  • June 22, 2025, 03:03:14 PM
Author Topic: EVO 60 CL Specs  (Read 1285 times)
EVO 60 CL Specs
« on: January 08, 2013, 01:31:07 PM »
I need detailed measurement specs for the Evo 60 for the CAD forum. I am not interested in printed dimensions. I would like the ACTUAL dimensions taken, ideally using a calipers from an ACTUAL EVO 60CL.
If you could provide me with that, I would sincerely appreciate it.
Thank you.
Online Dick Pacini
Re: EVO 60 CL Specs
« Reply #1 on: January 08, 2013, 04:32:22 PM »
If you visit the EVO site, you can download the manual which has a diagram with the dimensions you need.
AMA 62221
Re: EVO 60 CL Specs
« Reply #2 on: January 08, 2013, 04:36:44 PM »
Thanks Dick. But that is exactly what I am not looking for. Looking for someone with an Evo that can actually measure it very accurately. But, thanks again.
Online Dick Pacini
Re: EVO 60 CL Specs
« Reply #3 on: January 08, 2013, 06:07:31 PM »
I guess I don't understand why the dimensions from the factory elevation are not good enough.  I have an EVO 60.  I have dial calipers and micrometers and over 40 years experience in manufacturing.  I can go downstairs and check my EVO and would lay odds that I get the same dimensions.  If I don't, then either I made a mistake or my EVO is a turkey out of tolerance.
AMA 62221
Re: EVO 60 CL Specs
« Reply #4 on: January 08, 2013, 06:45:05 PM »
I have a Saito 72. What they list and what they actually are sometimes different. I want this one dead one. I know about the listed specs on the EVO. I am specifically after measured specs. But thanks for the tip.
Online Dick Pacini
Re: EVO 60 CL Specs
« Reply #5 on: January 08, 2013, 09:23:54 PM »
I will check my EVO 60 and post back in a couple of hours.  Right now, I am, fighting a wicked cold and pretty well sapped.
AMA 62221
Re: EVO 60 CL Specs
« Reply #6 on: January 08, 2013, 09:39:16 PM »
Thanks so much. Get better!!
Online Dick Pacini
Re: EVO 60 CL Specs
« Reply #7 on: January 08, 2013, 11:31:50 PM »
A=1.417
B=1.732
C=.689
AMA 62221
Re: EVO 60 CL Specs
« Reply #8 on: January 09, 2013, 08:08:04 AM »
A=1.417
B=1.732
C=.689
Thanks so much Dick.
Dick as I know you are sick, please consider this at your leisure but, could I possibly get from you:
D. Mounting Lug Overall Width
E. Motor C.L. to top of motor
F. Motor C.L. to bottom of motor
G. Max Top Cylinder Circumference
H. Motor C.L. to Center of the Exhaust
I. Exhaust opening width (outside)
J. Exhaust opening height (outside)
K. Motor C.L. to spray bar height (very important)
