  • June 16, 2024, 04:28:07 PM
Author Topic: Eve of a spin-up  (Read 4327 times)
Re: Eve of a spin-up
« Reply #50 on: May 17, 2024, 05:10:23 PM »
Bobby, you are making the old DOC think hard about this design.   You do stupendous work. H^^ H^^ H^^
Online Bob Hunt
« Reply #51 on: May 17, 2024, 05:31:23 PM »
Thanks for the thoughts and kind words Steve and Doc.
Doc, the reason my work seems stupendous according to my wife is that I'm just plain stupid.... %^@
I'm very much considering working this one up into a plan if I can find someone who can cut the foam appropriately. I'm retired... #^ #^ #^ #^ #^
Later - Bob
« Reply #52 on: May 17, 2024, 07:25:27 PM »
Wow Bob
What a great series of build photos.
I’m hoping the movie will be out soon. 😉🍿
I think someone has a CnC foam cutter.
Tight Lines = Fun Times
« Reply #53 on: May 17, 2024, 07:33:16 PM »
All in all one of the better first days I've had with a new ship in years! Got in three full patterns and lots of 1 minute, 20 second trim flights. I'm pumped!
   I never cease to be amazed at your creativity, and willingness to try something new! I said this before, and you know I wouldn't just say it if I didn't mean it  - but I can't think of *anyone* who has contributed more to the advancement of stunt than you have, it's not even close!
    Thanks for showing us yet another one!
« Reply #54 on: May 17, 2024, 08:29:48 PM »
I just returned from a full day at the flying field. 4 to 6 winds, overcast and the grass cut to the nubs; nirvana!
The Double Take twin flies much better than I anticipated; now I wish I'd put s finish on it... mw~ mw~
 I have a couple of brand new BadAss 2310 motors, and tomorrow I'm going to retrofit the Double Take with them at Rick and Paul Walker's suggestion. They should spin the 10 x5 props a bit better than the Park 450 motors that are currently in the ship. They came down just a bit hot with the 10 x 5 props.
Be sure and post the results.  That is the combo I am putting in Endgame IV.  It is a bit larger than yours so I am using the 2320-850.  I am still a bit leery of these tiny motors!
« Reply #55 on: May 18, 2024, 05:57:32 AM »
Bob,
Great prestation and photos. Can you give us a bit more info on the battery packs and major trim adjustments you made.
Best,   DennisT
Online Bob Hunt
« Reply #56 on: May 18, 2024, 07:02:46 AM »
Wow! Thanks, Brett! That means more to me than you know...
I vividly remember the day we traded planes after a Nats (or was it a Team Trials...?). Your glow powered - and quite large - Infinity and my smallish, electric powered Genesis Extreme.
Two planes could not seem to be more different. And yet, our handle settings were virtually identical and the pitch trim we prefer was also spot on. I think we could have flown each other's planes in the contest and not really known the difference. The same thing happened when Mike Palko and I traded planes. I flew his P-51 Mustang and he flew that same Genesis Extreme. And again we could have flown each other's planes in the contest! By the way, Mike won the contest that day... I was a close second. Maybe I should have flown the "Stang." mw~
Brett has earned the respect of everyone in the Stunt community for not only his designing and flying prowess (which is considerable), but also for his ability to look at everything from a clear technical and logical perspective, and then present his findings in a manner that we can all understand. So, right back at you my friend for your creativity and service to our community.
Later - Bob
Online Dennis Nunes
« Reply #57 on: May 18, 2024, 08:42:58 AM »
Bob, I couldn't agree more with your compliments. I have the privilege of flying with Brett, when he can get out, for several years now. He has a unique gift for seeing what a model airplane does in the air that the majority of flyers can't or don't see. Along with the willingness to help, Brett also possesses the ability to communicate the issues and let's you know what needs to be done to fix them. And he does this in simple terms that even a second grader (like me) can understand. Thanks Brett!
Dennis
« Reply #58 on: May 18, 2024, 04:01:38 PM »
Ken:
The .02 carbon is a tissue-like material with indiscriminate weave. Good for over solid surfaces; not good over open bays. I get mine from Aerospace Composite Products in San Leandro, CA. It used to be very affordable, but - like everything else - it has gone up in price significantly. I'm looking around for a more affordable replacement
I got some of the more affordable stuff, and it won't be a nightmare the next time -- I tried putting it on the way folks tell you to do the ACP stuff, and it was a disaster.
