  • July 21, 2025, 06:42:14 AM
Author Topic: Profile Mako Jet  (Read 3797 times)
Offline Pat Johnston
Profile Mako Jet
« on: March 29, 2011, 12:19:17 PM »
Here is a departure from my usual Warbird stable.  The Mako Jet is 600 squares, 44 ounces, LA46 or PA40RE Lite.  Tapered airfoil from 18% root to 16% tip.  Shark 45 outlines for wing and tail, hence the name.  Anhedral allows the RE engine muffler to not hit the wing and line up the vertical CG with the tips.  Plus it looks cool.
I'll paste the plans on in the following post.
Pat Johnston
Jet Design Section
Skunk Works
Re: Profile Mako Jet
« Reply #1 on: March 29, 2011, 12:20:48 PM »
Now for the plans:
Pat
« Reply #2 on: March 29, 2011, 12:58:49 PM »
A typical cool Pat Plane. Can't wait to see it on the contest circuit this year.
« Reply #3 on: March 29, 2011, 01:13:22 PM »
Really Sweet, Pat.
Actually, you still have a kinda "Warbird" theme going.  A touch here and there and you have an A-7 Corsair II pretty easily. ;D
What are you using for reinforcement/doublers on the spars with the anhedral, anything?  Couldn't tell from the plans pdf.
« Reply #4 on: March 29, 2011, 01:44:32 PM »
Really Sweet, Pat.
yeah - how bout a full fuse A-7 Corsair Pat???   that would be AWESOME!!!!!  All time fav jet!
« Reply #5 on: March 29, 2011, 05:18:00 PM »
Gotta say the Corsair Jet is one of my favorite, too.  Better go find some three views...
The spars are flat 1/4 X 1/2 in the center of the plane.  Actually they are 1/8" thick and doubled out to about rib 7 as I recall.  They meet in the center and get doublers.  The center section sheeting is one piece so the integrity is good through the middle.  A little reinforcement in the leading edge joining area.  That's all.
Pat
« Reply #6 on: March 29, 2011, 05:32:51 PM »
Pat
draw one up - then chuck it straight on the laser cutter and then in the post to me........have been wanting to build on for years!
Walter Hicks
« Reply #7 on: March 29, 2011, 07:09:19 PM »
How about a Yak 55, Su- 26M , Katana or the likes??
Offline Jerry Leuty
« Reply #8 on: March 29, 2011, 07:31:37 PM »
    I like it. I have built two Rayettes and have started the tail assembly for a Stingray. Brickhaus is issuing the plans for the Eclipse, another Gialdini Jet stunter. This Mako Jet is way too cool. How about a short kit minus the hardware?
Jerry
« Reply #9 on: March 29, 2011, 07:39:33 PM »
Now go to the Carrier section and see Bill Bischoff version of the plane.  Except his is the Crusader.   Looks great tho.   H^^
« Reply #10 on: March 30, 2011, 06:46:34 AM »
Wynn, Jerry,
I already have the laser files setup and that is what I buildt the plane from.  Get in touch with me for the particular details of a short kit.  I can do ribs, fuse parts, tail parts, etc.
Catch me at pjohnston at idahopower dot com.
Pat Johnston
Laser Control
Skunk Works
« Reply #11 on: March 30, 2011, 02:47:56 PM »
Pat - I meant the A-7
« Reply #12 on: March 30, 2011, 03:01:53 PM »
Pat,
And such an original paint scheme.  LL~
Well, at least they will all match.
Offline Bryan Higgins
« Reply #13 on: March 30, 2011, 07:27:19 PM »
Pat
Really nice , the paint is so clean.  The wing design is my favorite part let us know how she fly's.  H^^
Bryan R higgins Jr.
Arvada,Colorado
AMA#885188
« Reply #14 on: March 31, 2011, 07:56:37 AM »
I just did a redesign of the ribs so they will support a constant thickness 3/8" flap.  That will be a lot easier to manage than a tapered built-up flap system.  My spread sheet shows the price of the short kit plus at $104.  This includes plans, ribs, tips, flaps, 1/2" fuselage core parts, doublers, motor mounts cheek doubler, stab and elevator frame.  The builder needs to supply sheet stock and misc. other parts.
Pat Johnston
Skunk Works
Offline Ward Van Duzer
« Reply #15 on: March 31, 2011, 08:49:50 AM »
Arrrrghhhhhhhh!
Somebody jumped my gun.
Attached is my "MIG-a-fied" Pathfinder.
Some people can't leave anything alone....
Great design Pat. Looks like there would be room for a pipe under the wing!
Ward-O
OOOps! forgot to shrink the 1st two pics! Is there any way to remove those two?
« Reply #16 on: April 01, 2011, 07:34:59 AM »
Ward,
I think we could make up a pair with these two.  The reason for the shoulder wing was to make clearance for the rear exhasut PA40.  I have a muffler version, but a tuned pipe would fit just fine.  This is the easy to get a pipe on a profile plane.  You were cleaver in solving it by canting the engine.  Two paths of climbing the same mountain.  I like your Mig design.  Mine is a lot closer to the Corsair/Crusader look.
Pat Johnston
Skunk Works
Offline dirty dan
« Reply #17 on: April 01, 2011, 02:30:03 PM »
Pat
Well, maybe on the paint. As this model was close to being finished I was asked for helpful tips and techniques--on the plastic finish!
Dan
Dan Rutherford
« Reply #18 on: April 01, 2011, 04:07:31 PM »
Yea, the canted engine is pretty much the same as I used on my Ringmaster Deluxe. Works pretty well and Dan just loves it.   ;D
>>smiley face just for Dan<<
