  • July 20, 2025, 12:12:26 AM
Author Topic: Replica Battery Scan Needed  (Read 2572 times)
Offline Harleyman
  • ACE
    • Circle Masters
« on: October 22, 2017, 02:32:57 PM »
Hi Guys,  Remember me?     I'm back in the saddle again.     y1
Would any of you super talented computer graphics guys happen to have a full size, clean, bright scan of all 6 sides of this puppy?  I'd like to make a replica with new re-chargeable innards and need a scan of all the sides.
I already have some other replica scans of the old Eveready and Rayovac cylinder dry cells, but, I really like this old Cox battery.
« Last Edit: October 22, 2017, 11:37:29 PM by Harleyman »
Chris Sterner
AMA 1825
EAA 1429853
https://circlemasters.com
Re: Replica Battery Scan Needed
« Reply #1 on: October 22, 2017, 03:31:15 PM »
   Those old battery cover would let loose at the seems and they would unfold after a while. If you steam the thing it may do that, and then you can lay it on a color copy machine or flat bed scanner to make copies. I don't know if I have one of those or not but I'm going through things today and if I run across one I'll let you know. I have made the round type cells and powered them with Cylone 2 volt rechargeable batteries, I think there are pics on the forum here some where. That size shpould even hold four "C" size dry cells in parallel, and you could build one you could open up and rebuild with fresh cells. That is what I was kind of thinking about last time I messed with them.
Offline George Albo
« Reply #2 on: October 22, 2017, 06:52:39 PM »
Found this on Fleabay. Might want to get it, scan it. When dead, make rechargeable like you want.--Just a suggestion
http://www.ebay.ca/itm/COX-SUPER-POWER-STARTING-BATTERY-GLOW-STARTER-BATTERY-NOS-SEALED-/222686098177?hash=item33d9203301:g:FNUAAOSw~9BZsLvA
Offline George Albo
« Reply #3 on: October 22, 2017, 06:54:43 PM »
Can also go to Cox engine forum and ask around.
https://www.coxengineforum.com/
« Reply #4 on: October 22, 2017, 07:58:35 PM »
  I've got that one, an all red version, and a Ray-O-Vac (I think) that is yellow and red. Don't have time tonight to get them unfolded and coax my scanner into working, but will get at it when I get home from work tomorrow afternoon. PM me your email address so I can send the files when finished.
   The red ones are kind of stained, but maybe you know some one that can touch up the files on a computer with Photoshop or something. They should lay out nice and flat. Run off a good color copy, then paste it to something like cereal box chip board with contact cement, cut out, and fold where necessary to assemble. The one you posted came from the #400 Cox Starting kit with the fuel can about the same colors.
   Type at you tomorrow,
Offline Dane Martin
  • heli pilot BHOR
« Reply #5 on: October 22, 2017, 08:41:18 PM »
A scan ? Would large full size pics emailed to you work? I have a brand new battery I could take plenty of pics of.
« Reply #6 on: October 22, 2017, 08:55:09 PM »
... Don't have time tonight to get them unfolded and coax my scanner into working, but will get at it when I get home from work tomorrow afternoon...
Just in case, when you get your scanner working scan all five sides that you can get to and take a picture of the top, in case your efforts at steaming the thing apart fail.
Cool idea.
Offline Harleyman
  • ACE
    • Circle Masters
« Reply #7 on: October 22, 2017, 09:20:19 PM »
If you laid it on a Scanner/printer and scanned all sided, the scans can then be printed out at actual size, and glued to a battery box, I'd make.
Chris Sterner
AMA 1825
EAA 1429853
Offline Harleyman
  • ACE
    • Circle Masters
« Reply #8 on: October 22, 2017, 09:23:10 PM »
Thanks Dan!!
My email is my last name:"sterner"then "6854" "at" "gmail"dot"com"
No rush, take your time.  Thanks again.
« Last Edit: October 22, 2017, 11:26:24 PM by Harleyman »
Chris Sterner
AMA 1825
EAA 1429853
Offline dave siegler
  • sport flier
    • Circlemasters Flying club
« Reply #9 on: October 22, 2017, 09:34:46 PM »
I just tried to redraw it from your pic.
Still need some work.
Lay it on a scanner.  make sure it is square and I can trace it.
I used inkscape. an open source program
Dave Siegler
NE9N extra class
AMA 720731
Offline Harleyman
  • ACE
    • Circle Masters
« Reply #10 on: October 22, 2017, 11:29:17 PM »
I don't have one, I just copied a photo off the interwebs.
