  • July 09, 2025, 02:47:53 PM
Author Topic: New 77 Stunt engine  (Read 3157 times)
New 77 Stunt engine
« on: September 16, 2016, 09:25:50 AM »
I am now selling the K-77 RE  ABC  stunt engine, these are a rear Ex stunt engine for pipe runs, We will have a Rear ex full muffler  and a  Header muffler soon
Please call or email for info
Randy Smith  678 407 9376  Randyaero@msn.com
Offline Allan Perret
  • Proverbs
Re: New 77 Stunt engine
« Reply #1 on: September 16, 2016, 04:06:13 PM »
So how does the K77 compare to your PA75 weight wise, about the same ?
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #2 on: September 16, 2016, 05:05:59 PM »
I'd say it looks like about 375 grams with muffler.
« Reply #3 on: September 16, 2016, 07:04:19 PM »
It was originally advertised by Kaz MInato who was instrumental in getting them built, as weighing .5 oz less that the PA 75.  However on my scale mine weighs .41 oz less than my PA75.  Close enough I guess but not really any serious consideration in my book
I would add that while I haven't flown mine yet it is slated for and installed in and airplane that is about two or three weeks away from flying.
I have run it on the bench through about 8 6oz tanks of fuel.  Actually it ran very steady from the first run on 15% nitro (remember I live in Tucson AZ and it was hot), with 20% half castor and half Klotz.  It is an easy starter, needles easily and runs with authority on a 13-5 APC prop.  I also ran it with a 13-5 three blade Medjlik carbon prop and it turned it the same RPM at nearly the same needle setting as the 13-5 APC.  9600 RPM in a medium fast 4 cycle.  I believe it really didn't need very much breakin because it ran very steady and the needle setting required only a tweak during the first run only to maintain the same RPM till the tank ran dry.  Actually the first two runs were accomplished in three minute cycles of running and then cooling but the fit of this engine appears to be so good that it really seemed unnecessary.  I did it anyway.
The last 2 6 oz runs were accomplished with a Randy Smith PA75 pipe and the engine handled the pipe very well at nearly the same RPM.  I didn't try to adjust the pipe setting to be ideal because that will change a bit in the air as the engine unloads a bit.. I used a pipe length of 18.25 inches and it ran good.  RPM didn't change appreciably from beginning to end of tank.  No pipe pressure which I probably will install and use when installed in the airplane.
The first runs were accomplished using the muffler supplied with the engine (extra cost) and although it ran and handled very well and was very quiet it seemed to be a bit more powerful and smoother on the pipe but that's really only opinion as none of the visible factors etc really changed significantly (except the noise of course the pipe was significantly louder according to my neighbor).  Oh yeah, it ran for 6 min 40 seconds on the muffler with 6 oz of fuel and 6 minutes 10 seconds on the pipe at a slightly richer (only a small tweak on the needle), on the same tank!
In my opinion this engine may be the equal of the PA75 (actually that's what it was designed to be according to Kaz).  I think that in itself is a great recommendation because in my opinion the PA65 and PA75 come very close to being perfect.
My PA75 does use a bit more fuel but it also has a larger venturi.
Oh yeah, It's also Very Purty !
PS:  It uses the same header pipe as the PA75 and can be mounted in the same mounting holes!
« Last Edit: September 16, 2016, 07:21:29 PM by Randy Cuberly »
Offline Louis Rankin
« Reply #4 on: September 16, 2016, 08:00:35 PM »
Price?
Louis Rankin
Somerville Tennessee
AMA 10859
« Reply #5 on: September 16, 2016, 08:01:33 PM »
It is about  14 grams lighter, it has a smaller crank, 1/4 x 28  the PA 75 has a 5/16 inch thick crank at the threads
It sales  for  399 each
« Last Edit: September 17, 2016, 12:55:50 PM by RandySmith »
Offline frank williams
« Reply #6 on: September 18, 2016, 03:12:45 PM »
I have one I've been running ~ 2 gals of flying.  It runs great.  I've run it on a 12x5 four blade.  Runs just like a PA75.  Back in July I flew it back to back in the same plane .... no difference.  Only downside is that the needle is located through the venturi rather than in a sprinkler mode.  This makes the needle location a slight bit different than the PA.  A good motor.  The majority of the running I did was piped.  Just a little with the muffler.  Muffler may not be exactly the right volume, but its a nice looking piece of hardware.
