  • June 18, 2025, 07:01:51 PM
Author Topic: Identify this muffler please?  (Read 1563 times)
« on: April 22, 2020, 09:38:33 AM »
I'm almost positive it's a FOX but I just want to be sure.
I don't want to misrepresent the item when I offer it for sale.
Thanks in advance.
Offline Robert Zambelli
Re: Identify this muffler please?
« Reply #1 on: April 22, 2020, 10:21:57 AM »
Hi, Charles.
Yes, I'm pretty sure it's for a Fox.
« Reply #2 on: April 22, 2020, 10:31:46 AM »
Hi, Charles.
Thank you.
What car is that you have up, it's small and I cannot see it well?
CB
Offline Perry Rose
« Reply #3 on: April 22, 2020, 10:48:46 AM »
Looks like a Fox .40.
« Reply #4 on: April 22, 2020, 02:15:26 PM »
Thank you.
CB
1967  Ferrari 330 GTC.
« Reply #5 on: April 22, 2020, 03:35:23 PM »
Are you the owner of that treasure?
« Reply #6 on: April 22, 2020, 04:15:39 PM »
Yes!
Bought it on November 8th, 1975.
My birthday gift from me to me!
« Reply #7 on: April 22, 2020, 06:20:14 PM »
Yes!
Congratulations!
Offline 944_Jim
« Reply #8 on: April 22, 2020, 06:32:56 PM »
Here is a Fox .35 bearing a very similar muffler. The mounting bolts are about 38mm center-to-center. More measurements can be taken if needed.
« Reply #9 on: April 22, 2020, 06:41:08 PM »
Yes,
I'm convinced it's a FOX, same construction different footprint.
I'll post the whole spread measurement when I put it up for sale.
CB
« Reply #10 on: April 23, 2020, 01:13:09 AM »
Could be a Faux Fox. I've never owned a Fox muffler, but I've seen them. Mostly used on OS FP/LA .35 > .46, or K&B .40's. The bolt patterns are close enough due to the 4-40 bolts vs. the 3mm bolts. The one Avaio has could be for one of the later bb .19/.25 cases.  y1 Steve
Offline Perry Rose
« Reply #11 on: April 23, 2020, 05:23:43 AM »
If the bolt hole spacing is 1.0625 +_ a foot ,in Fox talk, and the opening is 5/8 x 1/4 it will fit the .40.
« Reply #12 on: April 23, 2020, 01:53:08 PM »
Comparing the picture from Avaio and 944_Jim, and the fact that the latest .19/.25 would have (?) to adapt to both side and rear exhaust configuration, I'm thinking it's more likely for a 6 bolt backplate Fox .15...at least, I think they had 6 bolts...the tall backplate variety, anyway.   D>K  Steve
Offline Peter in Fairfax, VA
« Reply #13 on: April 23, 2020, 01:56:49 PM »
My first thought was late model Fox .25, though c-c measurement is the way to get an answer.
Btw, Schnuerle .15 has a tall backplate, correct, four holes.  The 36 Combat Special, six.
Offline BillP
« Reply #14 on: April 23, 2020, 02:47:25 PM »
Last square back plate plain bushing Fox 25 and Fox 35 share the same muffler. Probably fits the same era square bp .19 too.
Last 45, 46 & 50 same
Last 60 & 74 same.
Bill P.
Offline 944_Jim
« Reply #15 on: April 23, 2020, 04:21:29 PM »
I thought this was a model airplane site, not a furriers site.
Bwahahaha...sorry, it just popped out!
Offline Phil Spillman
« Reply #16 on: April 23, 2020, 04:32:00 PM »
Yes I too believe that these are for Fox .40 engines; one is a tilt up and the other is a tilt down two different designs both very effective.
Phil Spillman
Phil Spillman
