I'm currently "bashing" an ARF Nobler kit and I need this dimension for reference. I failed to record this info prior to chopping off the stock wingtips...
On a stock Nobler, or the ARF, where
exactly does the front leadout cross the end wing rib? In other words, I need an accurate measurement from the wing L/E at the end rib back to where the leadout crosses that same rib.
Thanks!