It turns out that some of the carbon veil has sizing that's soluable in the thinners found in dope, and some doesn't.  This isn't too surprising, because epoxy isn't dope.  After a disaster of wrinkles and failed attempts at sanding them out and cursing and another layer of tissue, etc. I heard the factoid about the sizing.  Took a scrap of the stuff, dampened it with water like it was silkspan, and it went on like a dream.
So, when you're looking, if you find something, try out a sample patch with just dope, and if that doesn't work try dampening it with water or alcohol.
Online Bob Hunt
« Reply #59 on: May 19, 2024, 07:13:12 AM »
Bob,
Best,   DennisT
Hi Dennis:
Thanks for the kudos.
I'm using a single ThunderPower 5S 2200 battery pack, and it seems to work just fine. Next time I fly the ship I'll charge one battery separately (I usually charge 5 to 6 at a time on a para-board) and report on how many mA went back in.
The plane was slightly tail heavy at first (but very flyable), so I started adding clay inside the nose cone each flight until I achieved a good balance. This thing has corner to burn, so the extra weight in the nose didn't affect that. It was a bit light on line tension on the first couple of 1 minute 20 second flights, so we increased the inboard motor speed until that was cured. Still, with the 9-inch props (Zoars) it didn't pull very hard. More inboard motor speed would have helped that. But, when I went to the BadAss matched L&R 10x5 props, line tension was not an issue; it felt like it was attached to the end of a flagpole! With those props on I got a bit silly and just threw the ship all over the sky. It is most certainly one of the most fun airplanes I've flown.
Rick brought me back to earth a bit and we got back into a trim regimen until I ran out of batteries. Actually I had one left, but everyone else wanted to fly, so I put the Double Take away until I could retrofit it with the BadAss 2310-900 kv motors, Rick seems to think they will spin the 10-5 props better and produce a bit less heat. I may shorten the lines just a bit also; it is on 64 + feet center of airplane to center of handle now. This is not a big model at 565 square inches (think just slightly bigger than a Nobler...), and with the nose weight added it is now at just about 45 ounces with the battery on board (actual flight weight). The shorter lines may even increase the performance. I had a gut feeling that it was out there just a bit too far.
I will also try moving the leadouts a bit farther forward. Couldn't do this at the field on Friday because I didn't clearance the foam spar between the two cored out sections far enough to prevent the rear leadout from hitting it when moved forward. We've been flying most of our electric powered models with a somewhat further aft leadout placement, and I just assumed that I'd never need to move them very far forward. Rick Huff has discovered that with a twin you can move the leadouts very far forward and then increase the inboard motor speed to achieve a much better turn and lock. I tried this on my Turning Point twin - which flew at first just a bit better than the Wildfire twin - and found a whole new realm of turn, lock, and vertical/overhead performance. I then made that same change to the Wildfire and it too responded with much better performance all around. We are still on a learning curve with twins it seems, and they respond to some trim changes much differently than single motor ships. It just keeps getting better and better...
I also had the chance to fly Rick Huff's bf-110 twin (the one he flew at the Nats last year), and found it to be just about flawless in every respect; it turns incredibly well, tracks like a freight train in rounds, and, well, pulls like a freight train as well (my arm still hurts...). Then I let Rick fly my Crossfire, and he liked it a lot (it doesn't pull as had as his, however...).
Rick's brother, Tom was also there and he had his newly repaired and refinished Saturn with him for trimming. Rick and I spent a lot of time with that ship and got it flying really well, so all in all it was a very fun and productive day for all of us.
Next things to try on the Double Take will be a set of synthetic lines, the aforementioned BadAss 2310-900 motors, an adjustment to the internal foam spar (the old bandsaw blade through the leadout slot ploy - thank you Inspector Clouseau...). But the verdict for me is already in; this is one great flying little ship and I can see it becoming my go-to fun airplane.
I cannot promise when the plans for this one will be available, but I'm thinking sooner rather than later now that I've flown it and know that it is a good design. But, again, the limiting factor may be the availability of the proper foam core set for it (wing and tail), and, of course, time!.
Later - Bob
« Last Edit: May 23, 2024, 04:12:10 AM by Bob Hunt »
Offline John Skukalek
« Reply #60 on: May 19, 2024, 07:35:35 AM »
I know that August is a long way off Bob, but do you think we will see you and this airplane in Muncie?
Online Bob Hunt
« Reply #61 on: May 19, 2024, 10:19:49 AM »
LOL! You'll most likely see me in Muncie, but not with this ship (at least not to compete with. I might stick it in the car to give some of my friends a ride on it though...) I'll be there with a twin that has some paint on it!
