon
AMA 496454
Dougmoon12@yahoo.com
Offline Brian Hampton
« Reply #7 on: March 12, 2025, 06:50:26 PM »
I learned to fly inverted palm up because back then when I went inverted for even maybe a quarter of a lap I started to think of my hand as being attached to a joystick at the top of the model. This worked well for me as I slowly started extending the inverted flight until I was quite confident doing repetitive laps without thinking about that "joystick" any more. That was the start of beginning to build up muscle memory, although I didn't know that at the time. By the time I started to try squarish loops that muscle memory really helped. I guess what I'm trying to say is that, no matter if you learn to fly either palm up or not, then it's how you develop your own style of muscle memory. Trying to develop a different style is a great way to end up crashing :(.
« Reply #8 on: March 12, 2025, 07:21:29 PM »
I fly inverted palm up too with no problems. I tried it the other way but felt akward. I understand the thinking that if you don't track the plane well it will give you control input but it's so easy to track the plane it doesn't matter. When I do manuvers (square eight) my hand stays pretty much straight up. Go figure.
MM :)
« Reply #9 on: March 13, 2025, 02:59:11 AM »
« Reply #10 on: March 13, 2025, 11:05:48 AM »
To this old man it is what you get used to.   If you are flying really decent patterns, why worry?   I myself used to catch myself flying palm up during inverted portions of the pattern.    D>K
« Reply #11 on: March 13, 2025, 03:38:18 PM »
Never fell into the habit of palm up or down, but did tend to tilt the handle to about 10:30 (i.e., semi-palm DOWN) when flying inverted. I practiced NOT DOING THAT for a season, and eliminated the habit...I thought. The next Spring, it was back, so I had to practice not doing it "like deja vu all over again". The good news is that seemed to dispell the evil habit. I am very much against learning bad habits, because they're a beach to unlearn.  y1 Steve
« Reply #12 on: March 13, 2025, 04:04:15 PM »
Quite true.  I have finally gotten to the point that I can keep the handle vertical without thinking about it.  What helped me was making sure that I rolled slightly palm down coming off of the top of the inside.  By the time I was at 5' I was vertical.
What is really hard for me is rolling the handle once I am locked in at 5'.
Offline Douglas Bykoff
« Reply #13 on: March 15, 2025, 03:43:36 AM »
Look at this pilot here. He flies inverted with his palm facing down! Didn't anyone teach him how to fly acrobatics?
https://youtu.be/p7wwvS5GMP0?si=FM6mCsEETHoLeVbK
« Reply #14 on: March 15, 2025, 01:04:09 PM »
I think the objective of this thread is to suggest ways for Beginner fliers to avoid learning bad habits and young-ish fliers to consider correcting bad habits. AT LEAST, suggest that mentors/coaches not push the horizontal handle as the way to fly inverted laps. My bet is that Igor would probably NOT want to fly inverted with the handle other than vertical if it wasn't a long established habit.
The problem with having the handle horizontal is that any roughness in the footwork while rotating can affect inverted flight and score. At an Expert level, one point gained or lost can mean 1st vs. 3rd place trophy or none at all. When we can get Howard to make the trophies, it matters!   o2oP  Steve
« Last Edit: March 27, 2025, 11:12:14 PM by Steve Helmick »
« Reply #15 on: March 15, 2025, 05:16:19 PM »
I think the purpose of this thread is to suggest ways for Beginner fliers to avoid learning bad habits and young-ish fliers to consider correcting bad habits. AT LEAST, suggest that mentors/coaches do not suggest the horizontal handle as the way to fly inverted laps. My bet is that Igor would probably NOT want to fly inverted with the handle other than vertical if it wasn't a long established habit.
Yes,
I have been forcing myself to fly with my hand vertically for many years. I also try to teach two pilots that I am helping to fly with the handle in vertical.
When I watched Igor's videos a few years ago, I was immediately impressed when I saw him flying with his palm down.
I have the impression that this might help the model to tow in inverted maneuvers, but I once tried to imitate him and almost crashed my model.
I don't know any other pilot who does this, hence my admiration for him, not disdain for others.
Between flying with my palm up or down, I choose vertically.
Douglas.
Online John Skukalek
« Reply #16 on: March 15, 2025, 06:47:42 PM »
I learned to fly inverted with my palm down 35 years ago. It helped me because I focused on the front of my hand (the pinky finger side) being "up" and the trailing side of my hand (pointer finger side) being "down". I still fly that way today. Maybe I should try to change to upright/vertical for inverted flight.
