  • June 15, 2025, 07:41:53 PM
Author Topic: power panel plugs  (Read 482 times)
Offline Bootlegger
power panel plugs
« on: June 10, 2020, 10:51:31 AM »
 I would like to know what the plug in parts for the power panel to attach starters to the power panels are called, and where I can get them..   Thanks.. H^^
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: power panel plugs
« Reply #1 on: June 10, 2020, 11:02:07 AM »
Probably banana plug, unless the power panel is weird.
It's a general electronics item.  I'd recommend getting them from DigiKey or Mouser, because you'll get quality parts that way.  Just searching on "banana plug" should get you hits (and show you a picture).
Offline Bootlegger
« Reply #2 on: June 10, 2020, 01:28:46 PM »
 Thanks Tim, that was what I needed, gottum on order   y1 <=
Gil Causey
AMA# 6964
Offline James Holford
« Reply #3 on: June 11, 2020, 11:13:46 AM »
Andy's has them as well
Sent from my SM-G965U using Tapatalk
Jamie Holford
Baton Rouge Bi-Liners
Lafayette, La
AMA #1126767
Offline Joe Ed Pederson
« Reply #4 on: June 11, 2020, 12:12:43 PM »
I got mine from Tower Hobbies.
https://www.towerhobbies.com/cgi-bin/wti0001p?&I=LXFT99
I bought the Sullivan heavy duty ones, but they also carry bananna plugs from E-flite and Dynamite.
Joe Ed Pederson
