I always "deburr" them with some 400 grit wet & dry, not enough to round the edge but to remove the fine sharp mold flash that is like a razor. I have heard people advise against it saying it will effect the efficiency of the prop but in reality I don't believe anyone could begin to tell the difference.
Man O Man, just GREAT! Makes my day when I can find a modeler that I can AGREE with!
I even flip some .60-.75 and .90 machines, especially if recently warmed up. Hold blade and turn for the "BUMP", flip and off it generally starts fine. However no matter the prop, it gets a sanding on the back edge. I have never done one that has reduces ability to fly the machine, enough for me to tell.
Back in the late '70s to mid '80s when I did some pylon racing, Quarter Midget, Sport, Q-500, and Scale War Bird, I worked on props a lot especially for 1/4 midget and Q-500. Make a good one and the next one just like it would be horrible.
Guys if you are short on experience with props, I suggest you balance and get rid of those razor-like trailing edges. It ain't pretty when they have to cut off your ring to get to the flesh to sew it up while the doctor, a former RCer, asks why you stick your hand in the prop.
Had it not been for that ring I would probably have lost two fingers, but the ring caused the APC to break at the hub, killing the 1.20 4 stroke.
I or you could ask why I was so stupid, but I cannot find a good answer. Stuff happens. Ya''ll do be careful and do prepare for out thar' on the flight line.