That's pretty cool for just tracing it.  I might be able to use that if no one else can do an actual scan.
Chris Sterner
AMA 1825
EAA 1429853
« Reply #11 on: October 23, 2017, 06:06:52 PM »
  Hi Chris;
    Just sent you an email with all three files attached. Let me know how it works.
« Reply #12 on: October 23, 2017, 06:08:42 PM »
  Hey Dave;
   Send me an email to ;  dpmcenthusiast at aol dot com and I'll send youthe same scans I just sent Chris to see what you can do with them.
  • sport flier
« Reply #13 on: October 24, 2017, 01:30:23 PM »
  Hey Dave;
I have it and am starting to work on it.
The type fonts are not exact but it is representative. Someone that real good with gimp or adobe illustrator could whip this out real quick. I am not real fast as an artist
Dave Siegler
NE9N extra class
AMA 720731
Offline Curt D Contrata
« Reply #14 on: October 25, 2017, 08:38:24 PM »
Did you get what you needed? I have one in very nice shape that I can scan for you, let me know.
Curt
Offline Harleyman
  • ACE
    • Circle Masters
« Reply #15 on: October 25, 2017, 09:09:12 PM »
Curt,
Yes I got a few scans from Mr. McEntee.  He sent not only the Cox, but also a different Cox Battery and a really cool scan of an old Ray-O-Vac battery that is pretty faded.  I would love to figure out how to enhance the color on it.  Living in WI and with Ray-O-Vac only a few miles away in Madison, I think that was my first Hobby battery when I was about 12 years old.  That one, I'm going to use somehow.
If you have do have one in good condition, I'd like to see it, if it's not too much trouble.
Chris Sterner
AMA 1825
EAA 1429853
Offline Robertc
« Reply #16 on: October 26, 2017, 09:36:51 AM »
If you want to send me the scans, I worked in Illustrator and Photoshop.  See if I can clean them up.
« Reply #17 on: October 26, 2017, 04:21:42 PM »
Ok, I will open, unfold, and scan tomorrow for you.
Curt
« Reply #18 on: October 27, 2017, 08:37:33 PM »
As it turned out, mine was brand new and still in a sealed plastic bag. I opened it today and removed the batteries and as you would expect, they were corroded. That said, the box was still in pretty great shape with only slight fading and deterioration at the edges/corners. I un-folded it and scanned it with a contrasting color background so as to see the edges of the original. In spite of it being NOS, there were still quite a few imperfections that needed to be re-touched. I am working with it in Photoshop and should have it done by the end of next week.
Curt
Offline Harleyman
  • ACE
    • Circle Masters
« Reply #19 on: October 27, 2017, 10:32:45 PM »
Curt,
Wow, that's great.  could you send the scan before retouching it and then after?
I just might use the old scans and the new scans.
Thanks again, this is very nice.  Nice of all of you that have made the time to help me out.
Chris
Chris Sterner
AMA 1825
EAA 1429853
« Reply #20 on: November 13, 2017, 12:34:46 PM »
Chris,
Please send me a PM with your email so I can send you the artwork as they each exceed the upload size limit.
Curt
Offline Harleyman
  • ACE
    • Circle Masters
« Reply #21 on: November 13, 2017, 05:00:28 PM »
PM sent   H^^
Chris Sterner
AMA 1825
EAA 1429853
« Reply #22 on: November 13, 2017, 06:22:05 PM »
I would do the thing if I had the time. I honestly don't have the time.
However, I would ask for the can, to return of course, and not for scanning. Just for measurements and to copy.
I would draw the art from scratch in a vector file.
But that's me.
« Reply #23 on: November 13, 2017, 07:28:21 PM »
But that's me.
But then, it would be re-drawn and not re-touched. More a replica than a restored original.
Curt
« Reply #24 on: November 13, 2017, 07:53:27 PM »
Curt
Curt,
The original is on the can.
Better to draw it from scratch over the scan, it'll be easier. At least for me it will be because I'll use a vector file.
Probably easier to match colors with Photoshop. Fine tune color with test prints.
Colors on the can could be faded? Could?
This is an interesting challenge.
Keep us Posted.
Charles
« Reply #25 on: November 13, 2017, 08:00:22 PM »
Curt,
Keep us Posted.
Charles
    This is proof that you never read a whole post or all the posts, Charles!!!! mw~ mw~ mw~  We are discussing  a BATTERY cover, not  a CAN!!! And you posted that way TWICE!!!  Even the thread topic says BATTERY !
    Just an observation,
