General control line discussion => Open Forum => Topic started by: Paul Raley on June 09, 2025, 03:35:58 PM
Is it possible to launch a single wheel Flite Streak from grass with a stooge? Forty years ago we always hand launched our Flite Streaks. I am thinking that some bolt on aluminum two wheel landing gear may be a better option for me now since I mostly fly alone. I have had a Flite Streak ARF kit sitting around for years now but reading old posts about the magic combination of this with the OS 20 FP has me interested in putting in together. TIA
I've never liked a single center wheel design. Always tore up the outer wing tip covering or worse on simple landings.
Brodak sells both aluminum and wire gear for profile models. Or you can make your own using 1/8" music wire.
Thanks Colin!
I used the single wheel for years. I put a paper towel roll under the inboard wing and step back once it starts moving. I have had great luck with the sinegl wheel gear on rough crassy fields
Thanks Dave! That is good to know. So just put an empty (?) paper towel roll under the outside wing tip? Is the roll parallel to the fuselage?
Single wheel, full up elevator, release stooge, step back, and even T-square will go!
Jerry
I also fly alone quite a bit of the time.
2-wheel gear on my Streak. Plus, I have similar gear on both a Brodak Shark 402 and SIG Skyray 35, both kits originally designed for a single center wheel.
Just use 2 wheels and then don't worry about it. There are plenty of other things to worry about. Don't add landing gear to the list. :)
I have never messed with a single wheel and a stooge. It didn't seem reliable. I have used the landing gear from the Brodak 38 Special. It's a prefect fit. It is expensive though.
https://brodak.com/control-line-parts/landing-gear-1/38-special-landing-gear.html
That's a nice one.
Brodak also makes a more generic one for any profile model that uses 2 mounting bolts. (Not sure why it is a little more expensive.)
https://brodak.com/control-line-parts/landing-gear-1/landing-gear/aluminum-landing-gear/2-piece-landing-gear-for-profile-planes.html
That's a nice one.
Wow, does that price include shipping, installation and training? ~^
I have used single wheel gear on many planes. I usually put shop towel or rag on out board wing tip so it will slide off when plane moves. Remember to step back as you release the stooge. If grass is too rough I use a strip of carpet. It takes thought and patience to do it successfully. D>K
No put a full roll under the inboard wing to keep it up for the first 2 feet. then step back.
Let's not all forget that planes also need to land.
The minor wing tip damage to my past single wheel models occurred on the landing when the outer wing tip eventually drops and drags. Takeoffs were fine.
Ah...I understand. Thanks!
That would help. The biggest problem over grass letting the lines hit the grass and pull the nose in before you get tension. That is true of most everything but with the All American it is doubly important. Backing up and back like you were avoiding a vortex is all it takes. We mostly hand launched everything back then. It works for that too.
I am guessing back in the day when this plane was king you got originality points for takeoff! I was 16 and I learned the difference between walking around a circle with a plane on a string and *FLYING* on the AA. It will always have a place in my memories.
That's a nice one.
The landing gear that you suggest is somewhat bigger than the one used on the 38 Special. I have them both. The one that you suggest is good. it seems intended for Twister sized profiles and up. The 38 Special gear is smaller and better proportioned to a Flite Streak.
Usually a Flite Streak will hop off the ground in about six inches- or the first clump of grass it hits. Just hold your handle up about head high to launch and keep the lines off the ground. The other suggestions about laying something on the outboard wing or to prop up the inboard wing are good. Once it starts moving you shouldn't have any problems. Be sure the wind is at your back. With the engine, tank and tip weight all outboard the airplane should want to naturally fall outward anyway. If it doesn't then the wheel needs to be placed a bit more inboard. The idea of the single wheel was to save weight and drag. To some extent adding more stuff hanging from the bottom will change the vertical CG. If you are using a muffler that too aggravates that situation. In flying this might cause the airplane to go lighter on the lines for inside loops.
Not Flight Streaks, but in the late 70's I was flying various single-LG 1/2-A powered planes off of dirt (there was glass there, but it was mostly dirt).
If the grass is too thick, get a cheap throw rug to take off from. Six feet long ought to do it, and you can take it with you when you leave the field.
single wheels rule. RAD
