  • July 06, 2025, 10:14:35 PM
Author Topic: OS NVAs and Venturis  (Read 1071 times)
Offline Andrew Tinsley
« on: October 17, 2015, 09:30:17 AM »
Hello,
I was browsing the Tower Hobbies catalogue for 46LA needle valve assemblies and venturis, same for the 25LA items. They no longer seem to be listed, or they have been listed elsewhere. I note that under the 46 and 25 LA listings there are items for other OS engines including 4 strokes! Can anyne help on this topic or have these items ceased to be listed by OS?
Andrew.
BMFA Number 64862
Offline Perry Rose
Re: OS NVAs and Venturis
« Reply #1 on: October 17, 2015, 09:59:34 AM »
They don't have the LA series of engines and parts have been used up also. Check the vendor section for those who make the items you need.
Offline Don Chandler
« Reply #2 on: October 17, 2015, 10:01:18 AM »
I believe those engines have been taken of the market. Tom Dixon or Eric Rule may have what you need. I have  purchased these from both of them in the past.
Offline Dane Martin
  • heli pilot BHOR
« Reply #3 on: October 17, 2015, 10:05:24 AM »
On towers website, search for 22311000 os part number. That's the springy nva. Then scroll down and all the venturis and other types of spray bars and stuff. It will be listed as related items.
 Tower lists all these parts as for FP series engines. That's probably why you're not finding them as LA parts.
Hope that helps
Offline Dennis Moritz
« Reply #4 on: October 17, 2015, 12:34:09 PM »
They're FP needles. LAs used remote.
Offline Geoff Goodworth
« Reply #5 on: October 17, 2015, 04:28:31 PM »
The NVA is NVA 20-25FP-S   LXCR49   13.49   22311000
The large venturi (7.1mm ID) is FP 40 Venturi   LXCX05   11.99   23312000
The 20/25 venturi (6.55mm ID) is FP 20/25 Venturi   LXCW99     9.49   22312000
« Reply #6 on: October 18, 2015, 06:57:08 AM »
Thanks Geoff
Just one more thing is there a larger NVA that went with the FP 40?
Thanks again,
Andrew.
BMFA Number 64862
Offline Jay
  • 1 Cross +3 Nails= 4 Given
« Reply #7 on: October 18, 2015, 08:49:31 AM »
Go to www.rcjapan.com they will have both the nva and the venturi you are looking for. They convert your money to Yen which makes it a very good deal.  Only problem is the shipping.  Get some backups or go together with your buds.
Hope this helps
Jay
My religion consists of a humble admiration of the illimitable superior spirit who reveals himself in the slight details we are able to perceive with our frail and feeble mind.
Albert Einstein
  278622
