I recently redid the bellcrank installation in a Vector 40. The leadout failed at the bellcrank--fortunately during a ground check--so there was something left to repair.
The Brodak plans (as drawn by Curt Contrata, and presumably faithful to Randy's design) show the pushrod in the bellcrank center hole, which measures out at a radius of 11/16". This is paired with a flap horn radius of 1-1/4".
If you have the assembly booklet from the Brodak kit, you will see a picture of the flap pushrod in the outer hole of the bellcrank. If you like quicker controls, that may be an option. I haven't got much flight time on mine since the leadout replacement exercise, but I like the control feel using the center hole so far. It feels pretty deliberate, and that makes the rounds smooth.
Note that another "control ratio" that should be considered is the line spacing at the bellcrank vs. the line spacing at your handle. Assuming you have the standard 4" bellcrank, that might be a good place to set your handle to begin with. Unless you have already found a ratio that works for you on similar planes. So you can always "speed up" the control feel by widening your handle spacing, or vice versa. But you may want to watch that your control surfaces do not hit the travel limit as hinged by a fast bellcrank/flap horn ratio.
It also might be worth mentioning that moving the pushrods out at both ends while maintaining the same ratios, causes the forces in the pushrod to go down. That means the ball joints, clevises, etc. see less load and the wear on the moving surfaces goes down. Also, if you had just a little bit of play in each joint, the larger the radius on the control setup, the less lash there will be at the control surface. In other words, without fitting anything tighter or holding closer tolerances, you get less free play in the control surfaces.
The plans show the flap to elevator ratio is 1:1. That means the radius to the holes on both ends of the elevator pushrod should be the same. Use the farthest one out that you can. On the plans (assuming the hardware is the same as the plans) that is a radius of 3/4", which was limited by the elevator horn. If your horns differ, just be sure that the connections at the flap horn do not interfere with each other over the entire control range. No binding or grinding....
Good luck with yours,
