  • June 16, 2025, 05:54:18 AM
Author Topic: exhaust maifold  (Read 2815 times)
Offline Doug Kretschmar
exhaust maifold
« on: October 28, 2016, 08:47:52 PM »
does anybody have a source for exhaust manifolds that can be used to dress up a stunt plane? Thanks,Doug
Re: exhaust maifold
« Reply #1 on: October 28, 2016, 09:08:42 PM »
How about the manifolds off of this engine?  They're a classic, at least if you're a Chevy aficionado.
http://www.ebay.com/itm/MONOGRAM-1-8-Scale-Model-Car-Kit-1965-Corvette-Sting-Ray-Engine-transmission-/282225985742?hash=item41b5fac8ce:g:LNgAAOSwxKtYB68V
Re: exhaust maifold
« Reply #2 on: October 28, 2016, 09:28:21 PM »
Doug,
I make my own exhausts, but for Warbirds, not stunt planes. Here's photos of some I made.
Simple aluminum tubing. Some, as you can see, bent. Glued in place then framed with balsa. I make the back cut in the table saw, but it could be done by hand.
Glued in place then painted. Takes a bit of time but worth it. There might be progression how-to photos in the Mig-3 build.
Brodak sells some already made.
Charles
Re: exhaust maifold
« Reply #4 on: October 29, 2016, 11:15:36 AM »
Made these from K&S Alumn. tube , cut in twelve , half the cuts at 45 degrees ish . Aryldited in a pin jig. Pins forced with pliers into a plank at measured intervals to space even .
The inner face can be sanded ( rubbing the manifold along 80 wt. on the bench . A edge at the outer edge and a quater & or three eights strip & pencil line , so its finished parrallel ,
or otherwise . The alloys very malable , so can pull in front face curved later , with a drill bit part in it to hold it round where needed , or you could C the rear like a Battle of Britian
Merlin ( Spit & Hurrie ) or P-40 etc . Maybe grind a stell die / former to fit in , for consistancy . Would have to avoid knocking them around or GRASPING the plane by your mitt , there.
whoops .
Also done them from 3/8 brass tube , likewise , but soldered .
If a slot is alowed for in the cowl sides they can be used as cowl air outlets ,
or even ducted for the exhaust outlets.
Thats a bit of a waste unless youve got a smokey exhaust engine . R E preferably .
« Last Edit: October 30, 2016, 01:05:48 AM by Matt Spencer »
Re: exhaust maifold
« Reply #5 on: October 29, 2016, 11:31:55 AM »
Theres some RESIN ones for 1:5 scale Warbirds on the RC Group Misc. Classifieds , too .
Whittle ONE pattern , and do silicon moulds like Spakys Resin Spinners ( video ) and youd have a set in next to no time
Re: exhaust maifold
« Reply #6 on: October 29, 2016, 06:32:28 PM »
Doug, please say that you really did want to know about fake exhaust stacks for that V-12 look, and that you're not looking for exhaust adapters or tongue muffers or some such.
Because I thought you were looking for the latter and only posted my link to yank your chain, but then everyone else dived onto the bandwagon.
Re: exhaust maifold
« Reply #7 on: October 30, 2016, 12:52:36 AM »
Too Right . Manyfold Manifolds , by golly .
rolls royce / merlin / griffon / hurricasne / wotever / EXHAUST MANIFOLD on Google Pics gets all sorts of itterations , unearthed .
Shakleton Griffon one , has five bolt flange .  %^@
So doing one pattern as appropriate , and the resin moulding trip ,
Re: exhaust maifold
« Reply #8 on: October 30, 2016, 01:14:17 AM »
TWELVE POUNDS . I hope thats not each . Serling ( again ) Now . Not those euro wotsits . Definately not 12 x 16 Oz  Pounds , though theyre sterling  , or Imperial . Too .  :-\
1/4 , 1/5 , & 1/6 scale . they say . Nothing about the weight .  :##
http://www.fighteraces.co.uk/product/16-scale-rr-merlin-round-exhaust-stacks/
AND THEYRE NOT THAT SCALE . TOO. LOOK . No blankety securing fastener ( Stud / bolt ) holes etc on periphary . D*#n poor show .
