General control line discussion => Open Forum => Topic started by: John Rakes on July 02, 2006, 07:03:57 PM
Title: First flights with Vector 40 ARC.
Post by: John Rakes on July 02, 2006, 07:03:57 PM
Put up 5 flights today with my new Vector. After the first flight I moved the leadouts back about 1/8 inch. After the second I added 1/4oz to the wing tip and another 1/8 back on the leadouts. Total wing tip weight is 1oz. This was one of the first planes I have had where the wings looked proportional to each other upright and inverted.  No flap tweaks were needed. The next three flights I did the entire pattern without any problems.
The set up I have now is LA 40 Dixon mod, 11x5 APC prop. Brodak handle with 64 ft/15 lines. Used 15% nitro/20% castor. Next flight I will try 10% nitro/20% castor. Even on the long lines, the planes felt quick with no real break into 2 stroke at all. The 4.5 Magnum tank is plenty big with guaranteed over runs. I will cut that back even more using 10% nitro not 15%. The Brodak covering held up great with only a 3 inch wrinkle on the outboard fuse side.  I figure a dozen flights this ARC should be deadly for anyone to use.
Title: Re: First flights with Vector 40 ARC.
Post by: Bill Little on July 02, 2006, 07:21:44 PM
Hi John,
Glad to hear that the Vector is working so well!  Keep practicing and whoop up on them at the NATS.  y1
Bill <><
Post by: John Tate on July 02, 2006, 09:19:02 PM
John.
Keep up the good work.
I launched Willis Swindell's Vector a bunch today.
It was kinda windy here in Norfolk.  Willis made some adjustments.
The Vector looks like a great airplane to have.
John Tate
