Ken I think no one is buying the idea of a first flight, or are we? The video is nice and clear.I will give him the benefit of the doubt. I did squares with my new twister last week on it's first flight on a 30 second trim setting, warp and all. You gotta be a bit crazy to do what we do anyway so why not a pattern. He did skip the one thing you never do first with an untested plane - the wingover.
I will give him the benefit of the doubt. I did squares with my new twister last week on it's first flight on a 30 second trim setting, warp and all. You gotta be a bit crazy to do what we do anyway so why not a pattern. He did skip the one thing you never do first with an untested plane - the wingover.Ok, being a rookie I must ask. Why, if the other maneuvers are ok to try (assuming things are feeling correct), is the wing over taboo on the first flight?
Gary
Ok, being a rookie I must ask. Why, if the other maneuvers are ok to try (assuming things are feeling correct), is the wing over taboo on the first flight?#1 you don't know how it will turn or what it will do when it turns. #2 You don't know if the tip weight is in range to overcome the line inertia. #3 you don't know if the engine/tank is right. Couple of tight loops and a lap inverted and you know all of the above are in range. It may look easy when done by an expert like Sparky but the 1st turn of the wingover is the most dangerous turn in the entire pattern.
Gary
