  • July 19, 2025, 05:11:32 PM
Author Topic: Finally....First Full Stunt Pattern in 2015  (Read 8678 times)
« on: March 15, 2015, 12:30:30 PM »
Whew......it has been since the Carolina Criterium Contest this past October that I have flown the full stunt pattern. Got out on a windy day a couple of days ago and finally got a full pattern in on my Prowler with the OS .40FP.
It felt so good to get through it. I can see the work I need to do to tighten up and all but just getting throughit makes a feller feel alive I say...alive.
Just putting this up for any of you that need a distraction or maybe even inspiration to get out and grab a handle and fly, fly. fly.
Offline Peter Walker
  • Dadda
Re: Finally....First Full Stunt Pattern in 2015
« Reply #1 on: March 15, 2015, 01:11:22 PM »
Well done Shug, you make it look so easy man. Reckon I am just gonna have to practice harder, and more often.
You never know what is around the corner.
« Reply #2 on: March 15, 2015, 02:15:09 PM »
Hey Peter.....flying the pattern has truly helped my focus issues. Lock in and try to do it right is on my mind.
« Reply #3 on: March 16, 2015, 10:22:40 AM »
Looks pretty good but one little (OK a couple) constructive comments. May be camera perspective, but it looks like your overhead eights are low and in front of you rather than straight overhead. Your first loop has to start at absolute vertical to set up the rest of the maneuver, don't rush it and keep them the same size. You're flying your maneuvers large which is OK while you tune it up, but can cost you points, flying the vertical 8 and hourglass the tops both looked like they were behind you. Just trying to help.
Oh yeah, looks like that airplane turns very well.
« Last Edit: March 16, 2015, 02:35:11 PM by Randy Ryan »
Offline Gerald Arana
« Reply #4 on: March 16, 2015, 12:08:59 PM »
Shug,
Great! I liked your video. Its VERY nice to see the plane moving and NOT the back ground.  y1
Keep up the good work.
Cheers Mate, Jerry
« Reply #5 on: March 16, 2015, 06:49:02 PM »
I agree with you. Though the camera angle makes it look worse. I do cheat those tops a bit behind me and will until I find the groove I am working hard to get. Got out today for a session too. Working on getting a decent engine run and timing my fuel. Still getting a cut out on the cloverleaf every third flight or so. So much to work on.
Thanks for taking time to critique me.
Video helps me see all my mistakes but success too.
Todays flight.....
Shug,
Cheers Mate, Jerry
Thanks. A bit of this, a bit of that.
Thanks for watching it.
Offline Ron Cribbs
« Reply #6 on: March 16, 2015, 07:24:32 PM »
Shug.
Until you compete, it's all practice and good fun. Great video as always!
I appreciate all the time it takes to set those things up and I enjoy watching the good flying.
Ron
« Reply #7 on: March 16, 2015, 07:35:45 PM »
Shug.
Ron
Yessir...boning up for a contest in June. And hopefully October too.
I apreciate you eyeballing the videos.
« Reply #8 on: March 17, 2015, 12:58:17 PM »
Shug, watched the video and it looked like extra laps on the inverted portion also some extra squares.   Once you have the needle set the way you want it, do the pattern the same time after time with what ever corrections that need to be made.   When I was in the zone, so to speak, I could count ten laps after the clover and set up for landing.  Yes sometimes it might be 8 laps or even 12 laps, but I knew when to get ready for the hard part, the landing.  The easiest maneuvers are the ones we usually give away points on.   I remember the late Allen Brickhause telling me over head 8's were great, but the rest of the pattern sucked.   And as I have said before keep the videos coming. H^^
« Reply #9 on: March 17, 2015, 03:36:52 PM »
I took a bit of an artistic license on laps for practice sake....there were no judges there. Just on here.... ~>
Just getting the moves in a row I reckon.
Thankee Doc.
Offline Martin Quartim
    • StuntHobby
« Reply #10 on: March 17, 2015, 06:59:27 PM »
Good Show!
Martin
« Reply #11 on: March 17, 2015, 08:09:33 PM »
Thankee Doc.
At some point you'll want to stop doing that.  Probably after the first time you miss out on your pattern points at a contest.
I always do an extra level lap, both upright and inverted.  I didn't used to -- then I missed out on my pattern points at a contest...
Offline Mike Keville
« Reply #12 on: March 17, 2015, 09:09:33 PM »
At some point you'll want to stop doing that.  Probably after the first time you miss out on your pattern points at a contest...
Agreed!  Fly each flight as if you're being judged.  (Don't ask how I found that out!)
« Reply #13 on: March 17, 2015, 09:36:11 PM »
And fly every part of the pattern as if it were judged, too -- judges try not to grade you down for wingwazzles when you should be doing level laps between maneuvers, but why bring up the issue?
« Reply #14 on: March 18, 2015, 08:05:07 AM »
Good Show!
Martin
Big thankee Martin.
I'll get there. Normally we would not even be out flying in Minnesota but Global Warming is working in our favor this year.
Thanks.
Hey....all my judges are right on here))))
May get out today and will straighten it all out.
Thankee
Keep it real....right?
