I got out today to fly. It's been a while, so I thought I would try out my new unflown planes. The flapped Magician flew very well with the McCoy 40, pretty much like the last three that I built. The surprise was the flapped Sterling S-2 Mustang, with a Fox 35. It flew really well, and the Fox ran without a burp. It is an older 70's model Fox, but it ran very steady from beginning to end. I was running it on uniflow with a 10-6 Revup prop. The plane flew well, but did have the outboard wing low upright, and high inverted, as expected, since it is a low wing. The real surprise was that it would not stall. I flew it through inside and outside squares, and triangles. I was banging the corners really hard, and not so much as a bobble. The wing being high inverted did not seem to affect line tension, but the plane was flying fairly fast. I am glad I built it with moveable flaps, even though it will cost me 10 points in Old Time. It is just a blast to fly a copy of a plane that I built and flew back in the 60's. I may try the boiling water towel trick on the wing, and see if I can get it to fly a little more level. It is covered with silk and dope, so maybe I can tweek it a little, or not.
