  • August 01, 2025, 03:32:09 AM
Author Topic: Wing protectors?  (Read 2635 times)
Offline Chris Fretz
Wing protectors?
« on: March 19, 2019, 06:55:12 PM »
Anyone using some kind of slip on wing protectors to keep fully sheeted wings from getting all dented up?  If so what are you using?
Formerly known as #Liner
AMA 1104207
Advanced
Offline Phil Spillman
Re: Wing protectors?
« Reply #1 on: March 19, 2019, 07:43:04 PM »
Hi Chris, Several years ago I saw Alan Brickhaus staple two sheets of poster board together for each wing and slip them over each wing. they worked for him may just be the thing for your needs!
Phil Spillman
Phil Spillman
Offline Paul Walker
« Reply #2 on: March 19, 2019, 08:08:10 PM »
I made some out of bubble wrap..
Cut to length of half span by just over 2 times the root chord. You can get fancy and taper them if your wing tapers. Then tape them together at the TE with the handy man's secret weapon, duct tape.
Works great.
« Reply #3 on: March 19, 2019, 08:35:44 PM »
Phil Spillman
   And to add to Phil's suggestion, Allen put small paper clip hooks on the bottom, held in place with Paul's duct tape, then used a rubber band from one to the other to keep the covers on. That way you can make them fit loose enough to slide on easily, and then still stay in place. A velcro strap of some kind would work also.
Offline Chris Fretz
« Reply #4 on: March 20, 2019, 01:12:46 PM »
Thanks for the ideas!
Chris
AMA 1104207
Advanced
Online dave siegler
  • sport flier
    • Circlemasters Flying club
« Reply #5 on: March 20, 2019, 05:57:33 PM »
I ave used rigid fan fold foam insulation.
pink or blue I build RC and indoor CL airplanes with it so it is in the shop
Use the the fold at the leading edge, trim the foam at the training edge and tape it.  It works very well.
Dave Siegler
NE9N extra class
AMA 720731
Offline TDM
« Reply #6 on: March 21, 2019, 06:26:44 AM »
Home depot has a nice durable bubble wrap stock that is used to isolate floor I think. It is color silver. Cut to size fold over and use a soldering iron to seal the edge. Glider guise use this a lot. The nice part is that it also keeps the sun from heating the stuff up too.
https://www.homedepot.com/p/Reflectix-24-in-x-10-ft-Double-Reflective-Insulation-Roll-BP24010/100318552
Offline jfv
« Reply #7 on: March 21, 2019, 08:54:54 AM »
I also use this.  Works very well.
Jim Vigani
« Reply #8 on: March 21, 2019, 10:46:06 AM »
Great stuff.  We use it around the house for all kinds of stuff.
Offline Chris Fretz
« Reply #9 on: March 22, 2019, 03:44:58 AM »
I saw somebody at Brodaks last year with that stuff, just didn't know where to get it at.  Thanks for sharing.
AMA 1104207
Advanced
Offline Carl Cisneros
« Reply #10 on: March 22, 2019, 07:52:03 AM »
Chris
Am going to hit Home Depot sometime this morning and pick up the 48 in. x 25 ft roll for 38 bucks and do
some of my planes hanging in the garage.
Will let ys know what I used for joining and such later this evening.
Carl
Carl R Cisneros, Dist IV
Control Line RB
Offline Target
  • C/L Addict
« Reply #11 on: March 22, 2019, 08:51:04 AM »
They sell 20" x 2m rolls at a Japanese store in my area called "Daiso" for $1.50 each!
I am one of the aforementioned "Glider guys" and just bought 10 rolls. For my DLG's and such.
R,
Target
Chris
AMA 5956
« Reply #12 on: March 22, 2019, 09:28:24 AM »
Hey Guys, Actually you do not want to use wing protectors. Reason: hanger rash gives them that war weary look so cherished at appearance points time. Makes them look like real veterans. Gives them "character" like most of us. LL~ LL~ LL~ LL~ LL~ LL~ LL~
My last design before my trip to the wilderness was called "Surveyor".  That was because of all of the Benchmarks!  LL~ LL~ LL~ LL~
Offline Chris Fretz
« Reply #13 on: March 22, 2019, 10:14:27 AM »
I can't even get it past the paint stage without denting it all up. Evertime I paint a new color it has a new dent, ding, puncture, cat claw mark....
AMA 1104207
Advanced
« Reply #14 on: March 22, 2019, 02:40:28 PM »
Chris
make that tomorrow instead.
Have a few things to get done before the thunderstorm hits.
Carl
Control Line RB
« Reply #15 on: March 23, 2019, 01:47:26 PM »
Made 1 set for my P-40.
did not like them so will leave mine off the plane.
The foam insulation I got from HD I felt was too stiff.
The way I hang my planes from the lead outs with 1 of the line clips attached made the flaps push on the inner surface
of the insulation and I could see and feel the flaps in a mild twist inside.
So I will leave them off as I have always done and leave it at that.
Carl
Control Line RB
