Denatured Alcohol is ok, AKA "Shellac Thinner" from the hardware or paint store. I would not use "rubbing alcohol" because it has water in it. If in doubt, read the label first. I think methanol alcohol would be ok, but I'm not a chemist. I haven't even stayed at a Holiday Inn Express, but did take high school and college chemistry.
Acetone or Lacquer Thinner would probably work ok, but would be likely to cause brittleness. At least, it appeared so, the one time I did that, so didn't do it again.