Later  Bob
« Reply #62 on: May 19, 2024, 12:53:26 PM »
Cool. That's what I was thinking. That you might bring it for fun.
Offline dave siegler
  • sport flier
    • Circlemasters Flying club
« Reply #63 on: May 19, 2024, 02:56:43 PM »
how it the wing joined at the center section?
doeste plywood carry though?  or just glass cloth over the top?
Dave Siegler
NE9N extra class
AMA 720731
Offline Brent Williams
« Reply #64 on: May 19, 2024, 03:15:38 PM »
Looks great Bob!
I noticed the nacelles place the motors closer to the leading edge than is possible with an IC twin.  Do you find this motor placement to be an advantage for flying performance, or CG management, or some other reasons?
I made a quicky line drawing of this.  Scale is to the nearest 'ish.   Kinda fun to use for imagineering purposes.
Online Bob Hunt
« Reply #65 on: May 19, 2024, 03:24:33 PM »
Hi Dave:
The two Lite-Ply full-depth spars butt join at the center. The 1/8 x 3/8 basswood spars go virtually full span, and are solid over the center joint, and they are well glued to the top of the full depth Lite Ply spars to prevent racking. There is no glass used, but I double overlap the carbon when applying it. You can see this in one of the above photos. The wing is stiff as a surfboard!
Later - Bob
Online Bob Hunt
« Reply #66 on: May 19, 2024, 03:44:14 PM »
My son, Robby and I went out for a long session today. Robby has inherited my Genesis Extreme that was built in 2001! That plane owes us nothing, but it keeps on flying extremely well.
I did a few changes to the Double Take before this session. Biggest update was changing from the E-Flight Park 450 motors to the BadAss 2310-900 motors. I noticed while I was doing the changeover that the outboard motor had no offset at all. The inboard had a bit (about 1 degree). I put in some outboard offset, and also added just a touch of tip weight.
The difference in performance with the BadAss motors was a bit amazing. Much better pull (although the added offset might have had something to do with that...). and I was able to slow the ship down a bit and still have better tension. I also reduced the RPM difference between the inboard and outboard motors a bit. I'm still running the inboard motor about 300 RPM faster than the outboard. I'll keep playing with that... It now feels like a regular size stunt model at the end of the lines. It is very easy to do rounds, and it turns and locks as well as anything I own. Robby commented that it doesn't look small in the air and suggested that I might try even longer lines (it's currently on 64 feet from center of plane to center of handle). The big thing for me was that the BadAss motors easily pulled the BadAss 10x5 props (L&R) without any heat build up. They came down warm, while the Park 450s were on the hot side.
Robby took some short videos and sent them to my computer. If anyone wants to see them, I'll forward them via email. PM me with your email address. Each video shows only one maneuver due to file size (I have to send them with Mail Drop).
This project for me is already a resounding success. Small twins at a very reasonable cost in money, time, and weight are now a reality. Fully trimmed now the weight is 44.5 ounces with battery on board.
I'm sold on twins of any size, but this small one is a hoot!
Later - Bob
« Last Edit: May 20, 2024, 05:43:28 AM by Bob Hunt »
« Reply #67 on: May 19, 2024, 06:52:07 PM »
Bob,
Interesting progress. Could you post the rpm and lap times that you are flying it at? Also, with the twins where do you set the CG? Last, since you went to the 10x5's relative to the CG where did the leadout position land?
Best,   DennisT
Offline Doug Moisuk
« Reply #68 on: May 19, 2024, 10:17:07 PM »
Hi Bob
Greetings from Canada EH
Love the new model. That fuse style is magnificent. I fly IC but you are tempting me to electric. Don’t tell my friends.
What’s the wing span and wing area?
Will you be producing plans?
Doug Moisuk
MAAC 3360L
Offline fred cesquim
    • Fred Cesquim Aeromodelos
« Reply #69 on: May 22, 2024, 03:35:55 AM »
The Double Take twin flies much better than I anticipated; now I wish I'd put a finish on it... mw~ mw~
Seriously, Rick and Sara Marie Huff, and Tom Huff joined me for a great day of flying. Rick has a ton of twin experience and he made some suggestions that made the little twin fly better and better with each flight. I initially had Zoar 9 x 5 props on it, and they worked okay, but then we threw on a matched set (L & R) of BadAss 10 x 5 props and the ship came alive in a big way. I discovered that I have a couple of brand new BadAss 2310 motors, and tomorrow I'm going to retrofit the Double Take with them at Rick and Paul Walker's suggestion. They should spin the 10 x5 props a bit better than the Park 450 motors that are currently in the ship. They came down just a bit hot with the 10 x 5 props...