« Reply #17 on: March 15, 2025, 07:20:27 PM »
     Have someone watch you as you do the maneuvers, if you are screwing your arm around trying to rotate the handle based on whether you are upside down or not, then, probably worth some consideration. Just doing it in stable inverted flight is not all that harmful.
« Reply #18 on: March 15, 2025, 07:57:41 PM »
I would like to put an age qualifier on that.  Once you start to lose your perfect balance and your gate gets less than smooth the palm up starts to produce some vertical drifting that will gradually get worse.  If you can get the handle vertical before geriatrics set in you can bobble a bit and still keep the plane level.
« Last Edit: March 16, 2025, 07:02:43 AM by Ken Culbertson »
Offline GERALD WIMMER
    • Auckland Free Flight Club
« Reply #19 on: March 16, 2025, 04:20:16 AM »
Hello
My youngest son Max is 15years old and after reading this discussion went out today with a mission to get his handle vertical.
He crashed the 09 sized diesel combat model many times and restarted the PAW09 himself and kept going till he felt he could see himself improving, I was impressed!
He had at one point got himself into a very weird position with his palm horizontal and over his left shoulder every time he flew inverted, this came about from watching one of our top combat flyers and coping him I think. Not a good set up for stunt but Max is keen on stunt and scale so wants to improve his flying.
Regards Gerald
Offline Doug Moon
« Reply #20 on: March 18, 2025, 03:09:50 PM »
Since mine looks the same as his I think this pic will re-enforce me to stick with what I got going.   ;D
Doug Moon
AMA 496454
Online Paul Taylor
« Reply #21 on: March 19, 2025, 01:10:10 PM »
Hello
Regards Gerald
Good to hear. Learn while he is young. I’m not sure I’ll get there.
« Reply #22 on: March 22, 2025, 12:24:14 PM »
I'm kinda tardy on this thread but just thought of a suggestion that might help illustrate the difference in success at contests of those who fly "upright" or "slanted sideways" grips when inverted or "maneuvering "!
This thought came to me as I reviued the previous inputs.
How many have won major CLPA contests while flying with entirely "upright" maneuver inputs---and how many have won major CLPA contests with vertical inside inputs but horizontal outside inputs?
My guess would be that most victories have been achieved with the "vertical" mode than via the "slanted path outside" mode.
I suspect that result would be true insofar as the vertical flight path accuracy of the slanted mode (in both level flight and during maneuvers) would result in more frequent "deviations" of desired tracks in both level flight and maneuvers as the ground based pilot "rotates" to follow the flight path of the maneuver.
Or not....I'd put myself in the "upright maneuver input" corner.
Ted
« Reply #23 on: March 22, 2025, 12:33:35 PM »
    We have a pilot of mutual acquiantance that was trying to rotate his hand flat or upright depending on the attitude of the airplane, normal when the airplane was upright or vertical, and flat when it was upside down. So, just doing a loop he started out vertical but had to rotate his entire arm over the right by the top, then vertical again by the bottom, over and over. Add to this his "relaxed" grip (which means that he also had to adjust the control input as he rotated his arm), it was completely impossible to reliably do even the simplest maneuvers. Square 8s were painful to watch, hand waving all over the place just to compensate for the various "requirements" of having his hand tilted sideways and making up for the effect it had on the control inputs.
    Same guy started working himself out of both the "relaxed grip" and arm-twisting, and when he manages it, he became a NATs-qualifier level pilot. When he can't manage it, it is back to being painful and his performance degenerates markedly.
« Reply #24 on: March 22, 2025, 03:56:01 PM »
   I never did fly palm up from the beginning. When I was learning to fly inverted I kept getting confused and crashed a lot. I thought about it, and decided to put my thumb on the top of the handle. That was the panic button. When I got inverted and started going down I pushed the panic button and half looped to upright. I kept doing that until I could make a full lap inverted. After a while it became natural to push for up inverted.
It works very well until you hook up your lines backwards and do not check before you release the plane. LOL. Am I the only one?
« Reply #25 on: March 22, 2025, 04:32:02 PM »
Yes, you are the only one.  LL~ LL~ LL~
« Reply #26 on: March 22, 2025, 05:28:49 PM »
Hi Jim.  I also do the thumb thing-even make my handles with a sort of thumb pad.   I haven't really thought about it much but I fly inverted with the handle canted that way around 15 degrees but nowhere near palm up.   One of my son in laws definitely flies palm up inverted and he is still in the intermediate stage so I'm going to try to help him straighten that up before it gets too ingrained.  I've sort of let it go being more concerned with keeping airplanes out of the ground.   I think changes like that can't be made real quickly.   Just being aware of it and slowly working to change it is the best bet.
