  • June 18, 2025, 05:53:44 AM
Author Topic: Plane flattens the ground  (Read 3688 times)
« on: April 20, 2014, 03:46:51 PM »
This plane does not stunt very well but sure smoothed out our circle.
Thanks Lou!
Offline Will Davis
Re: Plane flattens the ground
« Reply #1 on: April 20, 2014, 04:13:11 PM »
Should have used a hard point handle.....
Will Davis
"Carolina Gang"
Offline 55chevr
« Reply #2 on: April 20, 2014, 05:00:36 PM »
If you used a U-Reely, you could have expanded the circle diameter.
Joe Daly
Online Dan Berry
« Reply #3 on: April 20, 2014, 06:54:29 PM »
Is that a 'nitro' engine on that thing?
Offline Gene O'Keefe
« Reply #4 on: April 20, 2014, 07:11:56 PM »
Must be a Dyna jet --- no prop !
Gene O'Keefe
AMA 28386
Offline Zuriel Armstrong
« Reply #5 on: April 20, 2014, 08:38:55 PM »
I see you've gone diesel. The pilot detail looks kind of fake btw >:D
Zuriel Armstrong
AMA 20932
« Reply #6 on: April 21, 2014, 09:55:41 AM »
No wonder it wouldn't get air borne.  Not enough wing area.   That is a good shot though.
Offline Larry Fruits
« Reply #7 on: April 21, 2014, 12:32:08 PM »
Paul,
 Nice "scale" entry. Now all you need is documentation. LL~ LL~ LL~
 Larry
Offline Brian Massey
    • California Car Clubs
« Reply #8 on: April 21, 2014, 01:50:21 PM »
I'm sorry, but using lines that are so hard to see is why they get stepped on and kinked. You really should start using more visible lines as a precaution.
I'm here to help.
Brian
AMA 55421
Madera, CA
« Reply #9 on: April 21, 2014, 02:52:28 PM »
Spider wire is very hard to see.
I agree more wing area needed.
And yes we may cross over and do scale. The pilot may need a make over. 😜
« Reply #10 on: April 21, 2014, 03:42:11 PM »
It will never fly draging the stooge.
« Reply #11 on: April 21, 2014, 03:49:32 PM »
Oh so that third line was to release the stoog? LL~
« Reply #12 on: April 21, 2014, 05:15:42 PM »
I see the before pic...wheres the after??? ??? Y'all got a lot of hay left...I only have one bale. Me and the three dogs got caught in a thunderstorm and spent a bout an hour in the hay barn. LOL
« Reply #13 on: April 21, 2014, 08:20:18 PM »
John, that makes me think of the aroma of fresh mown hay and also the smell of it when I would get in the loft to push some down to the cows.
« Reply #14 on: April 22, 2014, 07:10:05 AM »
Here's an item I built especially for my flying fields and lawns...it can be filled with water to add penetration:
« Reply #15 on: April 22, 2014, 01:32:45 PM »
Here's the work I've been doing to increase the diameter of this field to 100' :
