  • July 22, 2025, 05:11:29 AM
Author Topic: Evolution .36 venturi base size  (Read 1730 times)
Offline Steven Kientz
« on: June 06, 2009, 05:44:55 PM »
I have searched HH website to no avail. I'm trying to determine the base size of the venturi on the Evo .36. I would like to see if I can retrofit that venturi to a GMS .25 or .32. The ST.51 venturi(13mm) will fit but the throat(7mm) maybe to large. If someone knows the size or could measure it I would really appreciate it.
Steve Kientz
AMA 855912
Dave Adamisin
Re: Evolution .36 venturi base size
« Reply #1 on: June 06, 2009, 08:09:33 PM »
Hi Steve. 7mm is a good plae to start with the 4mm (0.155") dia spray bar. This is the classic os 35-S, fp40 vent size and spraybar combo. It should work well on suction or mp.
Offline Larrys4227
« Reply #2 on: June 07, 2009, 04:15:41 AM »
Steven - The base size of the Evo36 venturi's is .513
FlySafe!  Larry (Larrys4227)
« Reply #3 on: June 07, 2009, 07:38:02 AM »
Thanks for the info.I have been using GMS engines for a couple of years,2 .25s and a .32. Locked the carb open, very good runners. Some club members say theirs were down on power after several months of RC use, but I suspect they don't typically clean the engine after use(or drain the tank). If someone is looking for a good performing inexpensive engine I would recommend the GMS. I am considering adding a .47 to my collection.
Thanks Steve
Steve Kientz
AMA 855912