Later - Bob
P.S.: The takeoff roll on grass at full power is less than six inches (actually a lot less!). Of course on asphalt I could hold in a bit of down elevator and achieve a longer roll, but it's fun to watch it looking like it was shot out of a cannon! - Bob
Congratulations Bob, another landmark model! pretty and practical to build. As always pushing the envelope and develpoing new technics! awesome desing and great construction pictures!
Offline Keith Renecle
« Reply #70 on: May 24, 2024, 09:31:45 AM »
Hi Bob, Great design.......as always! I've been playing with foam models and various coverings with wood glues like Titebond etc. My .15 size stunt trainers were made completely out of Isoboard which is similar to Depron being extruded foam. At first I covered them with medium weight silkspan or in my case teabag tissue, but I found that it is not that ding-proof. I improved this by changing from PVA glue to Aliphatic resin which dries a lot harder and even sands quite well. My latest attempts use the light weight glass cloth (25 grams/sq.metre) with the aliphatic resin. The tail feathers come out real nice and strong and can be painted even with the lacquer paint if you don't go too crazy on the thinners for the first coats. I would thin that the aliphatic would work really well with that carbon matt.
I also make a filler from baby powder and a small amount of aliphatic plus water. You need to experiment with the quantities but it makes a nice filler for foam parts. With the price of balsa right now, especially here in Darkest Africa, these foam parts are a blessing. I made a few WW2 combat models completely out of Isoboard using this method.
Keith R
« Last Edit: May 24, 2024, 10:55:57 PM by Keith Renecle »
Keith R
Online Bob Hunt
« Reply #71 on: May 24, 2024, 11:54:45 AM »
Hi Keith:
Yeah, these foam airplanes (of any type) are fun, inexpensive, quick to build, and even expendable to a point (although my new twin did take a while to complete...).
I've toyed with the idea of using some sort of light filler to fill the slight imperfections that are left when covering the foam with .02 ounce carbon and thinned titebond. I came to the conclusion that my method as is works just great for test-bed type models and training models. I'll bite the bullet and cover cores with very thin (like, less than .032...) in the future if I indeed want to put a finish on them. The balsa would serve to allow me to sand a perfectly smooth surface on the cores. Then I could do any number of types of finish.
Not too long ago I bit the bullet and bought a Jet 16-32 drum sander. Best purchase I ever made! I can hold nominally .002 tolerance side to side and end to end on a piece of 3-inch wide balsa. I bought that piece of equipment because I was able to score a huge pile of balsa from a kit manufacturer who decided to quit the business. He was quite optimistic it seems about just how many kits he'd sell, and so bought thousands of sheets of balsa from a supplier in Canada. That wood sat in sealed boxes in his T-Hangar (he owned a full size Piper Dakota...) from 1991 or so until I bought it just a few years back; it was very dry!. The downside was the balsa was all 3mm thick. That's where the drum sander came in. I found that I could take that wood down to almost any desired thickness and make use of even the heavier stock in that cache of wood (a lot of it was 4 to 6 pound wood, and that was sanded to 1/16-inch). I've found numerous uses for that sander besides wing sheeting...
I have yet to seal the hinge gaps on the Double Take twin, but I'll do that this evening and try to get to the field over the weekend. This thing could easily become my go-to practice ship!
Later - Bob
« Reply #72 on: May 26, 2024, 11:56:36 AM »
Thanks Bob. The other things that I'd like to know are where do you hide the battery and ESC's? Your 900 Kv on those BadAss motors seems high for a 5 cell setup, so what rpm are you turning? Thanks!
Keith R
Keith R
Online Bob Hunt
« Reply #73 on: May 29, 2024, 06:53:49 AM »
Hi Keith:
LOL! Actually there is more room in the nose of this twin than there is in my larger twins. I finally learned that skinny fuselages are just not practical; took me about 60 years...
I had the 2,200 mAh 5S batteries on hand, and needed the nose weight. I moved the motors much closer to the leading edge of the wing proportionally than those in the larger twins, and so needed to add a bit more nose weight to balance the model. My battery holder positions the battery quite far forward, and is arched at the rear to allow a lot of room for the wiring and the two Talon 25 Amp ESCs to be positioned on angled plates inside the fuselage (I'll try to get some photos of all that today).