« Reply #27 on: March 23, 2025, 02:08:04 PM »
 The problem I see with the "horizontal" grip inverted is that doing so demands that the pilot never allow the ship to exceed or fall behind the necessary relation  to keep the planes inverted flight nailed and true. If the inverted grip sags behind the "required" angel toward the ships leadout the down  leg will become an inputting unit and the level flight path will climb as the resulting handle input shortens and drives the elevators down making the ship climb and vice versa.  If, for instance, pilot stopped turning precisely in tune with path of the ship...or exfiltrated it...the pitch angle would change commensurately and the "level" path of the ship would wonder appropriately.
Put simply, any deviation from perfect and consistent alignment with the ship will result in an altitude deviation.  The vertical grip doesn't have that sensitive built in potential.  Without beating a dead horse I'd also suggest that any shift from horizontal to vertical  grip inputs during multiple content inside/outside maneuvers almost asks for deviations during the switch from inside to outsied inputs from the pilot.
In other words, that grip technique appears to me to add much potential room for distorted maneuvers than a traditional Up is Inside and Down is Outside!
Easy for me to say, I know.  I haven't flown a stunt ship now for longer than I care to try to remember.  Miss it a lot but all my ships hanging from walls and garage sealing are old as the hills and I expect every engine would have to be stripped down and recooperated before any chance of practicing my convictions could be accomplished!  None the less I demand the right to old geezers opinions.
Best to all who love to fly 'em on strings!
Ted
« Last Edit: March 23, 2025, 02:41:32 PM by Ted Fancher »
« Reply #28 on: March 23, 2025, 04:19:11 PM »
   How many of you ever watched Lew Woolard fly? He learned to fly the opposite of us. He pushed the top line to go up and pulled to go down. It would drive you crazy to watch him fly. He flew upright like we do inverted, and inverted like we do upright.
« Reply #29 on: March 23, 2025, 05:41:58 PM »
I've started to wonder if there's been some misinterpretation of the difference between palm up/down control so I just did a quick check on how I do it. I hold the handle with elbow bent to waist level and my wrist at a comfortable neutral feel so the handle was upright as in normal level flight. I made some marks on a cupboard wall to show the neutral position of the handle then another mark as though I was flying inverted by rotating my wrist palm up as far as it felt comfortable. Combining the two marks I measured the wrist rotation as 35 degrees.
« Reply #30 on: March 23, 2025, 11:20:34 PM »
   I remember seeing Lew fly that way the first time I saw him fly in person at an early VSC!! It occurred to me that I have seen at least a few people fly "reversed" with the handle horizontal all the time, and moving the handle to the right is "up" and so on!! One of my R/C soaring buddies asked to fly one of my C/L models years ago before I took stunt up really seriously, and let him take the handle from me in the circle. He about had a spaz attack!! he concentrated on just keeping it level until I could get the handle back from him and we got the airplane down in one piece, but it scared the daylights out of him!! He aske me why I had the handle backwards!! He said that the horizontal position was the way he learned to fly 1/2A stuff as a kid from someone!! I haven't seen anyone else fly like that , though, since the late, great Lew Woolard!!
« Reply #31 on: March 23, 2025, 11:45:43 PM »
I would never actually risk a plane doing that, but it actually is a very natural position.  I am lost though trying to find any advantage.
« Reply #32 on: March 27, 2025, 11:43:31 PM »
I've seen guys put their thumb on top of the handle and think it is a compensation for having a model that is harder to turn outsides...that light/heavy control input that Brett wrote about. I did it with one model, but shortly got it flying correctly and didn't need to do it thereafter. I see it as another one of those bad habits that should be avoided early on.
The last handle I've made (CF core from Arkady/Chris/Alan conglomeration) is shown in the two pictures and is intended to dissuade the thumb from finding its way to the top of the handle. It seems as though it works, as it is not at all comfortable to hold in any way not intended. It's also quite snug between the index and pinky fingers, per Ted's advice.
