  • July 18, 2025, 02:08:49 AM
Author Topic: Enya #3 Plug and Ni-starter problems  (Read 1739 times)
Offline John Lindberg
« on: September 02, 2019, 06:01:58 PM »
I have a few Enya #3 glow plugs, but my Sonic-Tronics ( or whatever it is) doesn't fit it very well, really hard to get off after the engine starts up. Anyone have similar problems, any solutions?  HB~>
John Gluth
Re: Enya #3 Plug and Ni-starter problems
« Reply #1 on: September 02, 2019, 07:14:13 PM »
Can you remove the igniter without the engine running? Otherwise follow righty-lefty convention.
« Reply #2 on: September 02, 2019, 07:42:46 PM »
   I think it says in the instruction to never use Enya plugs, but I ground down the tip of the center electrode to a point,  and didn't have any problems after that.
« Reply #3 on: September 02, 2019, 08:32:59 PM »
I had similar problems with 2 older Sonic Tronic units but the new one I have works fine.  Easy on and easy off of Enya Plugs!  Perhaps they have fixed the problem!
Offline Dave Harmon
  • Tulsa Glue Dobbers C/L and R/C Clubs AMA 5053
« Reply #4 on: September 03, 2019, 06:35:29 AM »
I have 2 of the newer metered Sonic-Tronic battery units and they work fine on the Enya 3.
I think I remember having that same trouble years ago with the Enya 3 plug so my guess is that ST changed something to make their glow drivers better in this regard.
Offline Balsa Butcher
  • High Desert Flier
« Reply #5 on: September 03, 2019, 10:40:35 AM »
I just keep a Great Planes (?) spring loaded style starter battery in my box for engines that use the Enya #3 plug. It does double duty as it serves as a back should my Sonic Tronic battery unexpectedly lose its charge (which isn't often).  8)
Just checked: Backup is  a DuBro spring loaded NiCad starter battery.
« Last Edit: September 03, 2019, 10:57:36 PM by Balsa Butcher »
Pete Cunha
Sacramento CA.
AMA 57499
Offline Dave Harmon
« Reply #6 on: September 04, 2019, 09:44:27 AM »
The big knob on top of the Enya 3 can be unscrewed from the body of the plug.
You could try removing it to expose the threaded stud coming out the top of the plug.
It might be long enough to press up against the center contact of the Sonic-Tronic driver.
Offline Jim Damerell
« Reply #7 on: September 04, 2019, 11:48:09 AM »
Or you could just trade those nasty plugs to me for something else. Where can you buy Enya #3 plugs?
Offline Dave Harmon
« Reply #8 on: September 04, 2019, 11:54:59 AM »
I get them from RC Japan....other stuff too...pretty cheap and about 5 day shipping.
You'll like them!
« Reply #9 on: September 04, 2019, 12:04:52 PM »
   I just ground it down on my belt sander, took a few seconds, then it was fine.
    Its not as good as the Thunderbolt 4-cycle in any of my engines, but otherwise, it's a good plug and worth trying. They used to be unreasonably expensive, but now, all of them are unreasonably expensive.
« Reply #10 on: September 04, 2019, 01:33:12 PM »
You'll like them!
You can also buy  them and many other plugs   from Aero products
Offline Dennis Moritz
« Reply #11 on: September 04, 2019, 02:42:29 PM »
I spread the grip ends a bit. Or simply put them on and take them off a few times. The ends will widen enough to release more easily. I just put an Enya 3 in an engine and used a
Sonic. First few times it needed a firm twist to release then ok. I find the ends of Sonics loosen up after extensive use. They need to be pinched in a bit when that happens. This will happen even when using narrow stemmed Thunderbolts. Loose fitting Sonic glow drivers can be a hazard.
« Last Edit: September 04, 2019, 03:08:49 PM by Dennis Moritz »
« Reply #12 on: September 05, 2019, 07:20:00 AM »
Even though Gerry has not chimed in, he is probably too busy reading the Mueller Report, thanks for the replies!  :!
