  • July 19, 2025, 08:33:31 AM
Author Topic: Fixed Fazer plans and dimensions  (Read 541 times)
« on: July 06, 2020, 06:51:44 PM »
Some of you had questions about the changes I made to the Sig Fazer kit to get to my "Fixed Fazer".
I managed to find the Fazer plans I marked up.  For those of you who have the kit, compare your plans to the mark-up plans and the dimensions below and that should give you a pretty good idea of what needs to change (everything!!)  Unfortunately, I did not mark up the wing on these plans, but I kept about the same span of 48 inches and added nicely shaped tips to give about a 54 inch span.
Note multiple areas of "white out"..... ;D
In the picture of the plans with a ruler set on the front of the nose ring, here are the dimensions:
- to wing L.E. = 9.5"
- to wing T.E. = 19.25"
- to flap T.E. = 22.5"
- to stab L.E. = 32.25" (yes, the plans with ruler differ, but this is the correct dimension)
- to stab T.E. = 35.25"
- to elev T.E. = 38.25"
- to tail end = 39"
Stab span = 24"
stab chord at tip = 2"
elev chord at tip = 2"
fin height at rudder hingeline = 6" (see note, below)
C/L of wing is 1/2" below C/L of motor mounts
C/L of stab is 3/4" above C/L of engine mounts
Wing and flaps are tapered, I hadn't marked down and don't recall the tip chord dimensions.  Just use what is reasonable.
Note on elevator: the Fixed Fazer started out with a 6" tall rudder, but then one day John decided he didn't want to kneel down to launch the plane and instead pinched the rudder.  He pinched it too hard!  So when I later had an accident and was making repairs, I amputated the top 1 inch of John's handi-work....
Offline Peter in Fairfax, VA
Re: Fixed Fazer plans and dimensions
« Reply #1 on: July 07, 2020, 10:24:44 AM »
Scott,
Do the plans show a solid or hollow fuse?  The wreck looks hollow.
I think I know know why it is called the "Fixed Fazer."  That's because you fixed the original design to make it more to your liking, correct?
thanks,
Peter
« Reply #2 on: July 07, 2020, 11:25:58 AM »
Scott,
thanks,
Peter
It was so long ago I don't recall if it was solid or hollow.  I think if I were to build one again, it would be hollow.
Bingo on the name!!
