  • July 12, 2025, 03:33:37 PM
Author Topic: Bandsaw Sliding Table  (Read 1984 times)
Offline Allan Perret
  • Proverbs
« on: July 22, 2017, 12:01:58 PM »
First up is pics of my current hobby size bandsaw. Its a Craftsman labeled saw but is identical to Rikon 10-305.  Friend had the Rikon and I set up a sliding table for him, and liked the saw so I replaced a 10" Ryobi I had at the time with the Craftsman version, it was on sale and about $50 cheaper than the Rikon at the time. Picking up at local Sears oultlet saved the the shipping cost.  Table is cast aluminum and miter slot is 5/8" wide so I used 1/4 x 5/8 alum. rectangle for miter guide bar.  Saw is marketed as a 10" but throat depth is actually 9 5/8".  I like and recommend this saw for hobby use.  Its around $275.
« Last Edit: July 22, 2017, 12:43:30 PM by Allan Perret »
Allan Perret
AMA 302406
Slidell, Louisiana
  • Proverbs
Re: Bandsaw Sliding Table
« Reply #1 on: July 22, 2017, 12:21:51 PM »
These are pics of one I just put together this past week for another club member.  Its going on a Craftsman 12" bandsaw which had the more standard miter slot of 3/8 x 3/4.  This makes it more convienent because you can use an alum tee-track extrusion for the guide bar.  The t-slot makes it easier and more flexible for mounting.  I lost track of the source on the blue track I'm using here, but Woodstock Int. has a red one identical to it except for color.  The gold extrusion is an Incra product, it has back to back slots with built in tape channel, one channel provides for mounting to table with screws from bottom and other channels is used the red stop, which is great for repeating cut length.  The center Zero scale is a $2 option, you want that.  The red alum stop and the red plastic knobs are from Woodpeckers.  Table in this case is 3/4" MDF, you can use any sheet material that is flat.  Using t-slot track for guide bar is nice cause you can put adjustable table travel stops at either or both ends.  I made the two silver travel stops from another extrusion used for putting a miter slot in a router table, most of the vendors that have t-track have this also.  This is the simplest version of sliding table and what I would recommend to get started.   You can also make table with the fence bar flush in table top, this would add some functionality to accommodate rip cutting, but most saws already have that so you just remove the sliding table for rips.  When buying t-track don't forget the special nuts that go in the slot.
« Last Edit: July 22, 2017, 12:51:20 PM by Allan Perret »
Allan Perret
AMA 302406
Slidell, Louisiana
Offline Mike Griffin
« Reply #2 on: July 22, 2017, 02:32:05 PM »
Allan made me one of these some time ago and I use it a lot.  It is so much better to place the work on the table and move the table through the blade to make the cut.  It really works well.
Offline Target
  • C/L Addict
« Reply #3 on: July 22, 2017, 04:22:43 PM »
I definitely need to make one of these since my Craftsman trim saw doesn't have a rip fence....
Thanks Allan!
Chris
AMA 5956
