  • July 26, 2025, 06:18:41 PM
Author Topic: Progress update on the Sea Hurricane  (Read 4120 times)
« on: August 11, 2017, 08:47:31 PM »
Just waiting on the weather to shoot clear.
Offline James Holford
Re: Progress update on the Sea Hurricane
« Reply #1 on: August 11, 2017, 08:59:32 PM »
Looking good!
Jamie Holford
Baton Rouge Bi-Liners
Lafayette, La
AMA #1126767
Offline Dane Martin
  • heli pilot BHOR
« Reply #2 on: August 11, 2017, 11:38:41 PM »
Beautiful job
Offline Don Jenkins
« Reply #3 on: August 12, 2017, 06:07:51 AM »
Very nice, you do great work!
Don
« Reply #4 on: August 12, 2017, 10:23:00 AM »
I like it. H^^
« Reply #5 on: August 12, 2017, 11:41:37 AM »
Thanks Y'all.  :D
Was hoping to have it ready by the WKSI contest next weekend but maybe the next one.
Actually there will be a small squadron of these. Three other club members have them under construction.
Will try and post up again when all are complete.
« Reply #6 on: August 12, 2017, 05:08:39 PM »
Looks really great, Paul!  John Tate from the Norfolk VA area has flown one of these very successfully in the past.  What is the power plant??
  y1
« Reply #7 on: August 12, 2017, 06:53:32 PM »
  Nice Paul! Is it a Brodak kit? I think I have one in my stash.
  Thanks a lot,
« Reply #8 on: August 12, 2017, 07:07:55 PM »
  y1
Hey Big Bear
Yea I swapped a few messages with John. One reason why I pulled the trigger on the kit.
I have a LA 46 ready to go.
« Reply #9 on: August 12, 2017, 07:08:38 PM »
  Thanks a lot,
Yep. It's a Brodak kit. 👍🏽
« Reply #10 on: August 13, 2017, 02:22:36 PM »
 Looks great! Aren't you going to add the insignia decals before doing the clear though?
« Reply #11 on: August 13, 2017, 02:34:25 PM »
Excellent workmanship and finishing.
Two hats off for this fine model!   H^^ H^^
Charles
Offline Fredvon4
  • Central Texas
« Reply #12 on: August 13, 2017, 04:59:38 PM »
I am currently making/morphing/assembling a Brodak P-40b ARF and really want to experiment on it with panel lines..
Your technique is interesting any advice?
looks to me like drawn line and then airbrush shadow....
Was there any special prep to the skin?
My ARF is all china kote
Fred von Gortler IV
« Reply #13 on: August 13, 2017, 05:51:16 PM »
Thanks. Not as good as some of your planes. 😉
For some strange reason I read the directions for the decals. They said not to use clear dope over them. That they are fuel resistant.
The directions said I could use some special type of clear ( too lazy to get off the couch and get the name).
So will shoot brodak clear then the decals go on last.
« Reply #14 on: August 13, 2017, 05:59:57 PM »
Not sure about the China Kote and ink lines but I think it could be done.
Jim Lynch showed me how to do the shadowing.
It is done by taping right on the edge of the ink line. Then take black pastel chalk and rub it on sandpaper to make powder. The with a small stiff artist brush dust it on the panel line. Blow off the excess then wipe lightly with a paper towel.
You have to be careful not to get it on areas you want clean. Also I found it works best if you work your way into the center of the area your working in.
« Reply #15 on: August 13, 2017, 11:06:37 PM »
 FWIW, if you're careful, those Brodak decals showing in your photo are totally safe to shoot over with clear dope. The "Major Decal" brand is also safe.
 Here are some tips:
 Start by carefully trimming out each decal, right up near the color line, leaving only about 1/16" of the clear. Apply them with a bit of soapy water (two or three drops in an old hairspray pump bottle works well) then squeegee them out and let dry for a couple days. Then go over just the decals with a half dozen or so "dry" coats of 50/50 clear, covering the entire decal but focusing most on getting the edges buried and sealed. A small model airbrush work very well for that process. After sealing the decals and they've had a good chance to dry then have at it with your final clear coats.
« Reply #16 on: August 14, 2017, 10:12:17 AM »
Very nice, Wayne. Great paint work. I haven't worked on anything in the shop in months really other than a bit of piddling around. After injury, am spending my time rebuilding decks and such. Hope to get back to playing in the shop soon.
Offline Fredvon4
  • Central Texas
« Reply #17 on: August 14, 2017, 11:07:38 AM »
Thanks Paul ....I assume the shadow chalk is fixed later with one or more clear coats and I also assume you are using a flat clear on that beautiful bird
Fred von Gortler IV
« Reply #18 on: August 14, 2017, 01:46:19 PM »
 Here are some tips:
Thanks Wayne.
I might give it a try.
If I screw the up I can order another set. 👍🏽
« Reply #19 on: August 14, 2017, 01:47:06 PM »
Yes. Just waiting on the weather.
Edit - I was told Stunt planes are  shiny 😉
« Last Edit: August 14, 2017, 03:20:12 PM by ROOTBEARD »
« Reply #20 on: August 14, 2017, 07:57:53 PM »
 Psst, Randy, this one ain't mine. Like yourself, I haven't spent any quality time in the shop for a few months. Winter will come though, then it's back on the P-38.
Offline Jim Nohsey
« Reply #21 on: August 15, 2017, 05:10:49 AM »
Paul it is looking good.
Jim Nohsey
Offline Joseph Patterson
  • AMA member- Supporter
« Reply #22 on: August 15, 2017, 07:29:02 AM »
     Paul that is a great looking plane! Hope to see it in Zachary!
         Doug
« Reply #23 on: August 15, 2017, 08:57:19 AM »
« Reply #24 on: August 15, 2017, 08:58:46 AM »
         Doug
That's the plan.
We are booked !😉
Offline Fredvon4
  • Central Texas
« Reply #25 on: August 15, 2017, 11:32:44 AM »
Just have to comment because I have seen it mentioned a few times about how Judges (seem to) prefer very shiny hand rubbed finishes
Kinda torques me a bit: Because, for me, a beautiful war plane in cameo ............well you get the idea.... some great modeler did such a grand job of a scale or semi scale war bird......
I love looking at some truly exceptional military dioramas where the model is weathered, worn, shot the hell up, and is actually dripping cherry juice in three paces
There are some exceptional model artist out there
ok no more rant
Very good looking plane Paul.... so much so I am using your photos for my self panel line training on my ARF...thanks
Fred von Gortler IV
