General control line discussion => Open Forum => Topic started by: Bruce Guertin on April 23, 2018, 01:00:46 PM
I have two Twister kits here to Fancherize and two OS .40 FPs to power them. I need a couple of venturis and NVAs for the engines. Along with that I need to make fuel tank choices. I prefer to buy these from a fellow hobbyist.
How big does a tank for those .40s need to be? Will 4 oz do the job or do they need to be larger? Before I quit flying years ago I had made some metal uniflow tanks of my own but, those forms are long. Are plastic clunk tanks still used?
As to the Fancher modifications. The article I have was published in August '87 or so. It clearly states that the stab/elevator was moved back 3 inches, yet the plans I have show only a 2 inch movement. Which is correct for the .40FP the prototype airplane was flown with?
Out of curiosity, just when did Ted actually prototype the Twister mods? It must have been some time before the article was published.
Thanks for the help.
Some photos of Steve Kott and I cutting combat panels in my garage c.'77 '80
Bruce,
Seems like there are multiple variations out there. Which plans do you have?
On the plan drawn up by Bob Kruger, revision 2 July 2005, it notes that the fuselage is 2" longer than the stock Twister.
I have had very good luck with a Sullivan plastic tank on a bashed Twister. It is an RST-6, plumbed uniflow with a fixed uniflow tube at the tank centerline. It is plenty for an LA .46. Not sure if the 4 oz. will take care of an FP .40 or not. I am not currently running one....
Good Luck!
I'm pretty sure that I have the plans by Bob, and my Fancherized Twister files great.
I used a 46LA, the plane is porky at 54 ounces, and 4 ounces of 10% nitro, 22% oil is only enough for the pattern if I doctor it up with a smidge (2 oz/gallon) of Coleman camp fuel.
I suspect that if you don't go too wild on the plane weight, and if you use the right prop that 4 ounces will be sufficient. I use a plastic clunk tank on muffler pressure, a ThunderTiger 11x4.5 prop, and it flies great. If you have unmodified 40FP's then try the TT prop if you can get it, and APC 11x4, 11.5x4, and 12.25x3.75 props. Be ready to spend some time with each prop before you go on to the next one.
Jim Lee or Randy Smith can set you up with venturis and needles. My personal bias is to stick with a needle that will fit the case -- please don't go drilling out yet another perfectly good OS case just so that you can use a fashionable needle instead of the perfectly good OS needle.
Dave, those are the 2005 plans that I have.
Obviously, light is right within reason. I had finished my previous Twister and Banshee with Monokote on the flying surfaces and either Varathane or Pactra colored polyurethane sprayed on just enough to provide coverage. I guessing those colored polyurethanes are no longer available.
As to the 40FPs. No, I will not be drilling the cases just to get a boutique NVA in them. The OS parts are fine, I'd like some venturis as I have none. Maybe in a couple of different diameters. Come to think of it I wonder if I could print some up? A buddy and I build race carbs and we've been printing booster venturis and other parts in nylon. Maybe I can do that.
Tim, I was used to running 10-5W or 6W Rev-up props on a Fox .35. Are the OS and current engines that much more powerful that they can use props in 11 or 12" diameter?
The airplane was definitely prototyped and existed (and may still be hanging in Paul "Peppy" Pomposo's garage. There's a picture of it in the article and that was well before Photoshop.
I only ever saw it fly with a Merco 35, which was OK. The best-flying examples were Bob Hazle's that used 25FPs with 10-4 Rev-Ups and a ST spraybar. I flew one of Bob's airplanes shortly after I won Golden State for the first time, and it flew better than the airplane I had just won with, and not just a little bit. I wouldn't even consider using a 40FP given what we know now, 31 years later.
That'd be interesting. You're printing in Nylon? I thought most of the consumer-ish printers were ABS, which has a pretty low melting point.
Venturis for CL is such an easy lathe task that if I taught shop I'd do it as a second or third project after making perfect cylinders.
Yes, but no.
Yes they're more powerful, but notice the pitch. If you're used to running Fox 35's then you need to change a LOT of your thinking. The "new" (i.e., "only" 30 years old) engines want to spin fast, usually in a wet 2 or a solid 4, almost never in a 4-2 break. That's why Brett and I are both mentioning props with 4" pitch or flatter. You run the motor faster, with less load, and it's happier.
I really need to see if I can build a Fancherized Twister light enough to run it with a 25FP or 25LA. Fortunately, if you build a porker you can run it with something bigger. I cannot, for the life of me, remember if the 40FP is a suitable stunt engine. The Tower 40 is, and the 46LA, but I haven't run the 40FP.
A 40FP will probably spin a 12-4 fast enough to fly the airplane, but that's not what you want to do. In the days of Fox 35s ad ST46s, the only way to get more power was to add diameter. You don't do that any more. You reduce the pitch.
