  • June 16, 2024, 05:31:26 AM
Author Topic: Need help from Rochester, NY  (Read 1285 times)
Offline bill bischoff
« on: July 27, 2015, 08:05:14 PM »
I hope somebody near Rochester NY can help me. There is a red midget air racer N6H, the Ohm Special, hanging in Rochester Airport. According to what I have found so far, it was originally donated to the Glenn Curtiss museum, donated or loaned to the Rochester airport, and "spruced up" by EAA chapter 44 in Rochester before it was hung at the airport. The Curtiss museum has no info on the plane, nor does the EAA chapter.
My hope was to find a three view. The R.S. Hirsch drawings don't show the particular iteration, and they are of suspect accuracy. Can someone email me a bunch of photos and whatever information may be readily available? I may be able to piece enough together from a good selection of photos.
Thanks.
Bill Bischoff
Offline JoeJust
Re: Need help from Rochester, NY
« Reply #1 on: July 28, 2015, 09:46:22 AM »
Bill, I will be in Buffalo in two weeks, but don't know if I can get to the airport in Rochester.  I will try, but no promises.
Joe
I only enter contests so somebody else is not always in last place
« Reply #2 on: July 28, 2015, 11:43:43 AM »
Thanks, Joe.
BB
Offline JoeJust
« Reply #3 on: August 22, 2015, 09:31:20 AM »
With a great deal of "Pure Luck" the mission has been accomplished!
Joe
Offline Tom Niebuhr
« Reply #4 on: August 22, 2015, 10:01:45 AM »
Joe,
Don't leave us in the dark. Pictures? Info?  "Inquiring minds want to know".
AMA 7544
Offline Bill Johnson
« Reply #5 on: August 22, 2015, 10:23:56 AM »
Nopt much from the FAA:
Deregistered Aircraft
Aircraft Description
Serial Number 01  Certificate Issue Date 09/18/1951
Manufacturer Name OHM RICHARD V  Mode S Code (base 8 / oct) 51741474
Model OHM SPECIAL  Mode S Code (base 16 / hex) A7C33C
Year Manufacturer None Cancel Date 03/22/1972
Reason for Cancellation Cancelled Export To None
Type Registration Individual
Aircraft Registration prior to Deregistration
Name STOPPELBEIN GORDON G
Street ROCHESTER AIRPORT
City ROCHESTER
State NEW YORK  Zip Code 14602
County MONROE
Country UNITED STATES
Deregistered Airworthiness
Engine Manufacturer None Classification Unknown
Engine Model None Category None
  A/W Date None
Deregistered Other Owner Names
None
According to Flying magazine, April 1957, it had a Continental C-85 and had set a new FAI speed record!
Best Regards,
AMA 350715
Offline JoeJust
« Reply #6 on: August 23, 2015, 10:53:21 AM »
Joe,
The whole adventure will be coming in a future CLW article. Here is a picture of the plane. to summarize, it took a Rochester City Policeman to get the job done!
Joe
« Reply #7 on: August 23, 2015, 05:01:20 PM »
It resembles the Casutt (Cassut, Cassutt?) Racer.  If you build this for C/L scale, you will need close-up photos of cockpit and details.  That looks like a real chore unless you can get it down to the floor!
90 years, but still going (mostly)
Offline JoeJust
« Reply #8 on: August 23, 2015, 07:28:01 PM »
Floyd,  I believe that Bill will not be building a full scale model. I believe he will be building a profile "Goodyear" CL Racing plane.
Joe
