  • July 19, 2025, 05:16:18 PM
Author Topic: trim help needed  (Read 1229 times)
Offline Glenn Quarles
trim help needed
« on: March 17, 2015, 07:01:45 PM »
Friends, I flew my 1/2A Waco yesterday and it acted completely different than the one I built a few years ago. My problem is that the plane flies VERY nose out. The plane is built exactly per the instructions with the lead outs as shown on the plans, about 1/4" rudder offset and I had one thin washer under the front engine mounting bolts for some out thrust. After the first flight I removed the washer to set the motor straight ahead and it didn't help any (not enough to tell anyway). So my question is on what should I do next, move the lead outs forward or get rid of some rudder offset, or both.
Any help will be appreciated!
Glenn
Live in such a way that those who know you, but don't know God will come to know God because they know you.
Re: trim help needed
« Reply #1 on: March 17, 2015, 07:29:28 PM »
I'd lose the rudder first.  Are the leadouts adjustable?
Offline Akihiro Danjo
« Reply #2 on: March 17, 2015, 07:32:45 PM »
Have you checked out the C/G location? It may be too far forward.
Aki
« Reply #3 on: March 17, 2015, 07:33:56 PM »
Hi Tim, no the lead outs are not adjustable, but it would be easy to do.
Glenn
Offline Ron Cribbs
« Reply #4 on: March 17, 2015, 07:37:07 PM »
Sounds like a leadout issue. By nose out do you mean yaw? Can you see both LG wheels during flight?
« Reply #5 on: March 17, 2015, 07:39:39 PM »
Aki
Hi Aki, yes it is a slight bit nose heavy. I was gonna add a bit of tail weight before the next flight, but I didn't  think about it helping the nose out problem.
Thanks!
Glenn
« Reply #6 on: March 17, 2015, 07:43:25 PM »
Ron, yes it is yaw. There is no landing gear, but yes the outboard wingtips are  visible well behind the inboard.
Glenn
« Reply #7 on: March 17, 2015, 07:58:40 PM »
I'd lose the rudder offset and make the leadouts adjustable.  Adjustable leadouts on a 1/2A is a bit overboard, but what the hey.
The CG issue is probably a productive line of inquiry, but I suspect it's not the whole answer.
« Reply #8 on: March 17, 2015, 08:03:46 PM »
How much should I move the lead outs? Is there a general rule of thumb for leadout position relative to the bellcrank? Right now the rear leadout is about even with it's position on the bellcrank and the front leadout is about even with the pivot point on the bellcrank.
Glenn
« Reply #9 on: March 17, 2015, 09:42:10 PM »
 Leadout location is a function of CG, not bellcrank position.  You can use this to get close: http://www.tulsacl.com/Linelll.html .
« Reply #10 on: March 17, 2015, 10:00:01 PM »
The only general rule for leadout position vs. bellcrank is that if the leadouts have a severe bend at the leadout guide, then friction will be increased.
That, however, isn't a big problem unless the bellcrank is absurdly placed.
Set the leadouts correctly with respect to the CG, and you'll be a happy camper.
« Reply #11 on: March 18, 2015, 07:11:29 AM »
Awesome! Thanks for the help guys!
Glenn
« Reply #12 on: March 18, 2015, 10:40:56 AM »
If the CG is spot on, hang the plane by the lead outs.   That will tell you if you need to move them or not.
« Reply #13 on: March 18, 2015, 11:59:05 AM »
With the airplane hung by the leadouts on one hook the fuselage should hang nose down 1-2 degrees.  The bellcrank location is not important.
