  • July 18, 2025, 06:00:10 AM
Author Topic: Older Robart Hinge Points - all plastic  (Read 952 times)
Offline Ian Hewitt
« on: December 15, 2021, 09:40:46 AM »
Hi Stunt Hangar,
I have discovered a stash of pretty old (30+ yrs?) Robart Hinge Points in my workshop. They are all plastic and 1/8" diameter - they feel good and free and I was tempted to try them in my Trophy Trainer having bought a Robart drill jig for the flap and elevator joiners (for which it is great). I notice that the current Robart hinges use steel pins - presumably for good reason..
I would be grateful for any advice on the virtues (or not) of using the older hinge points - must admit that I have now ordered some of the newer ones..  ..but have loads of the older type!
Thanks in advance
Ian
Nottingham, UK
Re: Older Robart Hinge Points - all plastic
« Reply #1 on: December 15, 2021, 11:34:45 AM »
Hi Stunt Hangar,
Thanks in advance
Ian
Nottingham, UK
If you are using pockets I would not hesitate to use them since replacing one would be simple.  Otherwise I am not so sure.  Is it a plastic pin or "snap on".  I don't remember ever seeing the full plastic ones and I use them on just about everything.
« Reply #2 on: December 15, 2021, 01:27:33 PM »
The Robart hinges with the plastic pins can and will fail with surprising little stress.  My recommendation is to avoid the hinges with the plastic pins.  If you have a choice, avoid the plastic pins and use the Robart hinges with the metal pins.
Offline Ian Hewitt
« Reply #3 on: December 15, 2021, 01:37:45 PM »
Many thanks for the clear replies.
It would be a shame and some considerable expense to lose a new model due to dodgy hinges.
They were part of a bundle of stuff that I acquired via EBay - this included some SIG 3" bellcranks in Mercury packaging - which must be well over 30 years ago..
I will not use the old hinges and wait on delivery of the newer steel pin versions.
I figured that this was the best place to find advice.
Thanks again
Ian
Offline Gerald Arana
« Reply #4 on: December 15, 2021, 06:50:53 PM »
Thanks again
Ian
Ian; since you have "lots" of them, you could throw away the ones with the plastic pins and use the ones with a hole in them. Put a wire full length and they will be removal!
Good luck, Jerry
« Reply #5 on: December 15, 2021, 07:12:21 PM »
 Donate them to your competition.  VD~