The batteries seem to work fine pulling the 10 x 5 BadAss props, and the BadAss 2310-900 kv motors come down just barely lukewarm. Everything seems pretty happy.
One thing I did learn this week (and it is something I preach all the time but didn't follow my own advice this time) is to seal the hinge gaps before flying a new ship. I didn't do that initially and thought the ship had way more than sufficient corner. I sealed the gaps over this past weekend and flew the ship. WOW! I now will have to calm it down as the corners are just too bizzarre and too hard to control. I have the handle spacing opened up quite a bit, so I'll reduce that spacing just a bit and add just a touch more nose weight until I get it to where it is predictable and consistent. Nice problem to have...
I'm currently building another version of this design with a much higher aspect ratio wing; try 7 to 1! The span is 63 inches and the average chord is 9.125 inches (can you say Dennis Adamisin?). I have the wing, stab & elev assembly, and the fuselage and nacelle crutches finished, and the top and bottom shells are molded. This one will incorporate a brand new control system design, and I'll expand on that at a later date. Unlike this first small twin, the new one will have a full blown finish and the nacelles will be built-up units; not profile like this test bed.
Lots of new stuff to try, and precious little time left...
Later - Bob
« Reply #74 on: May 30, 2024, 11:21:00 AM »
Thanks a ton Bob! I appreciate the info greatly. That's such a great project. Please tell us the present rpm as well if you don't mind. That would also be interesting.
Keith R
Keith R
Online Bob Hunt
« Reply #75 on: June 03, 2024, 06:59:29 AM »
Hi Keith:
I don't have the RPM numbers for you at this time, but I'll try to remember to check them next time out.
Again, with the hinges sealed the ship was way too responsive. I told my old buddy, Dean Pappas about this and he asked me where the elevator slider was set. Homer Simpson moment number two (the first HS moment happened at last year's Nats when Howard Rush asked me the same question about the slider position on my Turning Point twin). On both occasions I was so anxious to get the birds flying that I did not do a proper bench trim check. In both cases the slider was at the very top of the adjustment, giving me a ton of elevator movement versus flap movement. And, in both cases moving the slider down (significantly...) made each of the planes very easy to corner and bottom. Lesson learned; bench trim EVERYTHING!
The Double Take is now just a pure joy to fly. I let Rick Huff have a ride on it during my club's Electric Fun-Fly this past weekend, and he loved it. It was a treat for me to be able to see it from outside the circle. As everyone who has seen it fly told me, it doesn't look very small in the air at all. Again, it has 565 square inches of wing area, which makes it just a bit larger than a stock Nobler. This plane could easily become a "daily driver" for reflex and pattern practice. It is extremely easy to hit and lock bottoms, and it tracks rounds as good or better than anything I've ever owned.
I've received requests for plans for this one, and as things wind down from the Summer's activities I'll make some time to draw a set. But, again (as mentioned in a post above) the hard part might be getting foam core sets made as I'm retired from that business.
I took a few more photos of the Double Take showing the bottom, a close-up of the battery installation, and the battery holder.
Later - Bob
Online Bob Hunt
« Reply #76 on: June 03, 2024, 07:02:38 AM »
And here are few more of the finished (?) ship.
Later - Bob
Offline Matt Neumann
« Reply #77 on: June 03, 2024, 12:23:36 PM »
While I understand it would be hard to give all the dimensions here, I am curious as to the tail moment and nose moment.  That would give me a good idea of size.  As for a problem of making cores.  Do just like the good old days and give the tip and root template and leave it up to the builder to figure out how to get the cores cut.  Just say, don't look at me.
Matt Neumann
« Reply #78 on: June 03, 2024, 12:33:10 PM »
So, Bob, where are you getting the carbon veil?  We used to get it from Justin Sparr, but ACP seems to have gone away from hobby/small order business. I am down to 1 roll of the "hard"/uniform type that gives excessive pinholes and don't know where to get the good kind.
« Reply #79 on: June 03, 2024, 03:07:04 PM »
Really inspiring.  All it is missing is the Canard! LL~  I love your arming plug.  I always have two because I keep losing them.  You have those motors really close to the wing.  I thought I was doing good at 1".  Are you using bullets on both ends of the motor leads or just one long set of wires to the ESC.  I personally don't like connectors where I can't see them.  I found the perfect tunnel to the nacelle.  Plastic Smoothie straws.  3 #13 wires with bullets fir perfectly.