Modern engines are much more powerful, but at higher RPM, and they want 4" of pitch. Almost all of the large contest winners since about 1990 have used props in the range of 3.25-4.5".
Something like a stock 40FP will end up being FAR too fast with a 6" pitch prop, and people have had nothing but frustration when we tried to run them like they were Fox 35s with better fit/finish. They are notorious for "runaway", where no matter how you set the needle on the ground, at some point in the flight, they take off into a 2-stroke and never come back. This is seen as a defect, however, *this is precisely how they were intended to run*, that's how they are designed, and you have to make drastic modifications to change it.
If the engine makes the airplane too fast, the logical solution is to reduce the pitch. This will permit the engine to rev up more like it wants, you run it in a 2-stroke all the time like it wants, and everything is a lot more reasonable. However, you will quickly find that a 40FP is *way* too much power to deal with and it's still too fast even with a 4" pitch prop. You can get fiberglass props that you can adjust to have less than 4" (try 3.25" to start with) but with any common prop, you still are too fast/have too much power. In fact, if you set the engine at the desired/intended operational setting (peak out lean, then richen up so it peaks out at some point in the maneuvers), it's close to *twice* the power you need.
When this was discovered, about a million (it seems...) guys came out of the woodwork with dremel tools and drills, trying to "fix" it. It wasn't broken, but that never stopped anyone, and eventually people came up with a bunch of modifications, some of which actually caused it to work OK with props like a 10-6EW most of the time. The problem is, then the performance is no better than a Fox 35, either.
You can deal with the "runaway" problem a better way by reducing the venturi size until the power is reduced enough to fly with the props you want. An alternative, if you have twice as much power as you need, is to use one about the same but half the size. Like a *20FP*. I did that equation sitting out in the 100+ degree Gilroy, CA sun one afternoon, and sure enough a bone-stock 20FP with an APC 9-4 is just about exactly what you want. It doesn't have the vast overkill power of a 40FP, that is hard to deal with lacking a tuned pipe, and it performs much better than a Fox 35. I did nearly back-to-back flights on a Skyray35 with a very good Fox 35 and the 20FP, and flying it with a 20FP was like gravity had been turned off, with vastly better vertical performance and dead-steady pace in the maneuvers.
This is exactly how top competition systems work, except you are doing it with a muffler instead of a tuned exhaust. That means you don't have nearly the sort of pinpoint control you have with a piped system so you have to be a little more picky about getting the right-sized engine.
The led to very extensive experiments with similar small RC engines, with the rules of using commonly-available 4" pitch props and *minimal* or preferably no engine modifications. This turned our very well, and I found that almost any of the smaller RC Schenurle ABC engines at the time worked fine if you ran them how they wanted to run. The 20FP (available for $49 at the time) and the 9-4 APC prop ($1.94 at the time) stood out, but they all worked with slight adjustments and NO GRINDING OR DRILLING whatsoever, and far better performance than any engine from the good old days and a 10-6EW.
And they're still out there, in eBay land.
Russel Shaffer was flying a Fancher Medic on a 25LA for a couple of years; it always seemed to lack power, which is part of what's kept me from trying to stick one on a Twister.
"snip"
Hi Brett,
Are you sure you aren't confusing Bob's Medics with the F'ized Twister? I don't recall him having one of the latter? Of course, I no longer recall what I had for breakfast this morning, so......
Ted
General Interest p.s. The F'ized Twister was built, as stated in the articles, solely as subject matter dedicated to entry level readers. The mods therein were never chronicled via the additional effort of drawing an actual "construction plan" for the project. Bob Kreuger's later plan was vetted by me for general conformation to the concept but I no longer had the airplane with which to make accurate dimensional comparisons. I was, quite frankly, surprised at the level and long term interest in the...um,er...project as it was intended primarily as a means by which to discuss some general items of interest or possibly educational value for less experienced readers of the column.
The larger area stab/elevator, for instance, was not a part of the original project but was the result of later refinement of the "longer tail 'moment arm' concept" and the fact that the combination's greatest value lie not in more "power" to allow further forward CGs as (embarrassingly) stated in the article but, quite the reverse, that the longer tail combined with greater area provided the stability to allow the CG to be moved further aft to provide improved maneuverability "most particularly" in inclement, windy conditions under which forward CGs tended to open up maneuvers, often to disastrous levels while, importantly, retaining or likely even improving stabilty.
I don't recall for sure but the larger area tail may well have been part of the discussions I had with Bob as he developed the plans he drew (from which, I believe, most reproductions have been built). If so, that is likely where the shift from a three inch longer fuse addition was reduced to two inches as has been discussed on this thread.
Sorry I can't be more precise as I never expected to be discussing the F'ized Twister thirty plus years after the original kit was bashed! I'm nonetheless pleased to find that the intent of the project...to create interest for budding builder/flyers...appears to have been in large part a success.
