  • July 29, 2025, 11:20:24 AM
Author Topic: Ever have one of those days.....  (Read 2170 times)
Online Paul Taylor
« on: April 03, 2012, 09:50:52 AM »
when you should just step away from your model? Everything you do turns to crap?
My ARF Nobler was all blue and needed something on the wing. I took out the kit decals and cut out the NOBLER decal. I put two dots with a marker where I wanted it to line up. After getting ready to stick it on I change my mind and used the leading edge as a guide. Did not take a second glance at the dots. One ended up under the decal. Great, now I just need to add more dots and dashes to spell out S.O.S in Morris code ! HB~>
I then moved on to the muffler.
I was removing the muffler with a Phillips-head screw driver and the driver slipped off and I punched a hole in the side of my cowl. Great now I have a hole to run my pressure line thru. HB~> ( I just had it exiting out the heat venting and no extra hole required) Now I have a new hole.
I ran the line, and then put the model on the table. Turn off the lights and walked away.
Offline Brian Massey
    • California Car Clubs
Re: Ever have one of those days.....
« Reply #1 on: April 03, 2012, 10:03:48 AM »
So why are you whinning? Sounds like just a typical day in my life.  n~ n~
Brian
AMA 55421
Madera, CA
« Reply #2 on: April 03, 2012, 10:06:33 AM »
  Don't fret none Paul. A little alcohol will probably take the marker off, maybe even a few drops of fuel. As to the muffler issue, I ALWAYS replace any phillips or straight blade screws with socket head screws to eliminate that possibility. Most any muffler that has metric screws to mount it is about the correct size hole to run a 4-40 tap into, and there is a better assortment of 4-40 socket head cap screws out there to use than metric.
    Good luck and have fun,
Online Paul Taylor
« Reply #3 on: April 03, 2012, 11:07:38 AM »
Thanks Dan
Problem is the dot is under the clear of the decal. Can't get to it.
Offline Shultzie
« Reply #4 on: April 03, 2012, 12:03:52 PM »
Yes!
Go to the fridge...pop open a bottle of----------? BUD...or pour yourself a STIFF ALCOHOL drink...KICK BACK AND CONTEMPLATE! BW@ DK^ %^
or just maybe wait... RELAX...don't forget to JUST BREEEEEEEEEEEEEEEEEEEEETH! When the ALCOHOL wears off...repair optionals should just magically appear?
Don Shultz
« Reply #5 on: April 03, 2012, 12:31:52 PM »
Thanks Dan
   Carefully take the point of an Exacto knife and lift the edge of the decal. Get out you heat gun or iron and gently heat the decal until it lifts off. Clean off the spot, then relay the decal. Just a little time and patience is all that is required.
« Reply #6 on: April 03, 2012, 06:26:17 PM »
its a pretty easy fix  - not sure why you'd leave it there.  The cowl a bummer but I you were flyin electric - it wouldn't happen  y1
Offline Zuriel Armstrong
« Reply #7 on: April 03, 2012, 08:14:48 PM »
Paul,
Removing that dot may be the trim feature you have not adusted yet???  Might be worth a try :-*
Is that PINK fuel tubing???
Zuriel Armstrong
AMA 20932
« Reply #8 on: April 03, 2012, 08:40:27 PM »
Just take a spot of the blue monokote and put over the dot. done.
Online Tim Wescott
« Reply #9 on: April 03, 2012, 09:05:15 PM »
And a little more will make it so you don't care.
Mike Griffin
« Reply #10 on: April 03, 2012, 09:43:36 PM »
Well Paul it must be the week for the dark blue Nobler.  I poked a hole in the outboard wing on mine this week and I do not have a scrap of that color Monokote anywhere.  Soooo I am going to have to order a whole roll of that just to patch the hole....so don't feel bad.
Online Paul Taylor
« Reply #11 on: April 04, 2012, 06:15:28 AM »
Hey Mike if the hole is not real big just put a stick on decal. Some else idea.
Mike Griffin
« Reply #12 on: April 04, 2012, 07:57:46 AM »
I think that is what I am going to do Paul....I can come up with something...
« Reply #13 on: April 04, 2012, 09:29:00 AM »
If you had asked someone might have sent you a scrap peice that was left over.    VD~
Online Paul Taylor
« Reply #14 on: April 04, 2012, 11:36:12 AM »
Yea but if he puts a decal over it no one will ever know. If he puts on scrap monokote someone will know he is covering a hole up. LL~
« Reply #15 on: April 04, 2012, 11:53:49 AM »
  There is a marketing idea in all of this. Peal and stick MonoKote patches that look like BandAids! y1 y1 You could also just buy a piece of trim Monokote that is the same color, and it's peel and stick and very thin. Smiley faces come to mind also! :) :) :) :) :) <= <=
Online Tim Wescott
« Reply #16 on: April 04, 2012, 12:02:16 PM »
I like the band aid idea.  Or bullet holes.
I've met people that never have this kind of day -- but they're dull and boring, or irritating as all get out, or both.  (I had a manager once who never missed a day of work for being sick, ever, and really couldn't understand how it could happen to anyone else.  Since this was when my boys were at that "disease vector" age, it was a constant source of irritation).
Mike Griffin
« Reply #17 on: April 04, 2012, 09:23:25 PM »
I got a good laugh out of that Tim....I went through the same things with my kids years ago.   I do like the idea of a peel and stick bandaid....  or bullet holes...
Offline bill bischoff
« Reply #18 on: April 04, 2012, 09:30:36 PM »
You can always buy a new cowling, too. Lots of little problems disappear when you throw some money at them!
(This message brought to you by your friendly hobby shop)
Offline jim ivey
« Reply #19 on: April 05, 2012, 06:56:24 AM »
that's how Ikilled a "stratocat" trying to do an outside loop.  took it up high, cranked full down, got skeerd half way tried to recover just in time to pile straight in :(  jim moral: always finish what you start!!!  y1 jim