Online Bob Hunt
« Reply #80 on: June 03, 2024, 03:56:37 PM »
Yeah, when Justin first got there we had an "in." A Nats Stunt Champ at the helm. Sigh...
I bought a lot of the good stuff a few years ago and I'm nearing the end of that roll. I suppose we could get a bunch of guys together and by a bolt of the stuff and divvy it up and split the cost. For what I'm doing with the wings like I have in the Double Take I could use silkspan (even the new "bad" stuff), or even Polyspan Lite.
Has anyone from the Stunt community contacted Justin about special dispensation for his old Stunt buddies? If you think it would help, I'd try. The worst he could do is say "no."
Later - Bob
Online Bob Hunt
« Reply #81 on: June 03, 2024, 03:57:55 PM »
Ya know, that doesn't look half bad, Ken! Finding the room for the tube and the linkage might be a problem, though...
Later - Bob
« Reply #82 on: June 03, 2024, 07:36:21 PM »
Later - Bob
It is contagious.  I can't picture Endgame III without it now.  Ah, the nose linkage.  I spent most of today on that.  When I went to the 5" bellcrank I had a  bump put on the outside to drive the Canard.  The hole in the bellcrank is as close to the pivot as possible and still clear the ball link.  I test mounted the wing and tested the controls and they worked great except for one minor detail.  Way too much Canard movement.  Like 40 degrees. If I put a taller post on the pushrod will be running through the pilot.  Only solution - an intermediate reducing lever in that huge canopy area behind the pilot's seat.  I had originally drawn that up but thought I could get away with a straight shot.  I failed to consider that making it in line also meant that the canard and the batttery would be lower.  Oh well, when you compose planes instead of building them you get days like this!  Picture is the way it was hooked up to my balsa construction bellcrank I use to lay things out.
« Last Edit: June 04, 2024, 05:06:56 PM by Ken Culbertson »
« Reply #83 on: June 04, 2024, 08:10:57 AM »
You just got me thinking of my plane.  I had my slider moved up as far as it would go.  I did this on my IC planes and never gave it a second thought until I read this.  I moved it down and now things are smoother.  I had to widen the handle spacing just a bit and will probably move the battery a bit farther foreword but the plane is settling down more now.  What works on IC engined planes don't always apply to electrics.
Matt Neumann
Offline GallopingGhostler
« Reply #84 on: June 04, 2024, 11:32:20 AM »
Bob, that is a really sharp looking electric twin you are building, love the design. Also, I really like the pictorial tutorial styled thread you are posting, gives very clear details on how to do your particular method of construction of foam core wings and how you keep the fuselage clean, functional and lightweight.
Looking forward to seeing your completed results and first flight reports.
Online Bob Hunt
« Reply #85 on: June 04, 2024, 01:36:06 PM »
Hi GG:
If you read the thread carefully you'll see that the model pictured IS the finished model, and it has been flying as is for about a week and a half. But thanks for the kudos anyway.  H^^
The flight reports are noted above.
Later - Bob
« Reply #86 on: June 04, 2024, 06:12:42 PM »
Bob:
You asked about the Canard linkage.  I posted it over on my Endgame IV build thread.   I am still curious how you handled the motor wires with the mounts virtually on the wing LE.
https://stunthanger.com/smf/building-techniques/endgame-iv-build/
Online Bob Hunt
« Reply #87 on: June 05, 2024, 06:40:05 AM »
Hi Ken:
As one of the photos shows, the motor wires just tuck into a 1/2-inch diameter hole on the inside of the nacelles on the bottom of the plane. I positioned the inboard motor's ESC (a Talon 25 Amp) on the outboard side of the fuselage and vice versa for the outboard motor. This allowed for a bit of slack in the wires to allow me to use bullets to connect the motors to the ESCs. I simply pull an ESC off of its mounting plate (see one of the photos above), pull the wires from the nacelle end until the bullets magically appear out of the hole, and disconnect them there. I reverse the process to pull the wires back into place and then remont the ESC on its corresponding plate. I use small patches of velcro to mount the ESCs to the plates. Easy Peasy! When the wires are in flight position, there is not enough slack for them to interfere with the forward leadout.
Some have indicated that the ESCs should not be situated in the fuselage, and have said that there is some sort of interference between them if mounted that way. I've seen no evidence of that at all; they work perfectly, and it does cut down on the weight at the extremities a bit (Gialdini's "Bar-Bell" effect...). I'll most likely mount my twin model ESCs in the fuselage from now on.
Later - Bob