You'll notice that the holes are bushed with brass tubing, the finish isn't all that fancy (two coats of finishing epoxy), and the red stuff is rod handle wrap from Bass Pro Shops. It weighs 25 grams with the safety tether and no clips, IIRC. I don't notice the extra 10 grams on a .46/.60 sized model, but might on a smaller model/engine. I don't think the extra weight is due to the thumb control lump, but more balsa, epoxy and vinyl in general.  H^^ Steve
Offline Paul Van Dort
« Reply #33 on: March 28, 2025, 05:41:51 AM »
That is indeed true. When learning to fly inverted, there was a clear advantage for the "horizonal, palm up" grip .  When the plane get's too low for comfort, just stop turning in sync with it and it will go up. Easy save.
The main problem with inverted flying compared to upright is the fact that inverted flying with a vertical handle is an unstable situation. When the model climbs and is not corrected by giving more "up" the climbing will increase. Worse in the opposite case. When the model drops, "down" needs to be given to recover.  Terra firma is only 6 feet away. This effect is cancelled out by having the "horizontal" grip. What is worse? Difficult to say. But my habit is palm up...
Online EricV
« Reply #34 on: March 28, 2025, 06:44:04 AM »
When I learned to fly inverted as a kid, my mantra repeated in my head over and over as I flew inverted was "down is up, and up is expensive!" 😆  I also had decided well in advance that if I got in any trouble, like porposing inverted, I'd try and get down wind and my go to move was give down, not up, up was verboten. I've seen some try to climb and tuck it under and that usually ends in disaster for a newbie who inevitably does it up wind...you see some trying to do this dead stick when the motor cuts out inverted rather than just take your lumps and glide it in inverted... Oops, splat. A more experienced pilot might well wind fly it and flip it, but an overweight profile in the hands of a newbie isn't likely to survive. If these decisions are made well in advance, when it actually happens, you are much more likely to do the right thing.
I still stand by my earliest suggestions on these boards that the best way to teach inverted is to have them do lazy 8s and stretch them wider and wider with the handle vertical, until they can start holding a lap then multiple laps until they are comfortable.
EricV
« Reply #35 on: March 28, 2025, 07:26:58 AM »
EricV
As for the lazy 8's - :! y1
I think a lot of how you hold your hand is dependent on how you see the entire art of flying.  For example do you "see" the ground when you fly?  Is it your reference point or just part of the passing background?  Do you think "Up/Down" or "Inside/Outside".  Do you use you fingers or your wrist to make corners.  Do you squeeze the handle of cradle it? Do you trace with your arm or keep it fixed like the kid on the Ringmaster box.  Do you plant your feet and face a maneuver or just stop turning? Do you walk forwards or backwards or just pivot?  How do you feel the wind? (I am still trying to figure that one out).  All of these add up to style and you can find most all of them on the Walker Trophy.  What I think is important is to pick the style that maximizes YOUR performance, and it may not be the one you are using so, instead of defending what you do just because you do it that way, try some of the others. Old dogs can learn new tricks.  I have been walking forward since I returned.  A casual comment by another flier reminded me that back in the "You've got whip it to do it" days I walked backwards.  I wonder how long that one will take me to change.  LL~  End of morning soapbox.
PS - if you think we have a lot of "style" in our flying, watch some of the videos of the Japanese Nationals on YouTube.  We look like zombies next to them.
« Last Edit: March 29, 2025, 11:18:51 PM by Ken Culbertson »
Offline Dallas Moore
« Reply #36 on: March 29, 2025, 09:49:49 AM »
As an inexperienced flyer....
Why is palm up, or near palm up so bad?  It seems a good way to me to differentiate control when inverted.  I've watched videos of some very good fliers using this technique.
I have yet to fly inverted.  In other indeavers I've learned muscle memory, while great in many areas/times, can be disastrous in others.
« Reply #37 on: March 29, 2025, 08:23:08 PM »
.....I've learned muscle memory,....
As I mentioned back in reply#7, essentially all everyone is doing when first learning to do stunts is to start building up muscle memory, even though it's not realised at the time. It doesn't matter if it's palm up or not but whichever way it'll stay forever or until you try risking a model by reprogramming your muscle memory. For me, the moment I start the reverse wing over I switch to autopilot and then all I have to actually think about is where I am in the pattern and how I should do each manoeuvre as best as possible. That's where practice comes in.
Totally off topic I guess but another regime that uses muscle memory is my fascination with boogie piano. One of the worlds finest players (Stephan Ulbricht) was once asked how is left hand was so effortless. His answer was many years of practise and he didn't have to think about what his left hand was doing.
