  • July 19, 2025, 02:41:00 AM
Author Topic: Ersatz Maintenance Rotisserie  (Read 990 times)
Offline Peter in Fairfax, VA
« on: June 07, 2022, 05:59:36 AM »
Mounting your stunter, or even your classic car, on a jig that allows it to be rotated for maintenance is increasingly possible.  For stunters, typical is to use the engine mount as an attachment point.
Absent such a rig and the time to remove/replace the engine, what's a good way to hold a stunter "wingtip high?"  Obviously, hanging by the leadouts is possible for one side.  As I type, I realize that rope from the hanging bar to the fuse would also work.
Thoughts on best methods to support a stunter in various positions?
thanks,
Peter
Offline Ty Marcucci
Re: Ersatz Maintenance Rotisserie
« Reply #1 on: June 07, 2022, 09:27:38 PM »
 I have two, two  inch dowels protruding  from my work bench. They slide in or out as needed.  Photos later. With these I can rest the fuselage on either side, letting me work on almost the entire model.  H^^
« Last Edit: June 11, 2022, 12:18:07 PM by Ty Marcucci »
Ty Marcucci
Offline Ty Marcucci
« Reply #2 on: June 07, 2022, 09:54:45 PM »
Disregard the back ground. LL~
Ty Marcucci
« Reply #3 on: June 08, 2022, 11:38:27 AM »
Ty, that's cool!  I may add that to my bench.  I think I'd keep some of those pipe insulation things handy, to avoid scuffing the model (I'm really bad at getting one side of a part nice and pretty, lifting it off my bench, and finding bits of junk embedded in the offside surface).
« Reply #4 on: June 08, 2022, 02:37:12 PM »
I’m stealing this idea Ty. Hope it’s ok. 🤣
« Reply #5 on: June 08, 2022, 03:03:03 PM »
I like that rig, and imagine a similar rig which is essentially a U-shaped jig that clamps to a bench, perhaps with a slight angle so the plane slides toward the bench.
Spacing of the rods is somewhat obvious - must be greater than wing chord at root.
« Reply #6 on: June 09, 2022, 11:27:11 AM »
Ty,
Your method worked great.  My rendition is shown below.  I was adding some glue to a fuse/wing joint and trying to avoid the look we all know too well of glue running down, away from where it is needed.
thanks,
Peter