Hi Brett,
No, he only had the one Medic and that got sold to Paulette. That was the one where we completely transformed the airplane by adding a tiny rudder (made from a folded-over glow plug cardboard package and taped to the large fin) with a 1/16" of offset.
He had (at least) two Fancherized Twisters, translucent yellow Polyspan, both with 25FPs/ST spraybars and Rev-Up 10-4s. Very neatly built, lots of half-ribs, etc. He took them to the NATs, one ended up with Jim Renkar, from what I recall. You guys tried a Brodak BY&O 10-3 and even launching it at 13000 RPM, it went about 6 seconds/lap.
The incident I mentioned was at the 1996 Golden State meet, my first big contest win, and Bob got me to fly it while I was waiting for the score to be posted. It flew better than the Imitation XL with a PA40, and not just a little bit.
Kinda like hitting the ball out of the park when you thought you were going to bunt. It is unfortunate that more people don't read the original article and go kit-bash their own stuff, but on the other hand, the Fancherized Twister is one hell of a stunt trainer.
Bob Hazel's Twister.
(https://stunthanger.com/smf/open-forum/show-us-your-twisters/?action=dlattach;attach=243496;image)
Hi Brett,
Ted
Ted
Thanks for adding to the discussion. I haven't picked up a handle in 35 years. so that makes me a beginner again.
My last flight was with a Twister I modified in 1983 or so. While looking at the photos I have of that particular airplane show some F'ized type mods. Things such as half ribs, shortened and widened fin, wider stab/elevator, extra hinges at the wing tips and extra wood at the cheek for strength. At the point of self-depreciation, it's not likely I would have thought of that stuff myself, I must have read or heard about those mods somewhere. Maybe MA.
Bruce: I hope all this side discussion isn't going to keep you from getting it done! If you get to confused -- just build something, and stop worrying about people who like to split hairs.
Tim, I get it. I'm asking questions and other modelers are just trying to help. And I don't want to appear resistant to that help.
Good. Just remember that my way is the best way. ;D
Oi vey! I should'a known better than to question Brett's memory and then Brent shows up with a picture to rub it in! Don't recall where that pic was taken but I did note the original Doctor was just a couple of planes north of Bob's ,er, uh F'ized Twister. Also appears to be another Twister just South of Bob's that shares what is a common Hazle-ish finish. Was that another of his Twisters?
Ted
Oh...and of most interest what and who's was that biplane in the line-up of profile stunters, Brett?
One of my best flying profiles was a cheater Magician. Longer tail moment, stabilizer lengthened 30 percent. Powered by a reliable running FP40. 10.5x4.5 sport APC prop. Powermaster 22%(50/50), 10%. .273 venturi (available from Jim Lee, see vendors corner.) It was light, 33 ounces ready to fly without fuel. Model is comparable to Fancherized Twister. I used 3 head gaskets softening the break. Weight of model will effect required power, that can be regulated.
An FP20 did not have enough power to pull a rather porky Skyray I bought at a swap. FP25 when run at full power using a tongue muffler works. Skyrays do not have flaps, depending on model weight, can fly reliably with and FP20. Heavier models will need more power. True for porky Skyray. Flapped models of similar size can need more power.
If you build light, if the Twister comes in around mid thirties an LA25 or equivalent should work. I have flown Twisters and the Magician powered by FP40s and Tower 40s (a close clone, better cylinder liner, true chrome.) I have a ten year old Galaxy that uses FP40 power. Great fun, very controlled engine run. Since you have them, I'd start with an FP40. Use the small venturi -- .256, put in an extra head gasket, use prop and fuel mentioned above.
Runaway problems with FP40s and Tower40 I've seen usually have two causes. Vibration or attempts to run engine at too low rpm.
Ask Brent - I am not *sure* I know where that assemblage of airplanes was, looks kind of like the Woodland Stunt Clinic and the time frame is about right. I think Hazle's Twister (his first) is the nearest the camera, and maybe the one in the center is Paul "Peppy" Pomposo's. I do not know whose biplane that is and I don't recall the airplane at all, which suggests I wasn't present, since I am curious about it, too. I *am* going to do a biplane in the future.
The Starduster was built by Dave Baxter of St Helens, OR. Here is a link to an interesting thread from “the Biplane Forum”, a forum dedicated to full scale biplanes of all types. The thread asked the question “did model airplanes lead to the real thing?
Lots of cool pics and videos and familiar faces we will all recognize. There are multiple pictures of the Starrduster model, including a picture of it in front of its full scale inspiration.
http://www.biplaneforum.com/showthread.php?t=16731&highlight=Model+airplane
Enjoy.
I most likely nabbed that picture from Heman Lee's Aeromaniacs site.