« Reply #38 on: March 29, 2025, 08:27:29 PM »
  It might help if you are just going to fly inverted, but it can be absolutely catastrophic doing more complex maneuvers. My example above was very revealing, the gentleman in question had to try to twist his arm around all over the place to make his hand upright or flat, depending on where he was in the square 8. This made/makes any attempt at precision hopeless.
     If you are only ever going to sport fly, and not compete, then, it doesn't matter too much. But if harbor notions of stunt competition, I strongly suggest that posture and handle setup is something that can, if you get too far off early in your career, you are going to have serious issues and make it all much harder on yourself. I have many examples of that, and several examples of "doing it right" from day one - including a sterling of someone who *never learned to do it wrong* going from not being able to fly inverted to being competitive in Advanced class stunt in 3-4 practice sessions.
    So, you learn something that helps and builds in bad habits to get through the first few hours without crashing, that then sets you up for a lifetime of fighting it. It's a classic example of people making something intrinsically simple into a complex mess.
   As an aside, the same thing applies to the engine and airplane as well, particularly trying to use vintage *engines* and trim ideas, and then spending months/years struggling.
« Last Edit: March 29, 2025, 08:55:35 PM by Brett Buck »
« Reply #39 on: March 30, 2025, 12:05:10 AM »
For me, the moment I start the reverse wing over I switch to autopilot and then all I have to actually think about is where I am in the pattern and how I should do each maneuver as best as possible.
Right now you are building muscle memory for one skill, flying inverted.  As Brian points out, by the time you have reached the advanced level the entire pattern will be one big maneuver that you will fly without ever thinking about it.
If you want to know how powerful muscle memory is, I laid out 30+ years while I started a business, raised a family, supported two national level athletes.  One day in 2017 I decided it was time and bought an ARF Nobler on E-Bay ($45 - disgusting) and dusted off the trusty OS35s in the attic.  First flight was a trim flight at a local contest with a handle I borrowed at the contest!  A trim disaster but a few tweaks and some tip weight and my second flight was an official 409 if I remember right (muscle memory is more reliable than actual memory at my age).  Virtually any expert flier could do that.  You don't forget, the muscle memory is that strong and since it is that strong think about how difficult it will be to change it.  Palm Up is a sugar cube.  It makes learning easier for sure, but I totally regret it now.
Online John Rist
« Reply #40 on: March 30, 2025, 08:32:55 AM »
I learned to fly around 1953.  After some initial help to get started I was pretty much on my own.  Not sure when I learned to fly inverted but it was on my own. I streached  a  lazy 8 until i was doing a full inverted lap.  never thought about a palm up while inverted.  I am wondering when the palm up thing creeped into control line world?   D>K
« Reply #41 on: March 30, 2025, 02:53:59 PM »
  Since we are on the topic, the two "habits" that I think are the most egregious are the "palm up" when inverted, and the "relaxed grip", with a forward bias at neutral. We beat the first to death above. The "relaxed grip" is almost always a function of being told to hold your arm straight and stiff, and only make control motions by moving your arm up and down. Again, this holds down on the carnage from over-controlling for the first few flights, but building in a bad habit - because you can't fly stunt by just moving your arm up and down.
Offline Kafin Noe’man
« Reply #42 on: April 12, 2025, 09:02:04 PM »
Hi let me jump in into the discussion.
I’ve tried so many times to fly inverted with the handle vertical but it often ended up with the plane bouncing back to the upright position immediately. When I managed to get a full lap or two inverted, it was hard for me to keep it level.
So then after so many trials, I decided to try flying that palm up inverted. Mine was like this /, so it wasn’t totaly horizontal. To my surprise, my inverted level was much nicer. I could hold it steady for like 5-6 laps before I got really dizzy then recovered into upright.
What should I do now?
Looking forward to hearing more.
Best,
Kafin
« Reply #43 on: April 12, 2025, 11:04:31 PM »
Best,
Kafin
   I think a lot of us tend to fly inverted like you just described. If you feel more comfortable that way and have had some success, I think the at this point just continue that way to build up experience and you can refine your technique as you progress through the pattern. Building flying time and repetitive flights is to your benefit overall instead of repairing airplanes.
« Last Edit: April 13, 2025, 09:51:43 AM by Dan McEntee »
« Reply #44 on: April 12, 2025, 11:39:28 PM »
Best,
Kafin
Best,
Kafin
Nothing, you are doing it.  You are not close to what I would call "palm up".  What I feel is important is that you do not get into the habit of rolling your wrist at points in the pattern when you need to make fast pitch changes.  The transition from the inside loops to inverted is not one of those.
