  • July 21, 2025, 12:42:18 AM
Author Topic: Flying Mood  (Read 1068 times)
Flying Mood
« on: September 08, 2007, 08:39:38 PM »
Well today, actually this evening I went to the flying field to do some flying/testing.
First up was the Cotton Candy with an OS FP35.  Started first  flight with normal setup of Windsor 11.5 X 4.5 prop.  Then I put the new Master Airscrew 10-4 three blade on.  After setting the needle  to a wet 2 stroke I started putting in full patterns.  The engine had a different sound to it, or maybe it was the prop.  After several flights(about 3 full patterns).  I went back original prop.  Will be trying the 3 blade on other engine/plane combos I have.  Maybe when the weather cools off a bit I may try the three blade on the Cotton Candy again.
Next up was the Skyray I have with an OS FS28 Surpass on it.  Bob Reeves sent me a prop for it.  Of course my tach decided not to work, dead battery.  First flight I must have been a little lean as it was cutting out while doing loops.  After opening the needle a couple of clicks it never missed a beat.  I had tried about a half dozen props on this bird before with undesirable results.  The prop Bob sent me is a wood 9-7.  I just need to quit over controlling now.  Will take care of that with the new Tom Morris handle i picked up at the NATS.
Anyway I had a good session at the field and am pleased.   I want to thank Bruce and Bob for their help.  Have fun,  DOC Holliday
