To the point of the Imitation fuse twisting. A very good and simple solution, and I've done this on two profiles. Make the balsa fuse outline from 1/2 inch balsa, with kind of a geodetic structure between the balsa fuse outline. Normal 1/2" balsa nose section, back to the high point of the wing. Install the 3/8" x 1/2" motor mounts, then sheet both sides of fuse with 1/64" plywood. Use a full sheet of 1/64" ply, both sides with grain running nose to tail. do not make the plywood diagonal, as this lets the fuse flex. Make a second 1/32" plywood doubler for both sides of the nose section back to the high point of the wing. Sheet the fuse then with 3/32" balsa both sides, from the high point of the wing to tail. Make 1/4" balsa doublers for the nose section back to the high point of the wing, both sides. On the tank side, cut out where the tank will be mounted. I made a filler on the front of the fuse to blend into the spinner, like the Pathfinder has. Sand the fuse round top and bottom. This makes a very, very stiff fuse and the total weight is satisfactory for our needs, 7 to 8.5 ounces. Normal silksapn and dope to finish. If you have seen any of Don Hutchinson plans, I pretty much copied his idea, only with the addition of the 1/64" ply. I think Tom Morris does that also on his profiles. Anyhow, just another thought to keep the fuse from twisting, especially with the low aspect ratio stab/elevator of the Imitation.
